Old 02-15-2017, 06:03 PM   #41
Chassis: International S3800
the in frame kit should have new pistons and liners matched as well as bearing inserts.. since you never spun a bearing you shouldnt have to turn the crank
Old 02-15-2017, 06:06 PM   #42
dmattarn's Avatar
Engine: DT466E Allison 3000
Rated Cap: 84 Kids/56 Adults
I haven't pulled pistons yet to examine bearings. I'm hoping I don't have any spun. I don't have the means currently to pull a 1500lb engine out of the front of the bus, nor do I have an engine stand to remove the crank to have it ground.
Sent from my SM-G930V using Tapatalk
"Once you get it, you got it."
dmattarn is offline   Reply With Quote
Old 02-15-2017, 10:19 PM   #43
Chassis: TC 2000 bluebird
Engine: 5.9 cummins
Harbor freight has a 2000lb engine stand on sale for $125. And their 2 ton engine hoist is only $220.
It might be easier with a forklift though.
It is doable, but would be easier on concrete than gravel.
When you get it running again, lets talk about an Ohio/Michigan/Indiana rally. I think there are quite a few in the tri state area and it would be great to meet fellow converters, and a lot of fun.
Bill
miltruckman is offline   Reply With Quote
Old 02-15-2017, 10:21 PM   #44
dmattarn's Avatar
Bill
I am all for meeting up. Hoisting won't work where I'm at currently, I'm parked in my back yard about 30-50 feet from concrete unfortunately. If I manage to sell my car and pick up a cummins ram pickup I'll be able to pull her up to the concrete and consider pulling the block
Old 02-20-2017, 03:50 PM   #45
dmattarn's Avatar
We had some unusually warm weather this weekend so I ended up pulling pistons. Crankshaft rod journals look in pretty good shape. Pistons 2 and 6 were pretty badly scored.
Old 02-20-2017, 03:59 PM   #46
good thing for sleeved cylinders.. this thing can get a new lease on life..
good deal on the crank journals.. those are the scary ones...
Old 02-20-2017, 04:02 PM   #47
dmattarn's Avatar
Sleeves are a great thing. Now I just need to figure out a plan to get them out.
I'm hoping that since the rod journals are in great shape, none of the main bearings will be spun
Old 02-20-2017, 04:04 PM   #48
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Man, way to go!
Roll Your Own Build Thread
Old 02-20-2017, 04:18 PM   #49
ive only ever seen sleeves yanked with a tool made for the purpose.. I saw it done on a Semi truck engine once and they were in there pretty good..
wonder if someplace like sunbelt rentals or such would have a tool like that..
Old 02-20-2017, 04:20 PM   #50
dmattarn's Avatar
Some of my teachers suggested a seal driver with a Jack. They only have to move about a half inch to pop them past the oring and then they slide it easy from there
