Old 04-19-2010, 10:36 PM   #1
Josef's Avatar
MegaBus project
Hi all, Iím going to try take more pictures and post more here Ö anyhow, probably will change my name to megabus after my daughter Megan Ö I donít think thatís been used here yet.
Below are some pictures added to Picasa I will add comments to them soon.
http://picasaweb.google.com/11571894521 ... usProject#
Some of the photos are of:
Removed/Skinned windows
Removed old floor
Resealed emergency hatches
Installed Vantech floor
Removed rear heater
120 volt / 12 volt wiring
Some over all pics / engine pics
My bus is a 1997 Thomas DT466E 65 pass / dog nose.
Thanks!
Joe!
Conversion photos viewable at:
http://picasaweb.google.com/js6011980
Josef is offline   Reply With Quote
Old 04-20-2010, 08:28 AM   #2
Josef's Avatar
Re: MegaBus project
Thanks Smitty!
I'll be using for weekend camping trips, hunting, etc ...
Here are some Sketchup models (added more to the albumn), I can upload the actual sketchup file if anyone is interested ... if there is room for it. I think it's about 8MB. I think this is about all the more detailed I am going to get on my model/plans. I might draw the the table/chair/soffa component though. Who knows!
Thanks again!
Old 04-20-2010, 09:14 PM   #3
Josef's Avatar
Re: MegaBus project
Yes, to the right (toward front) of the bathroom will be 22x48 rv window, sink, and burner. Opposite side will be another matching window and a pop-up camper style table and bench seats that convert to another bed. Under the AC will be a drip pan, under that will be LP suburban furnace and an electric water heater. To the right of AC will be the coverter/city svc.
I have a Subruban water 5 gal LP/120V water heater, but the place where the anode rod goes in is super duper rusted out, I was blowing it out, and got a bunch of blue glass fragments coming out with dirt and other stuff. Seems in pretty rough shape, so I dont think it's worth cutting a hole in the wall to mount it. I think a 5 gal electric would be fine for weekend trips anyhow.
Planning to put in an external shower access somewhere in that general area too.
Thanks!
Old 04-20-2010, 09:24 PM   #4
Josef's Avatar
Re: MegaBus project
On another note ... A couple times I have hit the ignition key and I just get a single click noise (maybe 1 in every 20 start attempts) then I try again and it cranks as expected and starts right up. Should I be overly concerned the starter is going out? I doubt that is normal.
Yet another question.... I took the fuse out for the buzzer for when the door or something is open, but now I'm wondering is that the same buzzer that sounds of when something fails .. like a brake sensor or something else? or are they typically different buzzers?
Old 04-21-2010, 06:47 AM   #5
busdriver_phil's Avatar
Coachwork: AmTran RE
Re: MegaBus project
They're different buzzers. I assume you removed the one behind the switch panel under the driver's window. That's part of the body wiring, which is separate from the chassis wiring (all behind the front dashboard). The buzzer for chassis stuff (engine warning, brakes, etc) is behind your gauges.
The conversion of Miss Euphegenia, a 1999 AmTran RE: http://www.skoolie.net/forum/viewtopic.php?f=9&t=5704
Old 04-21-2010, 07:31 AM   #6
Josef's Avatar
Re: MegaBus project
Yes, it was the buzzer to the left of the driver seat under the switch plate. Thank you both! Great info!
Old 04-29-2010, 08:58 PM   #7
Josef's Avatar
Re: MegaBus project
Got a couple sheets of luan up!
That's Jake, he is such an awesome helper!
I've got the windows and more luan to go up this weekend if the rain will hold off a little bit!
There are some more pics uploaded at the link in my signature as well!
Thanks!
Old 04-30-2010, 07:18 PM   #8
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Re: MegaBus project
Congrats! Nice bus! And its got the 466! Great engine!
The intermittent starting issue is probably the shifter. Whenever it does not want to start, wiggle the gear shift a little. It has to be in neutral to start. And those can be very finicky.
BUSBOZO is offline   Reply With Quote
Old 04-30-2010, 11:14 PM   #9
Josef's Avatar
Re: MegaBus project
Thanks! I'll pay attention to that next time it happens!
Old 06-17-2010, 10:44 PM   #10
Josef's Avatar
Re: MegaBus project
Hi everyone, been a while since I posted, keeping busy with work, bus, life, and everything else ...
Some photos of progress since the last post ...
Electric and Ext Shower
Master bunk, and Megan's bunk below ...
Me and my Megalope ....
Wife & half a bunk wall ...
AC # 1 framed in and 55 amp power converter & electric panel 30 amp svc
Driver side Window cut out ...
Framed and insulated
Paneled
Installed
Outside view of passenger side window
More walls and paneling
Top bunk bed
Bottom bunk with Lid opened
There are quite a few more pics added. They are in the same album .... in my signature ....
I have been slacking on the photo-taking.
We have completed two camping trips without incident ... one to Clearwater Lake and another to Sam A Baker state park, both in Missouri, at just under 200 miles each, One trip I averaged 7.4 mpg, the next I averaged 9.5 mpg. I averaged 10 mpg from kansas city to Festus (45 min south of St. Louis) when I bought the bus.
First Project salee05 Skoolie Conversion Projects 0 09-02-2009 10:25 PM
My bus Project With a new name.... Kirbystud Skoolie Conversion Projects 12 08-20-2009 10:55 AM
New project...need some help the_experience03 Everything Else | General Skoolie Discussions 4 08-13-2007 04:58 PM
My new project...maybe lapeer20m Everything Else | General Skoolie Discussions 9 04-17-2006 08:03 PM
Trade 1970 VW Karmann Ghia project for skoolie project bus? shortwaverunner Classifieds | Buy, Sell, Swap 3 02-03-2006 09:56 AM
