Old 05-24-2012, 07:55 PM   #1
opus's Avatar
Chassis: All-American R/E
Luggage racks
I THINK I might be looking for a section or 2 of the above seat luggage racks from a Blue Bird. Has anyone got any that they took out?
Old 05-25-2012, 08:52 AM   #2
Re: Luggage racks
it might be easier to get the luggage rack from a transit. should be the same, and there are lots of those in the wrecking yards.
Old 05-25-2012, 08:58 AM   #3
opus's Avatar
Re: Luggage racks
I was looking for a OEM bolt in. This had them in it at one time. There are no wrecking yards here within 100's of miles. Someone here had them a while ago, I forget who though. :/
Old 05-25-2012, 09:32 AM   #4
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Re: Luggage racks
Is this what you are looking for?
I still have most of it, although I did cut it in a few places to get it out. Not sure how you would get it though.
From a 91 Bluebird All American RE
Free if you want them. I have used a few bits and pieces for other things.
Old 05-25-2012, 09:47 AM   #5
opus's Avatar
Re: Luggage racks
Thats it. How long is a section and could you use just one section and have it hang structurally sound? In other words, is there a hangar at each section end? She is wanting a shelf over a table are and I was thinking that would be the best way to do it. Not sure SHE is thinking that, but............
Old 05-25-2012, 10:22 AM   #6
Chassis: AARE
Re: Luggage racks
Here's a better picture of the details. This is the end, note the upright bracket between each window, has a screw top and bottom into rib. The rack bottom is aluminum tube that goes through the inner brackets and just into the ends. I haven't tried, but assume that brackets will slide off of the tubes. Spacing is whatever the window (or rib) spacing is mine are 28 or 32, not all windows are the same size,nor are the ribs spaced evenly. Padded part is just some cheap particle board covered with foam and vinyl, I wouldn't think you would need that, I assume your interior is something other than school bus brown.
Old 05-25-2012, 10:35 AM   #7
opus's Avatar
Re: Luggage racks
I have the brackets on the windows already. I have the holes in the ceiling as well. How long is a section? Just thinking, but if I got a couple sections, I could always cut ends off and weld them together. As far as me getting them, I would surely pay shipping if I do this. You could tape a couple together and stick a label on it, no box necessary.
Still thinking out loud here......
Old 05-25-2012, 10:48 AM   #8
Chassis: AARE
Re: Luggage racks
From what I can tell the aluminum tubing is full length, I cut it into more manageable lengths, I'll have to see if it can be knocked apart. So, you would need a pair of ends, and however many middle sections, plus aluminum tubes to adequately. cover the length?. I don't think the box would have to be very big, not sure about shipping without a box. I'll have to check on getting them to pick up here, round trip to them would be about 70 miles.
Old 05-25-2012, 11:23 AM   #9
opus's Avatar
Re: Luggage racks
UPS or FedEx doesnt pick up at your home? Maybe its a living in the middle of nowhere thing here. I just call them and they come here. Dont do anything yet, still checking things. I need to go measure widths and lengths as well.
Old 05-31-2012, 03:34 PM   #10
opus's Avatar
Re: Luggage racks
Ok, here is what I would need. I need enough to cover 2 windows. Just like your last picture above. Whatcha think?
Roof Racks Gearhead94 Conversion General Discussions 2 04-25-2013 10:53 PM
luggage rack / rooftop storage Atridox Conversion General Discussions 1 04-02-2010 09:48 AM
Roof Racks kirkndopp Skoolie Conversion Projects 2 08-03-2009 08:25 PM
How To: Racks (Roof and Rear) fightingsiouxbus Conversion Tutorials and How-to's 4 08-09-2008 10:48 PM
Roof Racks/Party Platforms Steve Conversion General Discussions 12 07-19-2005 01:04 AM
