Old 12-17-2019, 10:25 PM   #1
Chassis: AmTran RE
Rated Cap: 74
Makai the skoolie
Started this build in June of 2018. I raised the roof 18" and I am so glad I did.
Jaynvona is offline   Reply With Quote
Old 12-17-2019, 10:34 PM   #2
Chassis: AmTran RE
Rated Cap: 74
Dropped the ceiling 6" for ac duct work and raised the bedroom and bath room floor to clear wheel wells and run water/waste.
Old 12-17-2019, 10:39 PM   #3
Interesting approach.
Is this bus mostly stationary or will you be putting a lot of miles on it?
The metal-work transition looks smooth from the front to the raise -- I like it.
Old 12-17-2019, 10:44 PM   #4
Chassis: AmTran RE
Rated Cap: 74
Framed bed and headboard. Closed rear window because I failed to secure it and the glass did not withstand the fall. LOL
Old 12-17-2019, 10:45 PM   #5
Chassis: AmTran RE
Rated Cap: 74
Thanks Banman.
It will be on the road. The transition was a challenge but I think it turned out well.
Old 12-17-2019, 10:52 PM   #6
Chassis: AmTran RE
Rated Cap: 74
Working out shower pan placement and drain.
Old 12-17-2019, 10:58 PM   #7
Chassis: AmTran RE
Rated Cap: 74
Water heater installed and water lines pressure tested. AC ducting in ceiling and wiring for led lights.
Old 12-17-2019, 11:01 PM   #8
Chassis: AmTran RE
Rated Cap: 74
Battery storage, dc power fuse block, and pre-wired to the roof for solar. Still need 2 more batteries when the budget allows.
Old 12-17-2019, 11:05 PM   #9
Chassis: AmTran RE
Rated Cap: 74
Finished shower and vanity. Love the 32x32 pan. Lifetime vinyl plank on the bathroom floor. Cabinet/wardrobe going in the open corner.
Old 12-17-2019, 11:09 PM   #10
Chassis: AmTran RE
Rated Cap: 74
Kitchen cabinets installed and counter tops ready to attach.
