Old 05-24-2016, 10:34 PM   #241
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
Next (and to some degree - during) we built the bathroom walls and started the plumbing...
I used cpvc for the in-wall pieces that drop through the floor and pex underneath.
Kitchen sink supply drops... Notice the black pipe plumbing in this pic... propane plumbing in progress as well.
Started framing in the bathroom and cut the *shudder* first and (hopefully) only hole through my roof.
We used some scraps of wallboard to support the FRP in the bathroom.
FRP up on the forward wall... installed a ridiculously large medicine cabinet for the size of the bathroom. Intentionally set up the mirror to open on the right, so the Mrs can open it and do her hair from outside the bathroom.
Completed bathroom (minus door and somewhere for the waste to go, both of which we are working on)
Well, that's enough posting for one night... stay tuned.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 05-25-2016, 12:29 AM   #242
Robin97396's Avatar
That's some pretty cool porcelain you're putting in there.
Old 05-25-2016, 07:40 AM   #243
Thanks! Since it is a shower pan as well as bathroom floor, we figured we needed something fairly waterproof.
-Dan
adjective
Old 06-02-2016, 09:09 AM   #244
I pressure tested the fresh water system yesterday and there was only one minor leak in a very accessible place! Considering there's probably at least 30 connection points, I'll take that any day!
-Dan
adjective
Old 06-02-2016, 04:12 PM   #245
Jolly Roger's Avatar
Engine: Detroit 8.2
Nice work.
It looks like you caulked all of your piping penetrations.
I like to either put a PVC pipe sleeve through the metal or to use rubber tubing (old water hose) on any penetration for rub protection.and then seal everything. Eventually the caulking will/could seperate and then the piping could rub and as thin as my floor metal is (15-guage) it wouldn't take long before I was trying to fix leaks in the worst spots.
Just my opinion and observation?
I have been a pipefitter, plumber for a many a year so to me my piping is secured at every turn, both sides of every penetration, every penetration is sleeved and rubber protected and most of that is because once done? I don't plan on ever looking at it again.
Might be overkill but every preventative measure that can be taken will allow more time before it is a problem. In my mind?
A little late for your build but they do make a brush/roll on waterproofing membrane to go under tile for wet areas and I found some leftover's on a job that I used to help fix my neighbors pool liner with but it was only dog claw punctures but 3-yrs later its still holding.
Old 06-02-2016, 04:35 PM   #246
GreyCoyote's Avatar
Chassis: IH 3800
Engine: Navistar DT466E
Rated Cap: 72 passenger
Schweet!!!!! Awesome build!
Where did you get the bathroom sink? That is EXACTLY what I am looking for and I'd positively kill for it. (Hmmm. Where did you say you lived? Kidding!!!! But please share a link to the sink if you have it).
"You can finally say you have enough horsepower when you leave two black streaks from corner to corner"
(Mark Donohue, famed TransAm driver)
GreyCoyote is offline   Reply With Quote
Old 06-03-2016, 09:21 AM   #247
I fixed my leak... believe it or not, I forgot to crimp the pex ring at that connection. I guess 29ish out of 30ish ain't too bad.
@ Jolly Roger
The pvc coming down through the floor shouldn't be able to contact the edges, as it is short (< 2 foot?) and affixed to the wall, so the caulk is more for anti critter/water entry than avoiding rubs.
@ GreyCoyote
The sink was salvaged from my old motorhome before I scrapped it out. Tiny, but functional!
-Dan
adjective
Old 06-03-2016, 10:06 AM   #248
Rated Cap: Your mom +1
One thing I've learned is never underestimate the power of road vibrations... you might be surprised how much everything moves around at 55 mph...
want just a bit more speed opus International | Navistar Drivetrain 49 02-02-2021 04:09 PM
Replace 5 speed spicer with 7 speed spicer (double O/D) frank-id International | Navistar Drivetrain 2 02-13-2011 07:17 PM
speed putterspitt Short-Bus Conversion Projects 7 12-13-2009 11:30 PM
4 speed + H and L? the_experience03 Conversion General Discussions 4 09-27-2006 12:04 PM
1986 bluebird DT466/5 Speed man/2 speed rear code4 Classifieds | Buy, Sell, Swap 2 08-14-2006 11:29 PM
