06-08-2016, 12:25 PM
#21
alternator noise in the radio... you can install a filter on the power leads of the radio that should help it out quite a bit..
06-11-2016, 04:03 PM
#22
Engine: 5.9L Cummins
Ok, still looking for suggestions on the removal of the heaters.
As for my water setup, I'd ideally like a setup that will let me and my significant other be "off-grid" for an 8 day stretch. What tank size would you guys recommend for fresh/grey/black water? We will not be putting in a standing shower, just a metal trough for "whores baths", ie. wand while squatting
I'm also flip flopping on fridge type. I only want a half fridge, but theres a good chunk of you who have electrical only fridges. That would be a pain to run off a generator for an 8 day stretch. My old 1972 triple mimac has a propane fridge and its worked great . Never blew out the pilot going down the highway so it was always cold, regardless of our travels. Are new propane fridges really that bad? There was a thread where the guy said his propane fridge generated so much heat he took it out. I dont remember any heat coming from mine in my old RV. Did he just have poor venting?
I just want a simple propane system (tank, water heater, potentially fridge, and stove) and a simple battery system that would be 12 volt lights/stereo, with a generator for plugs and the roof mounted A/C. For running a 13,500 BTU AC, I know I need a min.3100 watt generator, but what about inverter/converter size?
06-11-2016, 06:15 PM
#23
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Originally Posted by -cycosis-
These are the heaters Im up against. They run the length of the bus on each side. I have not come across another thread that had the same type of heaters.
Suggestions for eventual removal?
Leave the heaters in. Just replace the heat source with hydronic heaters.
I'd go with 50 gal grey/potable tanks and have already installed a composting toilet. Those require NO external tankage, only peat moss.
07-01-2016, 12:56 PM
#24
Whats a good source for water tanks? I dont think I can afford $500 for a 100 gallon fresh water tank....
07-01-2016, 01:08 PM
#25
Coachwork: Crown / Pusher
Craigslist, just keep looking & one day it may magically appear, I keep going back everyday & putting RV parts in the search & one day I saw a Bounder being parted out ran over & got 2ea 24 gal propane tanks & a 100gal freshwater tank.
07-01-2016, 10:16 PM
#26
My heater doesnt run the full length but a good distance and i just left em. Even left a rear seat to protect a rear heater and it came in super handy to support the front end of my work bench
and yes i second the magic of Craigslist
07-01-2016, 10:34 PM
#27
Keep an eye on Ebay...I found a perfect fit for about 25% of the going rate.
07-02-2016, 01:58 PM
#28
Thx for the insight
07-05-2016, 04:26 PM
#29
Black water tanks! I have a couple local plastic molding companies that have given me some good quotes on polyethylene tanks. They are cubic though with no slope. Should I really bite the bullet and buy a sloped RV black tank or do you think it is wise to try and save, and buy a regular cubed tank and add slope via the mounting brackets?
07-15-2016, 03:22 PM
#30
Still in parts acquisition mode. I have about 50% of the seats out and a stereo system wired in temporarily for by bachelor trip at the end of the month . Pretty hastily done.
Any tips for roof vents with fans that are not $300 +??????
Managed to score a Dometic Penguin 13500 BTU unit + control panel for $800 CAD delivered Was only test fit once on a trailer before a customer changed his mind.
Also scored a Dickinson 12000 propane heater for $900 CAD delivered too!!
07-15-2016, 04:05 PM
#31
Electrical question: If I have no plans to hookup a TV/microwave and I dont need to have outlets running when the bus is driving, do I really need an inverter?
I will be running off either shore power or generator. I am not doing a solar setup.
07-15-2016, 08:09 PM
#32
The only reason you need an inverter is wanting 120 VAC while not connected to shore or generator power. How will you charge your house batteries?
07-15-2016, 09:36 PM
#33
Shore, generator, and hopefully via alternator when driving? I assume that's possible.
This rig is going to be setup more for festivals where it's noisy all the time, not family friendly or retiree quiet campgrounds
07-16-2016, 01:23 AM
#34
You can do all of these things!
Good luck!
09-10-2016, 11:21 AM
#35
Bus Seats finally out! Wedding planning has progressed enough to have a comfortable green light for distractions Feels so good to make progress.
Couple things. I have started to attack the roof rivets on the inside with an air hammer. Damn its tough! About 30 seconds/rivet head. Any tips? Or is that normal? I have been punching out the mandrel first.
Second, anyone know of an ospho equivalent here in Calgary Canada? Cant track anything down and I need to treat my outside spots ASAP as they are getting worse.
3rd Question: Has anyone done a roof raise below the windows and kept the windows in during the raise? I dont want to remove my windows. I like them. I am not full timing. But Im 6'5" and woudlnt mind 4 inches.
09-14-2016, 08:50 PM
#37
Coachwork: BB
Engine: Cummins
Rated Cap: 25.999K
Same page.
You're building my bus. Starting from the same platform. Only difference i see that you want, and what i want, is I'm not committing to a roof raise just yet. I'm 6-3, and hit my head constantly, so maybe once i smack it a few more times, I may change my tune...
09-15-2016, 09:16 AM
#38
Originally Posted by superduty_59
theres another one.. they are not here on the forums but it was done with a raise cut below the windows.. in fact they left the rib on below the windows and used it as a guide to cut and allowed their roof to not skew.. of course as always you have to use straps or such to keep the roof from spreading.. but it looked to me like a pretty straightforward way if there is sich a thing to raise a roof..
fortunately mny "curse" of being only 5'9" is a blessing in the bus world so my 6'6" ceiling I have no issues in standing up
09-15-2016, 11:51 AM
#39
No longer doing a roof raise. I scored two great huge sky lights for the front galley (kitchen area) and I will chopping the back half roof off and building a wooden cabin-esque loft IMO the weirder looking the better!
09-16-2016, 12:40 AM
#40
Coachwork: Corbeil - RAMROD
Chassis: IH 3800 66 Pass
Engine: 7.3 IH IDI NA w AT545 hyd
Hey dude! Glad you're chugging along with your build. Let me help you out with a ton of advice that I've either gleaned from here or learned from mistakes as I go.
First - get a 60-80 grit flap wheel (10 pack) for your 4.5" grinder. Crappy tire has a sale on or P Auto is your friend. Then it only takes 10 secs a rivet and does a WAY nicer job. Finally you get a steel punch and a hammer and knock them out once you've ground them flush.
COVER all of your windows - so that sparks from grinding don't hit them. I effed up my drivers mirror because I was "watching" my sparks and then forgot when I leaned out of the window a couple back and shot a tirade of sparks forward. Fack!
I've got quite a few other tidbits but that's the best start.
Shoot me a text and we can chat more.
I'd like to take a look at that bus in person - it's pretty sweet.
