04-03-2016, 10:46 PM
#101
How did all that white beach sand get on your roof & hood?
04-04-2016, 01:36 PM
#102
In WA, OR, and CA emergency exits in the roof have been part of the minimum spe'c for more than 20-years.
I suppose I made the wrong assumption the spe'c was standard on all buses.
The roof hatches that can be opened as ventilators is such a nice thing to have I just couldn't imagine anyone not ordering them.
But when one is trying to get something in for the lowest cost, anything that isn't required becomes an unnecessary expense.
04-04-2016, 02:54 PM
#103
those hatches almost always end up leaking in heavy rain.. so I think they only get ordered if they are required as emergency exits..
this is a kickASS bus!!!! im loving this build out!!
04-04-2016, 02:56 PM
#104
Kevin is the man! Keep the pics coming!
04-05-2016, 02:52 PM
#105
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
It blew up from your neck of the woods ....it's white camo, see how well it blends in with the lawn.
04-05-2016, 02:57 PM
#106
Coachwork: Thomsass
Was thinkin' the same thing about the hatch...specially up here in the salt belt.
...and thanks
04-05-2016, 03:00 PM
#107
Coachwork: Thomsass
Thanks Charlie, suppose to get parts back tomorrow and I'll get some pics with it all installed.
04-10-2016, 08:05 PM
#108
Coachwork: Thomsass
...Well my parts didn't show up, snowed in. Maybe tomorrow I'm told, and now it's snowing again.
I did get some hub and nut covers to finish off the rims.
04-17-2016, 09:07 AM
#109
Coachwork: Thomsass
Painter dropped off my parts the other day...I'm defiantly not a photographer.
04-17-2016, 09:14 AM
#110
Coachwork: Thomsass
So the old man whipped up some furniture for me....nothin' to fancy.
Havin' a hell of a time puttin' pics up, keeps shuttin' down?
04-17-2016, 09:17 AM
#111
Kevin, you're the MAN!
This is one of my favorite threads, man.
You officially have the coolest steering wheel in all of skooliedom.
04-17-2016, 09:26 AM
#112
Coachwork: Thomsass
The couch/bed....
04-17-2016, 02:47 PM
#113
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
I like how you have the front hinged for storage and the back hinged for reclining. Pretty smart idea!
04-17-2016, 04:29 PM
#114
when you build furniture out of plywood what do you do to cover it?
i keep struggling with the idea of trying to find something pre-made that sort of maybe will fit my needs. . or building it as you have but then I get stuck at the point of trying to make it look finished.
04-17-2016, 07:08 PM
#115
Coachwork: Thomsass
I can't take credit for the furniture, my ol' man built it. I let him come up with ideas. The booth is my layout more or less, pretty simple. The couch/bench was his baby, I had the lid double thick with the top piece folding over into the aisle to make it into the bed. The bottom would have had a hinge at the back so I could lift it as a lid....a lot heavier and more plywood.
The couch is double hinged forward, first hinge is the back rest, second hinge allows you to have access to the storage box. The seat slides forward on hardwood runners and the back drops down flat, under the seat there are three folding support legs held up with magnets. I'll try posting again, grrr.
04-17-2016, 07:16 PM
#116
Coachwork: Thomsass
I bought good one side 3/4" with a pine veneer, I'm painting the insides of the storage boxes white [bad side] and clear coating the good side to give it a cabin feel. I figured when it gets banged and chipped, and it will, it'll be a plywood colour under the clear. The battle scars won't show up as bad.
04-17-2016, 07:30 PM
#117
Coachwork: Thomsass
Whipped up a couple of experimental movable tie down bracket thingys, gunna use them for securing genny, bbq, bikes maybe, who knows. I'll make 8 more with grade 8 bolts and a little heavier steel and link for the ATV's....holes are already there in/on the wall may as well use them.
04-17-2016, 07:45 PM
#118
Coachwork: Thomsass
Thanks CB
Really having a lot of fun creating this thing!
Sorta like Mad Max, Frankenstein and Mule Bus ... Mad Franken Mule?
08-28-2016, 01:11 PM
#120
If you're wanting those pics in your post...
They need image tags [img] text [/img]
Or copy your picture link, hit this icon , and paste your picture link in the popup box
Then post like normal
Nevermind, I tried it with one of your pics and it didn't show up
Weird
