08-21-2016, 08:14 PM
My 1974 Chevrolet 7 window
08-21-2016, 08:23 PM
Removed the bus "flasher" unit,
along with the wires that were cut when the privious owner removed the amber and red lights.
08-21-2016, 08:24 PM
Welcome! --- Cool old school Bowtie lines! Keep the pix coming.
08-21-2016, 08:32 PM
08-21-2016, 08:35 PM
My transmission pan
08-21-2016, 08:36 PM
GM number on my diff.
08-21-2016, 08:39 PM
08-21-2016, 09:01 PM
Thanks, for a 40+ year old bus still parts available 😊
08-21-2016, 09:10 PM
Yep...I can even find a few for my 70 year old. Thank goodness there are a lot of old Stovebolts still around.
08-21-2016, 10:24 PM
Oh yeah she's a beauty, goodness. Mmmm 350 motor. Ain't but a block, alternator and a carb. Nothing could break on it that a days work can't fix.
No computers going wacky, no sensors misreading pressure, voltage, current, etc. and shutting down the entire operation because they're not receiving the required signal, even though everything is just fine. Ahhhh, they don't make 'em like that anymore.
08-22-2016, 09:48 AM
KISS is good!
08-22-2016, 03:23 PM
Simple is good as long as smog police don't muck it up.
08-22-2016, 04:01 PM
when I was into hot-rodding i thanked my lucky stars daily that I live in a smog-check, inspection check Free city / county...
if you can bolt it up here and it runs its legal..
08-23-2016, 06:28 AM
Begining Sketchup drawing of my skoolie.
08-25-2016, 09:20 PM
Well today was busy...
Checked into getting a a second 50 gallon propane tank, now looking for a used tank.
Checked on getting an off the shelf "Y" pipe, no luck. Custom exhaust here we come.*
Checked into getting 900 R 20 tires or something to fit, nothing. Custom rims and 22.5 tires down the road.
Found out I have Allison Transmission AT 540 3 speed
08-27-2016, 02:37 AM
Received a quote on tires today ...ouch
Rims (tubeless) 397.50 ea
Need to find:
Rim Size:**22.50 X 6.75
Bolt Pattern:**10 Hole on 222.25mm Bolt Circle, 158.75mm bore
Mounting Type:**Hub Piloted Dual
Offset:**5.93"
Material:**Steel
08-28-2016, 09:42 PM
Engine: t444e
You may want to consider swapping out hubs/axles, yours appear to be an odd size.
08-29-2016, 08:18 AM
Check the big truck wrecking yards for a much better price.
08-29-2016, 11:56 AM
Love the older buses! I studied alternate fuels in school. Propane is cool and CNG but personally I would swap in a cheap 12v Cummins. Anything that big will get terrible MPG anyway and diesel will be cheaper. Sticking with the LPG engine and such is cheaper right now because that is what it came with. Keep us updated!
09-01-2016, 06:51 PM
I took a look at my wheelchair lift today. It has a hydraulic pump and a single ram. From the ram goes 2 chains 1 for each side, the chains are stiff and gooy, need lubricant. Thinking if I keep the lift changing the hydraulic system with a electric actuator. But the lift takes up room in the bus, hmmm....
