07-02-2015, 07:58 PM
#21
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
07-02-2015, 09:12 PM
#22
I put an ad on craigslist and gave my seats away when I had them out.
The fella that came had a for ranger and we stacked 20 of the 24 seats on the back of that pickup, I then pumped up his flat tire and he went on his way.
he had about 8 miles to home and shot me a text saying he made it home just fine.
I did not disassemble the seats either so it was a fairly high stack
07-02-2015, 10:51 PM
#23
Chassis: All-American R/E
Super singles are awesome when you have a blow out!
07-05-2015, 01:35 PM
#24
Coachwork: Thomsass
Was wondering the same thing, in the last few days/week I saw a straight truck and some kind of farm tanker thingy with super singles.....looked pretty cool. Hydroplaning might be an issue.
07-05-2015, 01:41 PM
#25
Coachwork: Thomsass
07-05-2015, 09:03 PM
#26
Coachwork: Thomsass
Got 'er cleaned out for the most part.
Mule's mounted, it's official.
07-05-2015, 09:14 PM
#27
I love it.
Its officially the mule bus, eh?
07-05-2015, 11:56 PM
#28
Year: 1951
Chassis: 2000 Chevrolet.
Engine: 400 ci Chev Vortec
Something like this perhaps?
johnboy.
I don't need to be told I'm a son of a b***h; I've been one a long time.
The hours are good and there's no heavy lifting.
07-06-2015, 06:26 AM
#29
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
Now this thread is going in the right direction. Love the ATV shots.
Originally Posted by REDD
07-06-2015, 10:35 AM
#30
Coachwork: Thomsass
Dropped off some parts I won't be using to the bus company I bought the bus from, and they gave me this....not the tomato
07-06-2015, 10:42 AM
#31
Canadian decency at work, eh?
07-07-2015, 06:10 PM
#32
Coachwork: Thomsass
Something like that, EH!
07-07-2015, 06:23 PM
#33
Coachwork: Thomsass
07-08-2015, 12:04 PM
#34
Coachwork: Thomsass
So I started to make a custom shifter knob for the Mule Bus. Started with a bock of aluminum 3"x1.5", drilled, cut, hacked, shaved, tapped, sanded 'til I got to this, a little more shaving and sanding....but it's a start. The head I found on EBAY along with the hood ornament.
07-08-2015, 03:52 PM
#35
Made me laff my "ass" off.
Sweet...now go chrome it!
07-08-2015, 05:29 PM
#36
Chassis: B3800 Short bus
Your heaters look like they were set up like mine. Are you removing the rear heater? If so, remove the cover and look at the main heater core next to the drivers seat. My guess is that you DON'T want to loop the coolant lines together after removing the rear heater. Depending on the heater core you may want to plug the lines instead.
07-08-2015, 09:02 PM
#37
Coachwork: Thomsass
Yes, more or less the lay out, shut off valve at your left foot. I figured just continue the loop, by-passing the the rear heater? Plug/cap it instead, why? I'm mechanically inclined but not a mechanic.
07-08-2015, 09:12 PM
#38
Coachwork: Thomsass
Crawled under the bus for a tranny check,
Fuller FS-5205A/B ...5 SPEED
Any body, yay/nay?
07-08-2015, 09:28 PM
#39
First off, you want to be absolutely sure that your heater core has copper tees coming off of it like mine does. If so then looping the coolant lines will create a path of least resistance for the antifreeze so will be limiting the amount of hot antifreeze that actually goes through the heater core. Most of the coolant will flow through the loop and not even enter the heater core. Plugging off the lines will force ALL of the antifreeze through the heater core, producing maximum heat (can still be controlled by the heater valve). That heater is also the primary defrost for the windshield. Max heat for that purpose is a good thing.
07-17-2015, 07:00 PM
#40
Coachwork: Thomsass
Thanks Jazty, that's what I have and that's what I'll do tomorrow. Got the parts just need a little time, seems work has gotten in the way of my project.
All I got done was blacking out the windows, first five windows are limo tint and the back six windows are solid black vinyl from a sign shop. Also started grinding/sanding/wire wheeling the paint and rust inside.
This was from another thread....Turns out the tools I thought were made in Canada were made in West Germany, found a couple of wire cups that have been around for over 25 years in a drawer. The tags on the tools are so worn out all I can read is something Canada on one of them......Dist. in Canada I guess.
