Old 05-11-2012, 09:33 PM   #221
Re: 1974 Model 05 Silver Eagle
I have a macerator, I have a garbage disposal, I have a pressure washer-- what the heck is a trash pump? Thanks for edjukatn me
Old 05-12-2012, 10:28 AM   #222
lornaschinske's Avatar
Rated Cap: 89
A macerator.
Fulltime since 2006
Old 05-12-2012, 12:12 PM   #223
Send a message via ICQ to mightybus
Yup.
http://www.harborfreight.com/3-full-tra ... 68370.html
They don't chop chop, but they will pump semi-solids.
official gooberment nomenclature; effluent relocation facilitator mechanism.
mightybus is offline   Reply With Quote
Old 05-12-2012, 12:22 PM   #224
Year: 1974
Coachwork: American eagle
Chassis: Silver Eagle
Engine: Screaming Jimmy 8v-71
Rated Cap: 46
Originally Posted by mightybus
Yup.
I would dig a hole about 2 feet and throw some stone in it. If you had to you could build a incinerator to burn trash and waste water. incinolet builds a toliet or you could make or buy a seperate unit
http://incinolet.com/
"Thunder Bird"
Chadluc is offline   Reply With Quote
Old 05-14-2012, 07:03 AM   #225
I sometimes stay at campgrounds which don't have a dump station, and while there may be one in the area, it is too far to travel or roads are too rough if towing one of those blue tote or turd tanks. My length of stay would require me to empty my holding tanks, but would not be so long that creating a gray water drainage pit or setting up something like a composting or incinerating toilet are worth my trouble. Otherwise, I'd say those are all good options.
For those with macerators, are you filling a waste tank in the back of a pickup truck? If so, what make and model of pump are you using, how much lift/head can it produce? Any other details are welcome.
Thanks,
Christopher
skoolz out is offline   Reply With Quote
Old 05-14-2012, 09:11 AM   #226
i have a harbor freight sump pump that i use when pumping water out of holes i dig to put septic tanks in - if there is water when i get down that far.. i think it would work great to hook up in line after the large garbage disposal unit from the black tank.. (then one could get one of those 250' plastic pipes that attach to this sump pump and run it over to the neighbors field.... )
Old 05-31-2012, 12:57 PM   #227
Year: 1974
Rated Cap: 46
back to the Bus topix..now that I have some free time on my hands,and money rollin in one agian ,I wrote up a wireing diagram.
The system would consit of 4 main parts:
1.Magnum Energy ME-AGS Automatic Generator Start Controllers
http://www.solar-electric.com/maenmeaugest.html
( I would buy the controller , the ME-AGS-N and use remote panel ME-ARC remote.
the reason I would do this, my bus is 100% off grid, and when running the A/C in summer I want the generator to shut off when the A/C shuts off. The ME-arc remote allows me to start and stop the generator based on a few factors including coach temp.
Next part of system:
2. PowerMax 50 Amp Automatic AC Transfer Switch 50 Amp
http://www.solar-electric.com/pmts-50.html
(this is to auto switch from shore power or in my case my inverter or honda eu1000.. Say the honda 1000 is running I'm watching tv. the coach reaches my set temp of 80degree. the controller starts the 4000 watt generatror and this auto transfer switch will switch in 30 seconds from the honda to the 4000 watt generator tuning the A/C on.) follow me?
3. Midnite Solar 60 Amp 240 Volt Dual AC Transfer Switch
http://www.solar-electric.com/miso60amp240.html
(manual switch used to switch from inverter or honda generator)
4. Regulated Battery Charger
http://www.solar-electric.com/bach2.html
So what do you think? could it work? I'll tell you my A/C system design next
"Thunder Bird"
Old 08-27-2012, 09:08 PM   #228
Year: 1974
Rated Cap: 46
Re: Model 05 Silver Eagle
Not to much work on the bus going on. The paint has taken a long time. still trying to shoot it on before i move to the interior /kitchen. still at Prime INC. I'v been to florida to claifornia to upstate NY , and everywhere inbetween . i look forward to getting home to roswell in the next few weeks to try and finish the paint up. I will have 3 days to get her done. I may hire some help to help with taping the windows off etc , i have to get this done.
"Thunder Bird"
Old 11-26-2012, 08:23 AM   #229
Year: 1974
Rated Cap: 46
Not much progress in the last 9 months, been slammin a 10speed all over the country. I nominated myself to work thru christmas so I plan to get back to the bus and do some work the second week in january. if its nice in new mexico and not windy ...I'll shoot some paint, or if its colsd I'll focus on the front and do some work to the kitchen.
"Thunder Bird"
Old 11-26-2012, 08:33 AM   #230
good to hear the job is still working out for you, any new interesting stories
Old 11-26-2012, 12:34 PM   #231
Year: 1974
Rated Cap: 46
I applyed today to pepsi to drive the bay truck making local delivery's in roswell,nm. they are suppose to call me for a phone interview in about 3 hrs.If they are ready to hire me I'll tell um soon as I get the truck thru the terminal and returned to prime I'll be in roswell.they start at 48,000/yr. and your home everynight. I have just over 6 months in with prime. If OTR was hr pay based and not by the mile I would hang around. I worked 70 hrs but on;y made 400. last week becuase I was stuck in jersy city. Until they change the way the OTR company's pay it sucks. get your CDL get Your expirence and after 6 months start appying to local company's. I'm done being alone and crying myself to sleep most nights ..its alot like modern day jail. very structured. u sleep **** drive.
"Thunder Bird"
Old 11-26-2012, 12:41 PM   #232
Year: 1974
Rated Cap: 46
Point blank if your "ON duty" your employer should pay you by the hour. U do tons of work thats on duty like on the dock loged as off duty ...etc. OTR sucks 1 week u make 900. the next 300 and I'm looking for my way out ASAP so if your lucky u may make 1400. u sit in traffic guess what u make nothing. to spend everynight alone in your truck and work like a slave 70 80+hrs is not worth it. drive for 6 months if u can make it that long and start applying to local company's
"Thunder Bird"
Old 11-26-2012, 12:43 PM   #233
Year: 1974
Rated Cap: 46
Thats 1400/for the month
"Thunder Bird"
Old 11-26-2012, 01:07 PM   #234
Sorry had to laugh,I have never seen someone quote themselves and correct themselves...
It'll work out,you have hung in this long!!
Old 11-26-2012, 07:06 PM   #235
Year: 1974
Rated Cap: 46
I'm flying ou tto new mexico for the job interview i was pre qualified and they want me to start as long as the interview goes well. If so I will be bringing prime their truck back so they can groom a fresh student to take it
"Thunder Bird"
Old 11-26-2012, 09:10 PM   #236
Be positive, have done and can do during your interview--we'll all hold a thought and GOOD LUCK! Jack
Old 11-27-2012, 05:36 AM   #237
Year: 1974
Rated Cap: 46
10-4
"Thunder Bird"
Old 11-27-2012, 07:57 AM   #238
GreyEagle's Avatar
Best of Luck on the interview.........
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 11-28-2012, 03:21 PM   #239
Rated Cap: 89
I'll wave at you as you drive past us!
For everyone else's benefit... The Pepsi place in Roswell is across the street from where we are parked.
Fulltime since 2006
Old 11-28-2012, 04:13 PM   #240
travelinwithus's Avatar
Good Luck on the interview!
travelinwithus is offline   Reply With Quote
Project Silver Bullet Booyah45828 Skoolie Conversion Projects 63 05-23-2023 03:50 PM
Help 1984 Eagle Bus Conversion Insurance FL KyVang Titles, Insurance, Registration and Money Matters 0 01-10-2014 05:59 PM
US 180/ NM Hwy 12: Silver City NM - Datil NM (US 60) lornaschinske On the Road | Travel, Trips, Camp Sites, Tailgates 2 04-18-2013 07:40 PM
The Silver Snail... NewSkewlHauler Skoolie Conversion Projects 87 01-28-2012 10:50 PM
1974 Silver Eagle Chadluc Coach Conversion Projects 4 08-07-2011 03:39 PM
