Old 01-14-2019, 04:08 PM   #111
nanoplane's Avatar
Chassis: MVP
Engine: 8.3L Cummins Turbo
Looking awesome!!
Can you tell us more about the material and where you found it?
Thanks.
The material is Knotty Pine beaded planks from Home Depot
https://www.homedepot.com/p/8-ft-x-4...EPOT/202536000
I used 3/4" self drilling stainless wafer head screws:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
--Marcel
Build Thread
nanoplane is offline   Reply With Quote
Old 01-14-2019, 05:09 PM   #112
Thank you!!
That is one of the best looking ceilings I have seen so far.
I am likely to borrow your method & material.
Old 01-15-2019, 10:44 AM   #113
nanoplane's Avatar
Chassis: MVP
Ceiling
Some additional notes:
- I think if I had to do it over, I would start with the "special" piece in the middle (tongues on both sides) and work out from the center of the ceiling down.. the hard part is figuring out how big that center piece should be to not wind up with tiny chunks at the bottom.
- Installing the strip lights required some thought.. I cut out a 1" part of the groove side of the plank to fit the lighting strips, then cut back the rear of each end of that slot to allow for the wires. I then glued small pieces of sheet metal (2" x 3") to the back side of the plank at the center and near each end of the cutout to give me a place to screw the clips that hold the aluminum channel that holds the lighting strip. This metal also extends slightly beyond the edge of the plank to act as additional support for the next plank (since there isn't a tongue and groove match any more where the light strip is.. An alternative would have been to cut the slot in the middle of the plank, but I figured that might weaken the plank too much.
- Even though I was using self drilling screws, I found it easier to pre-drill for each screw location.
--Marcel
Build Thread
Old 01-16-2019, 11:32 AM   #114
shaymcquaid's Avatar
Chassis: 40' MVP-ER
Amazing Bus. Congrats! I'm sure jelly of your solar!!!
shaymcquaid is offline   Reply With Quote
Old 01-17-2019, 05:42 PM   #115
nanoplane's Avatar
Chassis: MVP
Thanks, It's a bit of work..
--Marcel
Build Thread
Old 01-25-2019, 07:11 PM   #116
nanoplane's Avatar
Chassis: MVP
Inside wall panels
Panels (1/4" birch plywood) are done for the inside walls. Nailed to the slats and studs using 3/4" brad nails. Then everything masked and the panels sprayed with water based satin polyurethane (General Finishes High Performance Water Based finish). I really like this poly since it's extremely stable over time and doesn't really separate, even after a year or so.
--Marcel
Build Thread
Old 01-29-2019, 02:54 PM   #117
nanoplane's Avatar
Chassis: MVP
Duct
I wanted air circulation in the bus so I'm installing a duct that goes from the bedroom to the front of the bus on the driver's side. Only issue is that the bathroom is there and I didn't want the duct to interfere... So, I've fabricated a shallow (1-1/2" x 5") duct that fits in the wall, and two rectangular to round offset adapters on each end.
Here's the duct installed:
Did the design in autodesk Inventor using their "sheet Metal" option that lets you do a 3D design and then it flattens it to a pattern..
And Here's the pattern:
Bending it on the mag Brake:
The completed offset adapter:
Assembled:
--Marcel
Build Thread
