Old 07-19-2015, 12:05 AM   #221
Chassis: Blue Bird
Engine: ISC 8.3
Since it wasn't clear what sequence or combination of connections were done, here's a note about them: soldering is a great way to join wires. However, don't use solder followed by mechanical joining (crimp/screw/clamp/etc). This can be especially tempting when crimping terminals to the end of a conductor. If ever anything causes that joint to get warm, such as a screw working loose on a ring terminal, then the solder will soften, which makes the mechanical connection more loose, it then produces more heat... things can go downhill fast. The well-done mechanical-only joint would have heated, but without solder going soft and creating a loose connection in the compressed area, the heating would be better limited.
Old 07-19-2015, 07:43 AM   #222
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
I generally appreciate advice, so thank you.
I will, however, respectfully disagree based on my experience in mobile electronics. Solder is not, and never has been, intended as a binding agent. It is merely a tool to improve conduction and MUST be supported with some kind of mechanical connection, particularly in a mobile environment. If not it will work harden and crack, causing a bad connection.
Not soldering, however, is a great way to create the exact heat situation you are describing. I can't count the number of times I've dealt with non-soldered shoddy workmanship that makes for intermittent connections and unnecessary heat. That is the stick and staple (and redneck radio and amp install) way and the whole reason wire nuts in S/S campers are melted half the time.
So, to clarify my connection method -
I twist the stranded wire together.
Heat the connection, applying solder until it wicks into the wire and evenly coats the wires being joined.
Cap it with a wire nut.
Tape the connection starting with the wire nut, winding down around the wires, pulling them tight together below the nut, and winding back over the nut so the tape pulls the wire nut in both directions.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 07-19-2015, 08:05 AM   #223
Yep^ I agree.
Old 07-19-2015, 11:16 AM   #224
That's how it was 'splained to me.
Old 07-19-2015, 04:17 PM   #225
Chassis: Blue Bird
Engine: ISC 8.3
To start with the common ground: I'm glad we all agree that the Scotchlok quick splice is an abomination. Even if it is made by 3M!
It seems that our thoughts have somewhat passed each other. The scenario I meant to discourage is one like the following: a single stranded conductor tinned then inserted to some mechanical terminal. Maybe crimped into a ring or spade terminal, maybe inserted to a terminal block or placed under a screw, etc. Generally, such technique supposes that the tinned stranded wire is equivalent to a solid wire. The trouble there is that the solder adds bulk, but it is soft. It can deform until what was once a firm connection becomes loose. I would view individually/separately tinned and subsequently wire-nutted conductors the same way.
The above becomes a very different scenario if the crimp is done first and solder applied second. IMHO that makes for a reliable joint, especially since most of us would be working with crimp tools that lack the perfect die for the particular wire and terminal and so the crimp isn't the best.
Your method is different from the above (thanks for sharing it in more detail!). Because the conductors are twisted and soldered together, not merely tinned separately, and with the added bonus of a wire nut exerting some spring compression on the joint, it sounds like a very secure connection.
I confess: I didn't quite understand the part about the tape pulling the wire nut in both directions. Does that mean toward and away from the conductors (axially)? Or does it mean in a twisting direction, to ensure the tension on the stretched tape isn't working to unscrew the wire nut..?
Is there a reason why you wouldn't use shrink tube? I don't recall ever finding something that had been taped years earlier and thinking "wow, this tape is in great shape!" It seems that with time and temperature the adhesive always goes gooey and slippery and the tape loosens. I haven't seen that yet with shrink tube, especially the adhesive-lined or thick-walled types.
Old 07-19-2015, 04:30 PM   #226
The tape going both ways on the wire nut is to keep it from twisting either way.
Shrink tube is nice.
I only use 3m super33 tape for wiring. It stays put and stays pliable.
Old 07-19-2015, 07:59 PM   #227
Dude,
You come on here and haven't even said high in like years
Hope all is good, I actually started LaTortuga last night...felt good...must hit the road
What you "been do'in' Willis"?
Old 07-19-2015, 09:41 PM   #228
Work mostly. Church softball league, kids functions, etc... But mostly, I work at a computer all day and never feel like getting online once I'm home. I'll try to be less of a stranger in the future.
Congrats on getting started on the 'tuga! Hope everything goes as smoothly as it has for me.
Old 03-01-2016, 03:50 PM   #229
Work is ramping back up on Ludicrous Speed!
On tap between now and multiple summer trips:
Bathroom construction
Fresh water tanks and supply
waste water tanks
Proper Propane plumbing for range
12V lighting for kitchen and bathroom
Cabinet with doors over sink
Cabinet doors on pantry
Generator and related
Lets see how far we get this year!
-Dan
adjective
Old 03-05-2016, 05:44 PM   #230
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Are you going to use PEX tubing on your water set up? Id recomend it, even though I haven't started on my Skoolie yet, I have re-plumbed a new shower and icemaker line in the main bathroom in my house, along with the "Sharkbite" compression fittings, that stuff is absolutely amazing!
The compression fittings are a little pricey but so are the ring and barbed fittings for pex tubing. Not to mention the crimping tool you will most likely use for this project alone! I found a 30' section of used pex with fittings in it in a RV salvage yard it had about 25 fittings on it including the water valves for the sinks and shower. Soaked'em in vinegar to get the old calcium off, and pow, $100 worth of fittings for $20!
Looking forward to more pics and posts!
-Doc
My build thread - viewtopic.php?f=9&t=467197
want just a bit more speed opus International | Navistar Drivetrain 47 03-13-2015 12:03 AM
Replace 5 speed spicer with 7 speed spicer (double O/D) frank-id International | Navistar Drivetrain 2 02-13-2011 08:17 PM
speed putterspitt Short-Bus Conversion Projects 7 12-14-2009 12:30 AM
4 speed + H and L? the_experience03 Conversion General Discussions 4 09-27-2006 01:04 PM
1986 bluebird DT466/5 Speed man/2 speed rear code4 Classifieds | Buy, Sell, Swap 2 08-15-2006 12:29 AM
