Old 12-28-2013, 01:55 PM   #261
Year: 1974
Coachwork: American eagle
Chassis: Silver Eagle
Engine: Screaming Jimmy 8v-71
Rated Cap: 46
Re: Model 05 Silver Eagle
I hhave not posted in a long time. first off I was in Quartzsite, Arizona for a few months staying off dome rock road on the BLM land while I took a crappy job driving truck from phx to LA with knight refrigerated. we are back in roswell,NM on our private paid for land. the brakes on the eagle our way due for servicing and i had to hold her in second gear down the mountains to make it home. needs new air dryer and chambers.
I built a home generator for the bus out of a 5.5hp honda engine and car alternator. I will get those pics up soon. In short its a high amp regulated charger ,that is simple, robust and fuel efficient. The proublem with a honda EU is that the are very complicated,ultra cheap due to keep weight down, no cast iron sleeve ,chrome or anything in the cylinder,so a little dirt or heavy use and the whole crap unit is junk. I run the honda 5.5hp with a car alternator hookd to a battery with an inverter. The engine runs at an idle as a honda EU but with a robust and commercial grade engineering engine with cast iron sleeve etc, the honda spins car alternator to charge battery bank, the system and run 110v appliances at a gas saving uncomplicated idle.
"Thunder Bird"
Chadluc is offline   Reply With Quote
Old 12-28-2013, 05:55 PM   #262
Welcome home. I like your choice of scenery! And I like the Honda/alternator set up, just wish I had room for one.
Old 12-28-2013, 08:05 PM   #263
LuckyChow's Avatar
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
Good to see you post! I followed your story back when you were with Prime and have been wondering how you are. Do you still have William?
You'll have to post some pics of you gen setup. I've thought about building a setup like yours before, but without bays, it's a lot harder to pull off. At this point, I'm still contemplating what would serve me best.
LuckyChow is offline   Reply With Quote
Old 12-30-2013, 01:38 PM   #264
Year: 1974
Rated Cap: 46
Heres a few pics of our land in roswell,nm and the generator I built. I the past month i built a wall between the cab and kitchen to further more reduce heating costs and create more comfort.like i said a mobile RV or an RV in general is 12V. so why run a 110v generator to convert to 12v to charge a battery , and run a TV? With this setup , I can charge at 12V 90amps ,harnesse the energy into storage batterys to run lights,fantastic vents, then use an inverter to run my 48" samsung LED and I can run all this without the generator running by charging ,storing and using as needed. I have solar panels too , but this is the red giant for bulk charging.
The generator is located under the front of bus.
6" Steel drive pully from tractor supply $25.00 do not get die cast , the frame is a piece of steel I had laying around, that i bolted the engine down to,original pully on the alternator.
two pieces of heavy angle iron as the main support. the top support is for belt adjustment only
solid core door from home depot
access to the 12v honda generator from inside the bus,so I dont have to go out side at night or when its cold and windy or raining.
I have a duracell 2800 watt generator for heavy duty applications like power tools etc. portable water tank to get water.and the truck cap is being used as a dog house
"Thunder Bird"
Old 01-02-2014, 12:59 PM   #265
Year: 1974
Rated Cap: 46
Yes the generator I agree can be improved by using a permanent magnet alternator, and the torque of the engine. Put a 2" pully on the engine and gear down the alternator by putting a 8" pulley on the PMA, because a PMA can produce power at as little as 300RPM (or lower) to 800RPM. but that all costs money. I'm charging just a small bank of 3 flooded wet deep cycles. if I upgraded to some nice AGM trojans , i would upgrade to the charging system to exactly what you speak of.
"Thunder Bird"
Old 01-30-2014, 05:35 PM   #266
lornaschinske's Avatar
Rated Cap: 89
Breaking my silence to break the news first...
CONGRADULATIONS! Chadluc and Jeanette got married AND are new parents. New Year, new life, new job. WOW!
Fulltime since 2006
Old 01-30-2014, 05:55 PM   #267
Congrates and best wishes for a great journey
Lorna thanks for letting us know
Old 02-09-2014, 04:15 PM   #268
Year: 1974
Rated Cap: 46
yes we will have to post some family pics. You should stop by. were home if my ranger is there. i work nights and home during the day by 8am. dont worry im not tired during the day, I have a 5 hr lay over where i sleep in lubbock while the mail is processed. so im home and up most the day. you should stop by and see the new outdoor antenna from radio shack i picked up. it was the biggest they had for sale,.
"Thunder Bird"
Old 02-13-2014, 04:31 PM   #269
Year: 1974
Rated Cap: 46
few upgrades last week. I installed a outdoor antenna from radio shack. which works very well. all the antennas fold in so its pretty easy to move te bus as I just leave it secured to the bus and fold in all the little antennas.I also upgraded to a 20" range. the model is hotpoint.I also added fire extinguishers and smoke detectors.
[url=http://s83.photobucket.com/user/chadluc/media/IMG_1069_zpsb39ae1f5.jpg.html][IMG]
[url=http://s83.photobucket.com/user/chadluc/media/IMG_1065_zpsfbc4ce34.jpg.html][img]
"Thunder Bird"
Old 02-13-2014, 07:30 PM   #270
schoolmarm's Avatar
Year: 1985
Coachwork: Wayne Chaperone
Chassis: chevy
Engine: 350
Oh my, what a precious baby.
schoolmarm is offline   Reply With Quote
Project Silver Bullet Booyah45828 Skoolie Conversion Projects 11 01-24-2018 03:21 PM
Help 1984 Eagle Bus Conversion Insurance FL KyVang Titles, Insurance, Registration and Money Matters 0 01-10-2014 05:59 PM
US 180/ NM Hwy 12: Silver City NM - Datil NM (US 60) lornaschinske On the Road | Travel, Trips, Camp Sites, Tailgates 2 04-18-2013 07:40 PM
The Silver Snail... NewSkewlHauler Skoolie Conversion Projects 87 01-28-2012 10:50 PM
1974 Silver Eagle Chadluc Coach Conversion Projects 4 08-07-2011 03:39 PM
