Old 05-30-2015, 08:47 PM   #21
Chassis: Amtran
Rated Cap: 71
Shower is inside the bus the fit is pretty good cutting that shape on an irregular shape like a shower is a bear.
Got excited so I dry fit a couple of things
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
The Nebuchadnezzar is offline   Reply With Quote
Old 05-31-2015, 05:35 AM   #22
Year: 1979
Chassis: Ford B700
Engine: 6.1L, 370-4v lima
What kind of composting toilet did you go with? Brand/name? I was looking at going with a sunmar for my own build.
calmingcrow is offline   Reply With Quote
Old 05-31-2015, 06:29 AM   #23
Chassis: Amtran
Rated Cap: 71
I went with Natures Head, from what I've read the toilets that work best separate the 1 from the 2. Some of the toilets that don't result in big blocks of well you know. 12v volt fan is great too for ventilation.
~Morpheus
Old 05-31-2015, 07:54 AM   #24
Chassis: I.H.
Uh,is that a pic of the pattern leanign up against the shower where it will be? It looks like the shower is going to face the front or rear of the bus. Is that correct? If not, the pattern should be on the sides of the shower, not the front and back. Maybe I am seeing it wrong.
Old 05-31-2015, 07:58 AM   #25
Chassis: I.H.
Oops. My mistake for posting before I saw the finished cut pics. It looks great facing that way.
Old 06-05-2015, 07:07 PM   #26
RHOMBUS's Avatar
Chassis: Freightliner HDX
Engine: CAT 3126B250
What size is that shower? Did it come as a single piece? Where did you find one? I've been looking through many options and just can't find the right combination.
RHOMBUS is offline   Reply With Quote
Old 06-06-2015, 04:47 AM   #27
Chassis: Amtran
Rated Cap: 71
It's 32" x 32" x 73", I think the name on it is Lasko, I bought from someone doing a remodel on CL for $100. Trying to get back out there this weekend to do more work unfortunately some folks close to me don't share the same sense of urgency as me in continuing the work
~Morpheus
Old 06-06-2015, 12:50 PM   #28
nice job on those cuts.
Nachowarrior is offline   Reply With Quote
Old 06-07-2015, 08:36 PM   #29
browncrown's Avatar
Rated Cap: 79 at Birth
Looking very good!
BC
Old 06-07-2015, 09:12 PM   #30
Chassis: Amtran
Rated Cap: 71
Thanks guys
~Morpheus
