08-28-2016, 01:14 PM
#121
Needed the .jpg extension
08-28-2016, 01:18 PM
#122
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Originally Posted by milkmania
If you're wanting those pics in your post...
They need image tags [img] text [/img]
Or copy your picture link, hit this icon , and paste your picture link in the popup box
Then post like normal
Nevermind, I tried it with one of your pics and it didn't show up
Weird
My computer kid/daughter couldn't make it work either....ECCB was giving me pointers and still having issues.
08-28-2016, 01:22 PM
#123
Coachwork: Thomsass
Means nothing to me my friend, waaaaay behind on computer knowledge.
Does it work okay this way?
08-28-2016, 01:26 PM
#124
No worries my friend
Baby steps! Hang around, we'll get ya there
08-28-2016, 01:27 PM
#125
Yes, it gives us a link to click
08-28-2016, 01:33 PM
#126
Coachwork: Thomsass
Allrighty then, I'll add a few more pics....
08-28-2016, 01:38 PM
#127
Coachwork: Thomsass
08-28-2016, 02:18 PM
#128
Coachwork: Thomsass
https://imgur.com/SoLKbQI
https://imgur.com/cfsMaA4
https://imgur.com/d9xNRvV
https://imgur.com/RRaIxmp
https://imgur.com/qa4ODWj
https://imgur.com/Ky7Wkg7
https://imgur.com/XMnDLNO
https://imgur.com/xaUI8v0
https://imgur.com/9uGH5I7
https://imgur.com/1VlkHbI
https://imgur.com/qXSamiw
https://imgur.com/F9XjqCB
https://imgur.com/3tuh1FG
https://imgur.com/gfmhwLV
https://imgur.com/UlbwEzG
https://imgur.com/5xnIjFp
https://imgur.com/EzOvxTq
https://imgur.com/KTbWKcf
....So we're workin' on the floor and beds in the rear. Got 900 sq. ft of laminate flooring for free from a friend, so I'm using it. Not ideal for wet ATV's but it's free. Takes a while to paint/clear everything, shop is only 10x18' out side measurements....a couple of pieces at a time. Trimming out with 1x1 aluminum angle and some aluminum checker plate I had kickin' around. The short pieces of angle with holes drilled into it will be used to anchor beds to walls, S/S screws and carriage bolts. Still workin' on the hinges for the doors and bed tops...off set Z shape. The folded up pieces of fabric on the table are Mosey Oak curtains for the two sides and front windshield....the old man made the table top, it's hallow to lighten it up a bit. With the couch folded down into a bed you can reach the table, can seat six with no problem. Found an old license plate frame and covered it with reflective black and green, the plate I'll be using is off a kit car VW buggy I sold a few years back. No shortage of sanding and painting at this point. I'm in the middle of taping around the edges of the walls to silicone the gaps....it'll almond rubber trim/molding to seal the back from the front in case we get into some stinky mud, been there. Inside the walls will be the $#itter on the left and sink on the right. The front door will swing in and lock against the sink and the rear will swing in and lock against the toilet like a hall way to the rear of bus...hope that makes sense.
The beds are sitting low on top of the wheel wells, one ATV will be parked on top of the bed and the other behind on the floor....still have to remove the rear of the bus for access. Probably next spring, crazy busy with my two jobs.
09-01-2016, 09:10 AM
#129
Nice work.
12-22-2016, 10:12 AM
#130
Coachwork: Thomsass
Originally Posted by superduty_59
Nice work.
Thanks Superduty.
12-22-2016, 10:16 AM
#131
Coachwork: Thomsass
https://imgur.com/3YFOawk
https://imgur.com/qbyaWk3
https://imgur.com/I4bDgJZ
https://imgur.com/HSXmF4D
https://imgur.com/o2pv5Jv
https://imgur.com/oZzBKaK
https://imgur.com/iqMvxq8
https://imgur.com/M0vHjox
https://imgur.com/UCZ6454
https://imgur.com/VsJzJZd
https://imgur.com/5MC15wN
https://imgur.com/l1xgmIa
https://imgur.com/YOR0wFu
https://imgur.com/aKTmZNS
https://imgur.com/uO48ui1
https://imgur.com/BXvEUJW
https://imgur.com/q6hdSD9
https://imgur.com/l5001RI
https://imgur.com/T2a79Ih
https://imgur.com/UVjim5e
https://imgur.com/byuxnUs
https://imgur.com/h72lG7d
https://imgur.com/vSKG47G
https://imgur.com/tS2GQ5S
https://imgur.com/zL4a6gT
https://imgur.com/mVWbwpW
https://imgur.com/TrJkLAj
https://imgur.com/IoVNvDA
https://imgur.com/S3UYzGH
https://imgur.com/wdcXN38
https://imgur.com/eASEFm9
https://imgur.com/QFWsqFt
https://imgur.com/neWHxY5
https://imgur.com/tafAzSr
https://imgur.com/9TlAYCO
https://imgur.com/MHuevjf
https://imgur.com/Q0gNXb8
https://imgur.com/AKH92Tv
https://imgur.com/TZIzUK4
https://imgur.com/Fbx0ayj
https://imgur.com/3YpdKbb
https://imgur.com/5a1wBhe
https://imgur.com/kqO5zDr
https://imgur.com/GPhTpQM
https://imgur.com/y0MceAV
https://imgur.com/d5RzK3C
https://imgur.com/n60xmQM
So we got the doors finished and installed...routered edges, clear coat and paint on both sides, hinges made, locks created. Hinges were made from 1 1/4" x 1 1/4" x 1/8" angle and 1" x 1/8" piano hinges, trimmed one edge of the hinge and welded together in S/Z shape, drilled and painted...rounded corners to match doors, stainless screws. Locks were made from misc stainless hardware lying around.... nuts [British thread] , rod, bolts, flat bar and a couple plated hitch pins. There's holes drilled in the rod for the hitch pins if you really need to lock the doors. Made a counter, cabinet and shitter out of 3/4" pine veneered plywood...cleared outside and painted on the inside [exterior products on everything]. The cupboard Handles/latches are RV that lock. The mirror is a piece of 14 gauge mirror stainless steel. Found a cheap 12 volt RV tap that'll work fine for washing hands/face/brushing teeth sorta thing. A 5 gallon pail for fresh water and one for grey...emergency use for the most part. A pail for the toilet as well. We stay mostly in camp sites with comfort stations or at friends cottages. We were going to buy a Natures Head, couldn't justify the cost for the amount we'd use it.
I found some RV hooks for holding blinds in place, cut one of the tabs off so it would fit under the wire chase and I could use the screws already there. Installed grommets on the top edges of the curtains.... didn't want curtains hanging 24/7. They store neatly folded up in a plastic tote under the set and hang in under 5 min.
Finally found a decent seat for the passenger side ...air ride from an '08 Sterling [needs a cleaning]. Will be working on a pedestal for it to sit on over the winter.
12-22-2016, 11:27 AM
#132
Keep up the awesome work, Kevin!
12-22-2016, 12:06 PM
#133
Coachwork: Thomsass
Thanks Charlie!
I need to work on figuring out how to post pics without having to open them individually....PITA.
05-05-2017, 07:09 PM
#134
Coachwork: Thomsass
05-05-2017, 07:15 PM
#135
Coachwork: Thomsass
more pics.....
05-05-2017, 07:21 PM
#136
Coachwork: Thomsass
05-05-2017, 07:22 PM
#137
Coachwork: Thomsass
Have a new seat belt that needs to be installed for the passenger and some paint to touch up.
Working on seat belts for the bench and booth, then bolt everything down.
Next thing would be a 12 volt power source for the tap.....for the bare minimum to get this thing going, fingers crossed.
05-05-2017, 07:39 PM
#138
Coachwork: Thomsass
Oooops, tried to edit the wrong pics ...geese on neighbours roof and wiper arms for brothers S10....couldn't figure it out.
These were the pics I wanted.
05-05-2017, 09:07 PM
#139
Nice work there!!!
05-05-2017, 09:49 PM
#140
Damn, I love your craftsmanship Kevin!
I wish you didn't live so darn far north!
