06-19-2019, 06:34 PM
Year: 1980
Coachwork: Blue bird
Chassis: Chevy254
Engine: Chevy 350 Allison At543
Mista Bus roof raise
16” roof raise
08-16-2019, 09:16 AM
Year: 1980
Chassis: Chevy254
Awnings
Got the awning back on today now it’s time to clean it.
08-16-2019, 09:43 AM
Originally Posted by Mista Bus
16” roof raise
I really like that roof transition!!!
Nice job!
Got any more pics on that transition work?
08-16-2019, 11:24 AM
Year: 1980
Chassis: Chevy254
Transition
I do here are a few pictures, there is a gallon of bondo on it as well
08-16-2019, 11:28 AM
Year: 1980
Chassis: Chevy254
This is what it looks like now it still needs some body work and another coat of paint
08-16-2019, 12:17 PM
Nice work, and I love the nickname. I assume it's a play on "Mr. Bus" and "Missed the Bus"?
08-16-2019, 12:25 PM
Year: 1980
Chassis: Chevy254
Yeah since I raised the roof it got bigger so it became Mr and I work out of town a lot so I miss the bus when I’m not home. And I’d be at the airport when my ship comes in so missing the bus would be the norm
08-16-2019, 01:13 PM
Chassis: All American RE
Engine: 8.3L Cummins ISC
Excellent job! For the front transition, how did you get from the riveted silver panels to the finished white look? Specifically, covering up the rivets? Bondo?
08-16-2019, 01:23 PM
Year: 1980
Chassis: Chevy254
Transition
It was a lot of sanding like floating sheet rock but you have to be quick
08-16-2019, 01:24 PM
Awesome - thanks for the additional pics, that helps a lot.
08-16-2019, 01:30 PM
Year: 1980
Chassis: Chevy254
Bondo is awesome
Bondo the fix it all. Lights moved to the bumper
08-16-2019, 01:52 PM
Year: 1980
Chassis: Chevy254
Bondo
Bondo is awesome check out the rear light removal and patch work with bondo I just cut the patch steel 1/8 smaller than the hole screwed it off with self tapping screws and grind the heads off and bondo
08-16-2019, 02:34 PM
I always thought bondo is like sheet rocking with your boss yelling at you to get the mud up in two minutes.
08-16-2019, 02:41 PM
Year: 1980
Chassis: Chevy254
Yes indeed it’s cooking
08-16-2019, 06:15 PM
Engine: 6-71TA
Rated Cap: 90
You may already be aware of the downside to Plastic filler (aka Bondo) but in case you are not, it can crack and fall off if applied to thick or there is a lot of vibration. Another good alternative to virgin metal is Fiberglass but the resin can be messy.
08-16-2019, 07:03 PM
Year: 1980
Chassis: Chevy254
Yeah I’m sure I’ll be fiberglassing my front cap after I hit a few low limbs
just a guy with a bus.
08-16-2019, 07:36 PM
How thick is too thick? Is it less likely to crack if it's the drillable type (the stuff reinforced with metal bits) and/or has metal mesh underneath? I've done a few spots on my bus and I did them more-or-less sheetrock style with relatively wide, flat patches so it doesn't look bumpy. It looks good now but I have no idea of its durability.
08-16-2019, 07:46 PM
Year: 1980
Chassis: Chevy254
Time will tell. The good thing is when it cracks just bondo it again slap some paint on it and forget it till it cracks again. That the joy of these buses your never done
08-17-2019, 01:59 AM
You know, there is a tool for Bondo that looks like a cheese grater. It lets you shape the Bondo while it is curing. Once it has hardened, the tool is less effective. Speed is the key with Bondo. Once cured, sanding is about all that is left that will remove it. Some spots may take multiple applications to get the contour just right. It sure is fun stuff to work with.
08-17-2019, 09:16 AM
Engine: 6-71TA
Rated Cap: 90
Plastic body fillers are intended for small dings and smoothing out warped panels. It was never intended to fill large dents, rust, or other major body damage.
For a proper repair, you do not want to apply this to anything that is thicker than about a 1/4”. That does not mean it can’t be done, but the repair will not last as long. Eventually, it will shrink and crack or fall off. The general rule of thumb is that if the dent is deeper than 1/8”, you need to do some metal or fiberglass work first.
