Old 06-05-2013, 12:42 PM   #21
JakeC's Avatar
Re: Motobus
Motobus, I am sure you looked into it, but just double checking...are those axels rated to carry that much weight?! The trailer looks cool and I like the setup, but 2 vehicles on only 2 axles concerns me. If they are only 5k, you are probably over with the weight of the trailer, especially if you load any gear on it. If they are 7k axles, you would probably be fine. Like I said, you probably thought it through. I hope
Brutus
Old 06-05-2013, 12:51 PM   #22
Re: Motobus
the auto t-case comes right off just unbolt it, (5spd does not) the 4l30 tranny has a 27 spline output
the 4wd 700r4 also has 27 spline so you could in theory put a 203 box on and the 205 behind that...lot's of combo's
Old 06-05-2013, 09:01 PM   #23
Rated Cap: 47
Re: Motobus
The axles are 6500 lb.
The plan then is a jack shaft from the auto to the married 465/205.
Motobus is offline   Reply With Quote
Old 07-26-2013, 11:58 PM   #24
Rated Cap: 47
Re: Motobus
I got the Isuzu on one tons. Got some steering hooked up.
One of the jungle gym I built.
Old 07-27-2013, 05:19 AM   #25
Re: Motobus
Nice and low,that's the way to go
Old 09-30-2013, 11:10 AM   #26
Rated Cap: 47
Re: Motobus
Went on the maiden voyage with two rigs on the trailer. It stopped and handled everything well with a strong crosswind. Forward momentum on the other hand was another thing but about what I expected. Someone told me truck drivers would take a headwind over a side wind any day. I didn't know that, I have a lot of vehicle to catch wind from the side as well, maybe it can be a shorter trip on a calm day.
Old 10-01-2013, 08:22 AM   #27
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Motobus
Congrats on a successful maiden voyage!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 10-01-2013, 09:55 AM   #28
Rated Cap: 47
Re: Motobus
Thanks
Old 10-01-2013, 10:03 AM   #29
JakeC's Avatar
Re: Motobus
Bet that 330 was WORKIN!!
Brutus
Old 10-01-2013, 02:58 PM   #30
Rated Cap: 47
Re: Motobus
All 138 horses of it. We took rural blacktops to avoid traffic, lots of short hills up and down. It took us 75 minutes to drive 41 miles there. Burned about 18 gallons in 82 miles. We could have done better taking state highways. Stupid slow.
2001 E450 Star Trans MotoBus Conversion Project cloead Short-Bus Conversion Projects 27 03-27-2014 06:58 AM
