Old 05-27-2012, 10:08 PM   #151
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
Re: Ludicrous Speed
All of the window skinning is done! I put in over 520 rivets including reattaching the rub rails... Wow. Rivet tool is getting worn out too, as it popped the rivets in 3 pulls when I started, but by the end it was 6 or 7 and kept slipping.
Ceremonial final rivet ---
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 05-28-2012, 07:15 AM   #152
Re: Ludicrous Speed
Great victory vid
Old 05-28-2012, 11:55 AM   #153
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: Ludicrous Speed
Ha rainbow ,,,when are u going to start on the slides,thats what i want too see i got a 94 bird,but i got belly bays .i have one speace to put a slide.
keith is offline   Reply With Quote
Old 05-28-2012, 08:36 PM   #154
Re: Ludicrous Speed
Don't think I'm going that route LOL! Remind me to try that on my next conversion (yeah right hahahaah)...
-Dan
adjective
Old 06-01-2012, 10:43 PM   #155
Re: Ludicrous Speed
OK, over the last week or so we began working on adding the RV windows and installing a hitch and trailer wiring.
For most of the window install, I used an air nibbler to cut the holes. This tool cuts through the steel pretty fast. Unfortunately, the nibbler, being from harbor freight, was not the most robust of tools. I tended to break the cutter/punch after relatively short cuts. The nibbler was clearly marked to be good up to 16 gauge steel, but the 18 gauge I was using it on proved to be too much. Needless to say, after 4 trips to harbor freight, I decided to just cut the steel with the handy cutoff wheel.
Now for some pics!
I used drill bits of increasing size, so I wouldn't snag and twist the sheet metal when making the hole for the nibbler.
The nibbler would get a great start from one of these holes.
There is a hole in my bus again! This appears to be a recurring theme!
-Dan
adjective
Old 06-01-2012, 10:52 PM   #156
Re: Ludicrous Speed
I used the same rope caulk for the windows that I used on the door install. After securing a bead of caulk around the window frame, I clamped the window into the hole, with a 2x2 on each of the sides. I then screwed the frame to the sheet metal of the bus (and on through into the wood) with stainless steel self-drilling screws. Once the window is fully attached, it makes the sheet metal feel much more solid.
I used welding vise grip style clamps to hold the window in place.
The heads of the stainless screws were 5/16" hex head. I used a drill with a 5/16" nut driver attachment to drive them.
One of 4 windows that I have installed. I plan on putting in 4 more (kitchen, bathroom, and one in each top bunk), but they will have to wait until after the maiden voyage.
-Dan
adjective
Old 06-01-2012, 11:04 PM   #157
Re: Ludicrous Speed
OH! before I get to the hitch install, I realize I left out the pics of the framework we welded in to compensate for the 2 consecutive ribs I removed on either side of the bus. Yes we are aware that it is not as strong as it was when it rolled off the assembly line, but we are doing what we can to retain as much of that original strength as possible.
The steel we used was 11 gauge 1" square tubing.
Once again, my welding buddy, Stretch, taking good care of me ;)
The welds where the frame crossed the ribs that were removed.
-Dan
adjective
Old 06-01-2012, 11:16 PM   #158
Re: Ludicrous Speed
I needed to install a hitch on the bus, as we are going to use it to pull my friend's camper for our trip to Haspin Acres. A few of my friends and I tend to get a little noisy during the nights at this event, and Stretch likes his sleep, so he brings separate sleeping quarters. At first I acquired a hitch from my dad, but after some relatively close inspection, we realized it was too rusted out to trust.
I found this hitch on craigslist for $40. It still has undercoating on it, and the guy let me beat on it with a ball peen hammer to make sure it was not too rusted/soft. It was not the first one the guy showed me, but he happened to have one that fit my frame rails exactly! No cutting and re-welding makes us happy
The hitch is installed! I used grade 8 1/2" bolts with regular and lock washers to secure it to the frame. These were tightened firmly with an impact wrench.
I used a hole saw to cut the hole for the trailer wiring outlet. The bumper on this thing is THICK. I had to repeatedly dunk the hole saw in oil to keep it cutting without dulling/breaking it.
-Dan
adjective
Old 06-01-2012, 11:52 PM   #159
Re: Ludicrous Speed
I ran into a bit of a pickle with the trailer wiring, as the bus is wired for separate brake and turn signals, and trailers are wired to combine these. I could not just tie them together, as it would cause the bus lights to stop functioning properly, and I did not want to do without either the turn signals or the brake lights on the trailer. I could have gone into town, spent the $22 on the easy converter, and had it done no problem. But in grand skoolie fashion, I said "I can do this myself!" since I happened to have a few relays lying around. My first attempt (trying to wing it), I wound up doing nothing but isolating the turn signals, basically mimicking exactly what was already there... D'OH! After scribbling a few schematics on paper, I decided on a better course and was able to get it done correctly.
Note: The oddity with this setup is that when the brakes are applied while the turn signal is on, the turn signal on the trailer blinks out of sync with the bus. Figured some might find that interesting.
The wiring was then soldered to a heavy duty cable with enough leads in it that I could wire the trailer brakes if I so desired (not doing it at this time) and threaded down through the floor inside the wall to the trailer outlet.
I mounted the trailer wiring outlet in the bumper.
While this looks a bit like the proverbial rat's nest, I cleaned it up considerably before closing it back up.
Here is my schematic for those interested who know how to read them. Sorry for anyone who gets a headache trying to read it.
-Dan
adjective
Old 06-02-2012, 06:11 PM   #160
pipopak's Avatar
Re: Ludicrous Speed
Read the regulations about max length RC+ trailer in your state BEFORE sailing out. You don't want to learn about them in the middle of nowhere from some trooper!.
pipopak is offline   Reply With Quote
want just a bit more speed opus International | Navistar Drivetrain 47 03-12-2015 11:03 PM
Replace 5 speed spicer with 7 speed spicer (double O/D) frank-id International | Navistar Drivetrain 2 02-13-2011 07:17 PM
speed putterspitt Short-Bus Conversion Projects 7 12-13-2009 11:30 PM
4 speed + H and L? the_experience03 Conversion General Discussions 4 09-27-2006 12:04 PM
1986 bluebird DT466/5 Speed man/2 speed rear code4 Classifieds | Buy, Sell, Swap 2 08-14-2006 11:29 PM
