Old 08-28-2016, 02:14 PM   #121
Needed the .jpg extension
Old 08-28-2016, 02:18 PM   #122
REDD's Avatar
Coachwork: Thomsass
Chassis: Freightshaker
Engine: 5.9 cummins 5 speed
Rated Cap: 6 passenger 2 ATV's
Originally Posted by milkmania View Post
If you're wanting those pics in your post...
They need image tags [img] text [/img]
Or copy your picture link, hit this icon, and paste your picture link in the popup box
Then post like normal
Nevermind, I tried it with one of your pics and it didn't show up
Weird
My computer kid/daughter couldn't make it work either....ECCB was giving me pointers and still having issues.
Old 08-28-2016, 02:22 PM   #123
REDD's Avatar
Coachwork: Thomsass
Means nothing to me my friend, waaaaay behind on computer knowledge.
Does it work okay this way?
Old 08-28-2016, 02:26 PM   #124
No worries my friend
Baby steps! Hang around, we'll get ya there
Old 08-28-2016, 02:27 PM   #125
Yes, it gives us a link to click
Old 08-28-2016, 02:33 PM   #126
REDD's Avatar
Coachwork: Thomsass
Allrighty then, I'll add a few more pics....
Old 08-28-2016, 02:38 PM   #127
REDD's Avatar
Coachwork: Thomsass
https://imgur.com/kSDqR38
https://imgur.com/lmqMfYF
https://imgur.com/hug9MbP
https://imgur.com/fBiqH2b
https://imgur.com/FPlfj8f
Removed wipers for a freshening up, put some masking tape on the glass so they went back in the same position.
Old 08-28-2016, 03:18 PM   #128
REDD's Avatar
Coachwork: Thomsass
https://imgur.com/SoLKbQI
https://imgur.com/cfsMaA4
https://imgur.com/d9xNRvV
https://imgur.com/RRaIxmp
https://imgur.com/qa4ODWj
https://imgur.com/Ky7Wkg7
https://imgur.com/XMnDLNO
https://imgur.com/xaUI8v0
https://imgur.com/9uGH5I7
https://imgur.com/1VlkHbI
https://imgur.com/qXSamiw
https://imgur.com/F9XjqCB
https://imgur.com/3tuh1FG
https://imgur.com/gfmhwLV
https://imgur.com/UlbwEzG
https://imgur.com/5xnIjFp
https://imgur.com/EzOvxTq
https://imgur.com/KTbWKcf
....So we're workin' on the floor and beds in the rear. Got 900 sq. ft of laminate flooring for free from a friend, so I'm using it. Not ideal for wet ATV's but it's free. Takes a while to paint/clear everything, shop is only 10x18' out side measurements....a couple of pieces at a time. Trimming out with 1x1 aluminum angle and some aluminum checker plate I had kickin' around. The short pieces of angle with holes drilled into it will be used to anchor beds to walls, S/S screws and carriage bolts. Still workin' on the hinges for the doors and bed tops...off set Z shape. The folded up pieces of fabric on the table are Mosey Oak curtains for the two sides and front windshield....the old man made the table top, it's hallow to lighten it up a bit. With the couch folded down into a bed you can reach the table, can seat six with no problem. Found an old license plate frame and covered it with reflective black and green, the plate I'll be using is off a kit car VW buggy I sold a few years back. No shortage of sanding and painting at this point. I'm in the middle of taping around the edges of the walls to silicone the gaps....it'll almond rubber trim/molding to seal the back from the front in case we get into some stinky mud, been there. Inside the walls will be the $#itter on the left and sink on the right. The front door will swing in and lock against the sink and the rear will swing in and lock against the toilet like a hall way to the rear of bus...hope that makes sense.
The beds are sitting low on top of the wheel wells, one ATV will be parked on top of the bed and the other behind on the floor....still have to remove the rear of the bus for access. Probably next spring, crazy busy with my two jobs.
Old 09-01-2016, 10:10 AM   #129
Nice work.
superduty_59 is offline   Reply With Quote
Old 12-22-2016, 11:12 AM   #130
REDD's Avatar
Coachwork: Thomsass
Originally Posted by superduty_59 View Post
Nice work.
Thanks Superduty.
