03-30-2020, 09:33 AM
#501
Engine: T444E 7.3L
How much are cigs at the reservation?
Seneca brand at $25.00 per carton is what I smoke. They do have cheaper brands and unpackaged brands cheap as $10.00 a carton.
03-30-2020, 09:58 AM
#502
Originally Posted by banman
I thought you rolled your own...
YEah, I do. But not cigs.
03-30-2020, 09:59 AM
#503
That's very reasonable!
08-13-2020, 08:33 AM
#504
Chassis: Vista 3600
Rated Cap: 24000 lbs
Finally read the whole thread Johnny
good stuff
was not aware the mullet was real and not just a screen name
and nice how it ended with a discussion on the price of fags...which are over $14 a pack in the UK lol
I need to go throw the vids next, I just read the thread and pics... wish we had Amish around here... I remember them on Visits to Granparents farm in Bellville Ohio... lot of Amish around there
If you are ever near Raleigh NC look us up.. we have bus parking no worries
cheers
08-13-2020, 07:24 PM
#505
Engine: T444E 7.3L
Thanks! I do have some more updates on the bus and getting ready to do a major rear brake overhaul, so stay tuned!
08-30-2020, 05:54 PM
#506
Engine: T444E 7.3L
Today I removed the rear wheels, removed the calipers, pulled the hubs, replaced the rotors, seals, calipers and pads. Done this many times, but doing it on my own vehicle makes it fun?
08-30-2020, 06:59 PM
#507
Rated Cap: 19
4 thumbs up! Well, two thumbs and two big toes.
08-30-2020, 07:20 PM
#508
I really need to learn to straighten Dayton’s on the rear.. my dev bus wobble and I can’t get them straight for nothing
08-30-2020, 08:42 PM
#509
Engine: C7 Cat
Fantastic work Johnny!
Thanks for the great video including the safety tips on the wedges.
Oscar
08-31-2020, 08:48 AM
#510
Chassis: International 1753
Engine: 6.9 International
Cool deal. I've never seen disc brakes with a cast spoke hub.
Good tip on lubing the bearings. If you can't lube them like you did, we'll sit the opposite wheel up on some cribbing to let the oil work it's way over to the dry bearings. I've also seen on some hubs where one of the axle shaft bolts were drilled through into the hub, which allowed you to push a quart of gear lube into the hub after the hub, bearings and axle shaft were all installed.
Christopher, aligning the cast wheels isn't hard, just takes a special technique. It helps if you put a drop of oil on the lug studs and between the nut and clamp. Then you mount the wheels and tighten all the clamps a little at a time, centering it as you go, then once it runs true, you tighten the lug nuts in steps to spec, which is 160 for 5/8" studs and 200 for 3/4" studs.
08-31-2020, 08:57 AM
#511
I just haven’t gotten the hang of the rear with the spacer and such.. body strength is prob an issue for me when working with 11r22.5, I just may not be getting the inner on correctly to start
08-31-2020, 05:59 PM
#512
Engine: T444E 7.3L
Truing up Dayton wheels is a pain and you almost never get the PERFECT, but it takes awhile.
09-04-2020, 07:30 PM
#513
Engine: T444E 7.3L
Parking brake cable is replaced! I did not take pics or make a video, but if I did the entire video would be nothing but bleeped out cuss words. The hardcore rear brake overhaul was easier than replacing this dreaded cable. 3 hours fiasco for a simple cable.
09-04-2020, 07:58 PM
#514
what are some tricks to working with the rear dualies to get them straight? fronts i have no problem.. its those heavy rear duals..
09-04-2020, 08:46 PM
#515
Engine: T444E 7.3L
I set the inner rim and then the spacer. I then place the outer rim on and use my foot to keep the bottom pushed in. I place all the wedges and nuts and use a 1/2" impact to slowly tighten one upper, then one lower nut. I spin the wheels using a socket on the floor next to the outside tire to visualize the offset. Use the impact orEVEN HAND TOOLS TO SLOWLY TIGHTEN each nut by tightening and spinning to make them true.
I think there is a "slow hand science" to truing up these wheels.
09-05-2020, 09:50 AM
#516
Engine: C7 Cat
Haha that's awesome!
So do chalk that one up to pure determination or pigheaded?
