Old 04-15-2018, 06:56 PM   #41
Chassis: Saf-T-Liner MVP ER
Originally Posted by nanoplane View Post
I plan on traveling all over.. I'm planning on only 9000 BTU for my bus (10000 heating).. it's less than 300 square feet of space that needs heating/cooling.
... and it needs about 4 x the amount of heating and cooling that most calculators suggest, especially in hot summers or cold winters.
Steve Bracken
Build Thread
Old 04-15-2018, 07:43 PM   #42
Insulating panels or hanging heavy blankets to shrink the space cooled, plus of course solid insulation to start with.
Windows are deadly!
john61ct is online now   Reply With Quote
Old 04-16-2018, 11:52 AM   #43
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
Windows are deadly!
I have seen people plan TWO 15k BTU units front and back for AC for a 40' bus in AZ. I think. It's been a while now. I have a portable one that is supposed to be enough for that sized room and will certainly be enough for the bedroom at night only. And then it could do the living area during the day probably, but it's only designed to lower the temp so much -msybe 20 degrees and if it's 100 then 80 is better but not good enough for me probably. And then I still have to figure out AC and heat for while driving!!! So far I just drove with a lot of layers and gloves on!
2martins is offline   Reply With Quote
Old 05-02-2018, 02:14 PM   #44
nanoplane's Avatar
Chassis: MVP
Engine: 8.3L Cummins Turbo
Solar updates
Solar panels are all installed:
Each panel has some 1/8" thick weatherstripping on the bottom to provide a little space between the panel and the roof.. slightly better cooling.. probably only when driving down the highway
The panels are connected in parallel for each of the 8 "rows" some with two and some with three panels. Each Row is routed back to a terminal strip in the back of the bus where I can implement a parallel or serial/parallel configuration.. or experiment.
Wiring to the farthest 4 rows of panels is 8# copper wire. The near 4 rows are 10# copper wire.
nanoplane is offline   Reply With Quote
Old 05-14-2018, 11:51 AM   #45
nanoplane's Avatar
Chassis: MVP
Solar System Circuit
Here is the circuit diagram for the solar system / chargers / inverter...
There are 8 "rows" of solar panels, from the front of the bus, 2 rows of 2 panels, then 4 rows of 3 panels then another 2 rows of 2 panels.
Each row is connected in parallel at the panels then pairs of "matching" rows are connected in series at the terminal blocks and then those in turn connected in series to create two arrays, each having 10 panels with an open circuit voltage of about 40V. Each of these arrays route to a Midnite Solar charge controller and then to the Battery Array (12V, up to 880AH / 10kW).
The Inverter is an AIMS 3000 W nominal/9000 W peak device. It also supports battery charging at 140A when connected to shore power. It has automatic shutoff when the battery voltage gets too low.
--Marcel
Build Thread
Old 05-14-2018, 11:57 AM   #46
nanoplane's Avatar
Chassis: MVP
Solar Power
So far, the installation looks like this:
... almost there
--Marcel
Build Thread
Old 05-14-2018, 07:10 PM   #47
That's a clean install and those freaking huge dozer batteries should run the freakin' town next door.
ben2go is offline   Reply With Quote
Old 05-14-2018, 07:16 PM   #48
nanoplane's Avatar
Chassis: MVP
Smile Big Batteries...
I'm not too sure about that, but I could probably replace my house backup generator with the bus...
--Marcel
Build Thread
Old 05-15-2018, 03:36 PM   #49
nanoplane's Avatar
Chassis: MVP
We have Power !!!
Basic power is ON
Here's the final installation,
Now I just need to add the AC/DC distribution panel and all the rest
--Marcel
Build Thread
Old 05-15-2018, 03:49 PM   #50
Rovobay's Avatar
Rated Cap: 35
impressive setup. I loathe working on electronics. I wish I didn't but I do. I was going to attempt to strip all unnecessary wires from my bus but feared doing damage.
My Build: http://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 05-15-2018, 05:59 PM   #51
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
That is a great looking setup. I really like how clean it is. I have a similar set up to yours that I haven't installed yet. I think I may order a couple of more busbars.
Nick
Old 05-15-2018, 06:13 PM   #52
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Very nice wiring job! I worked at Car Toys for a decade doing aftermarket installs and that looks like it was done by a pro. A lot of people i worked with in the company couldn't even do it that clean to be honest, lol.
https://www.skoolie.net/forums/f11/n...tml#post256987
My build thread - Started 3.2.18
jjhwick119 is offline   Reply With Quote
Old 05-15-2018, 06:35 PM   #53
When I have a job like this I turn the vehicle on and all accessories on, then start cutting wires one at a time. If cutting one shuts something down or changes the sound of normal, I reconnect that wire and proceed on.
o1marc is online now   Reply With Quote
Old 05-15-2018, 07:38 PM   #54
nanoplane's Avatar
Chassis: MVP
I made most of my Busbars.. 3/16" x 1" copper flat bar and some plastic and stainless flathead bolts and flange nuts...
--Marcel
Build Thread
Old 05-24-2018, 10:25 PM   #55
nanoplane's Avatar
Chassis: MVP
Solar Updates
Ok, I've done the whole power system "backend"
added the AC distribution panel, sensors connections and negative to chassis... Which was "interesting"...
I had connected everything except the ground to chassis and when I added that last green wire (at the bottom center...), there was an interesting result...
Things you learn... when screwing Busbars to plywood, don't use screws that will be longer than the depth of the plywood.... They can touch metal (in this case, foil tape) and when you suddenly add the ground line... if the long screws were on the positive busbars.... you get a very large spark... enough to melt some of the copper in the ground wire AND blow away a bit of the Aluminum Tape...
... Screws Replaced....
At the top of the plywood you can see my wiring trays... these are segmented trays, 1 part for AC one part for DC...
The caps for the trays are made from some of the ceiling perf metal..
--Marcel
Build Thread
Old 05-24-2018, 10:34 PM   #56
nanoplane's Avatar
Chassis: MVP
Removing the Extra Door..
I decided my bathroom needed to be where the driver's side emergency door was.. so it had to go... It did not go easily... Well, the door went fine, the frame was a real pain... The top part is riveted into the seam for the rain drip tray... so I had to cut it free with cutting wheels.. But, now it's gone and in it's place will be a panel, with a tiny window (my SO insisted we have a window in the bathroom)..
Here's the current state... Lower panel in place... need to create the upper frame to match the structure and hold the tiny window. I am also getting some bumper rail to match the existing.
note: I created the tiny window by cutting down one of the old windows that isn't being used... Score both sides of the safety glass.. trim and drill the frame bits to match...
--Marcel
Build Thread
Old 05-24-2018, 10:42 PM   #57
I have the same door delete planned for mine, thanks for the experience and pics. Be glad it wasn't a wheelchair door that protrudes into the roof skin.
Old 05-24-2018, 10:52 PM   #58
oricha1984's Avatar
Engine: gasser probably
that is some serious money spent on a solar set up.
looks good, gratz!
oricha1984 is offline   Reply With Quote
Old 05-25-2018, 01:02 AM   #59
nanoplane's Avatar
Chassis: MVP
looks good, gratz!
About $6k so far. Not too serious
Old 05-31-2018, 04:41 PM   #60
nanoplane's Avatar
Chassis: MVP
Door be Gone
So.. just apply a little DoorBeGone and ... voila:
I tried to match the "patterns as much as I could.. almost successful .
on the inside, I'm insulating and covering the "hole" with sheet metal and then once I add the interior framing, there will be more insulation and yet-another-wall..
--Marcel
Build Thread
