Old 09-07-2016, 12:01 PM   #1
My build placeholder - International 3800 DT466 - Minneapolis
Starting my build.
77 passenger, removed all seats, striped and recycled
Looking at floor next. 1/2 inch foam, with laminate flooring on top. I'm planning on adding my framing over the flooring, instead of directly to the metal floor.
Also wondering if I should go with 50amp or 30amp. If the cost is roughly the same and 50amp gives that much more capacity, then I'm leaning towards 50amp, but would love any advice.
Flame on!
Thanks!
Steven
mplsdog is offline   Reply With Quote
Old 09-08-2016, 04:17 PM   #2
Coachwork: Corbeil - RAMROD
Chassis: IH 3800 66 Pass
Engine: 7.3 IH IDI NA w AT545 hyd
From what I've read on here and other forums - you are better to avoid laminate as water can still get trapped beneath it. Unless you have locking sealed stuff made to withstand spills and moisture.
Sweet engine and length!
slidewayzm5 is offline   Reply With Quote
Old 09-11-2016, 09:41 AM   #3
Floor going in
I can't figure out how to post an in-line photo using Google Drive. I have to say, I hate Imgr, photobucket, etc...
Oh well, I'll continue to post my links back to my Bus folder on Google Drive.
Laid down 1/2 rigid, 1/2 inch plywood and now adding click-laminate.
https://drive.google.com/file/d/0B2f...ew?usp=sharing
Old 09-11-2016, 12:02 PM   #4
wunderhut's Avatar
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
Linking from Drive takes extra work I think. This is how I do it. There might be an easier way, but I don't know what it is.
Format your link like this (where XXXXXXXX is the file ID of your picture):
Code:
http://drive.google.com/uc?export=view&id=XXXXXXXX
So the link for the photo you linked to in your above post looks like:
Code:
http://drive.google.com/uc?export=view&id=0B2f6E1odWzhYNzN6QzlQTDliTzg
Sometimes they come out sideways, I don't know why, but I think its random and happens with all the sharing services occasionally??? Someone else may know that answer.
wunderhut is offline   Reply With Quote
Old 09-11-2016, 07:13 PM   #5
Booya. Thank you!
Old 09-11-2016, 07:18 PM   #6
