04-11-2012, 10:37 PM
#81
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
Re: Ludicrous Speed
My homemade "tire-hole-maker picker upper"
The booty acquired with said machine...
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
04-11-2012, 10:40 PM
#82
Re: Ludicrous Speed
...and the Coup de Grace! Video of flattening what was left!
http://youtu.be/AdWjR43XEnQ
-Dan
adjective
04-12-2012, 07:05 AM
#83
Re: Ludicrous Speed
Originally Posted by TheRainbowBoxer
I was dissapointed ....I wanted to see you driving something over it
04-12-2012, 09:07 AM
#84
Re: Ludicrous Speed
Demo-ing a stick & staple gives one a new appreciation for how well built the average Skoolie is, doesn't it?
04-12-2012, 09:32 AM
#85
Re: Ludicrous Speed
It sure does... with a stick and staple, particularly with a little water damage, its amazing that it holds together even going down the road.
-Dan
adjective
04-12-2012, 09:39 AM
#86
Re: Ludicrous Speed
reminds me of when i tore a camper apart. heck so much is connected to this and connected to that that there isnt a whole heck of allot you can salvage sometimes!!
sold trailer frame to sis' bf and he flipped the axles and made a quad trailer out of it. if you put a deck on it you pretty much triple the value of resale lol
04-14-2012, 10:22 PM
#87
Re: Ludicrous Speed
Today we embarked on the scariest part of the conversion to date. Drum roll please...
We made a big hole in the side of the bus!
My friend, Dennis, drilled out the screws holding the hinges in place after attempts to remove them the normal way failed.
The emergency door came out without much further trouble.
Pulling down the wiring chase above the emergency door.
More to come...
-Dan
adjective
04-14-2012, 10:27 PM
#88
Re: Ludicrous Speed
The air chisel made short work of the rivets...
...and more rivets...
...did I mention my bluebird has a few rivets?
-Dan
adjective
04-14-2012, 10:34 PM
#89
Re: Ludicrous Speed
I cut the rub rails back using a die grinder with a cutoff wheel.
I used the air chisel to pop the mostly cut piece of rub rail off.
It was time to start cutting the rough opening out. First I tried cutting using a sawzall... I was making progress at the rate of about an inch every 15 minutes. I needed to find a better way.
-Dan
adjective
04-14-2012, 10:40 PM
#90
Re: Ludicrous Speed
Due to mother nature being unkind, we backed the bus into the pole barn. The way I found worked best for cutting out the rough opening was to put a cutoff wheel on a electric angle grinder. Thanks to Dennis for building an adapter to make use of the cutoff wheels.
Half of the door frame is loose!
Door Frame out!
-Dan
adjective
04-14-2012, 10:44 PM
#91
Re: Ludicrous Speed
Door frame, removed.
Got the hole for the stairwell cut out and that was it for the night.
Thanks to my goofy photographer, Joe, for this recent series.
-Dan
adjective
04-15-2012, 09:11 AM
#92
Re: Ludicrous Speed
that is sorta what i did when i put the rv door about 3 feet ahead of the rear wheels.. left the emergency door on the other side. mine - i put the door where i could use part of the back compartment for the bottom step. also put a rv door where the original steps were for the generator.
04-15-2012, 11:04 AM
#93
Re: Ludicrous Speed
Lookin' Good Guys! --- I have to admit I have recently become really jealous of anyone with a "square" bus...i.e.;...one with nice, straight walls. My shorty has a very slight inward curve (so slight I didn't even notice until I started de-constructing things) that makes everything many times more difficult to deal with. I just started over on my front door. Not only do I have to accommodate the curve, but the front edge is straight...only the back edge has the arch. And it isn't a nice, neat rectangle...nooooo...it has a slope part way up that follows the windshield. I tossed my first try at a workable frame and have just begun another attempt. Arrrggghhh! I need someone with old fashioned boat building skills to help out on this one.
04-15-2012, 08:59 PM
#94
Re: Ludicrous Speed
@ Tango
We have been extremely lucky on this door installation so far. The frame pieces are the perfect width for our chosen door, and we only had to remove one of the overhead braces to get it to fit. Everything just seemed to line up. *Knocking on wood furiously*
-Dan
adjective
04-15-2012, 09:54 PM
#95
Re: Ludicrous Speed
We have been working on possible color schemes, and have narrowed it down (probably) to one of these three. Opinions?
-Dan
adjective
04-15-2012, 11:04 PM
#96
Rated Cap: 89
Re: Ludicrous Speed
Top one reminds me of the paint on our bus when we got it (same colours). I don't care for the bottom one at all. Too much white.
04-16-2012, 05:23 AM
#97
Engine: Detroit
Re: Ludicrous Speed
All of them look great, but I'd hate to have to keep the last one clean!
The green is cool. Would look great in a campground. Where are you getting your paint, and what kind have you settled on using?
04-16-2012, 06:15 AM
#98
Re: Ludicrous Speed
We were kind of blah about the last one as well.
We will probably use rustoleum for the paint.
-Dan
adjective
04-16-2012, 10:20 AM
#99
Re: Ludicrous Speed
the thomas busses have a slight inward tilt toward the top and are not totally straight.. top is in around 2 inches narrower than belt line.
i like the top bus pic..
04-16-2012, 01:32 PM
#100
Engine: DT466/AT545
Re: Ludicrous Speed
At first glance, the top one appeals to me the most. Ironic since I'm going with a white & green theme myself.
