08-28-2015, 10:42 PM
#61
Mmmmm...like the silver. But now you gotta' dye the dog to match.
08-29-2015, 05:30 AM
#62
Chassis: Amtran
Rated Cap: 71
Most of the silver paint is finished. I'm going to paint between the two middle rub rails black and repaint the remaining rub rails black too. I'm worried I might get drips of black on the silver, not sure if I should do the rails with a foam rubber brush and the can of paint I bought or use rattle cans and a piece of cardboard to prevent over spray?
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
08-29-2015, 07:18 AM
#63
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Go to Lowe's or Home Depot in the paint section and buy a self adhesive edge barrier. They aren't too pricey and you just put it on like you are taping an edge. Makes it easier if you use spray, and can do it by yourself.
Looks great!
-Doc
08-29-2015, 07:29 AM
#64
Get the sunday paper and a roll or two of masking tape.
08-29-2015, 05:51 PM
#65
Rated Cap: 79 at Birth
The silver paint is Beautiful!!!
08-29-2015, 07:57 PM
#66
Chassis: Amtran
Rated Cap: 71
Thanks guys, The silver paint is XO-Rust which was thinner than I expected, for some reason Rustoleum won't ship that color to CT. Anyway I used Rustoleum black and it is much thicker, I actually ended up thinning it a bit which worked fine with brush, roller and some foam brushes. Still have to re-pint more rub rails, but I'm happy with the progress.
[/URL][/IMG] [/URL][/IMG] [/URL][/IMG]
~Morpheus
08-29-2015, 08:40 PM
#67
Looks gooooooood!
08-29-2015, 08:49 PM
#68
Shelby approves of the silver & black
08-30-2015, 08:54 AM
#69
I had a really sweet pooch named Shelby a few years back. But she was a tad larger...what with being a Greater Swiss Mountain Dog.
08-30-2015, 03:04 PM
#70
Year: 92
Engine: DTA360 5.9L
That silver looks great, hope my paint jobs looks that good!
08-30-2015, 09:23 PM
#71
Chassis: Amtran
Rated Cap: 71
Thanks, hoping it will be reasonably durable.
~Morpheus
09-05-2015, 07:40 PM
#72
Chassis: Amtran
Rated Cap: 71
Finished painting the rub rails
Getting excited for a voyage, still a bunch of work inside yet though
[/URL][/IMG]
~Morpheus
09-05-2015, 07:48 PM
#73
What would really set that paint job off would be top paint the wheels silver and the lugs and centers black.
But even as it is, it looks GREAT!
09-09-2015, 06:06 AM
#74
Chassis: Amtran
Rated Cap: 71
House battery storage
I picked up this steel box a while back on CL 18"x18"x36", it will nicely accommodate 6, 6 volt deep cycle batteries for storing the electricity from 600 watts of panels. Someone had welded a shelf in it that took me an hour and a half to cut out. Anyway this is the next project. Curious I'm thinking of utilizing the upper wiring chases for most of my wiring A.C. and D.C. and then dropping them down to boxes, is this what most folks do, I've seen some that run conduit beneath the bus and come back up?
[/URL][/IMG]
~Morpheus
09-09-2015, 07:44 AM
#75
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Bus looks good, how about some NUT BLING for the rims?
09-09-2015, 08:28 AM
#76
Chassis: Amtran
Rated Cap: 71
I think that would look great.
~Morpheus
09-12-2015, 09:47 PM
#77
Chassis: Amtran
Rated Cap: 71
Underbelly box for house batteries
Spent the day adding an underbelly box for the batteries for 600w of solar panels. Turns out a motorcycle lift is ideal for lifting stuff like this.
[IMG]URL=http://s1383.photobucket.com/user/tom_walker4/media/battery%20box%205_zpspqp8uwei.jpg.html]
[/URL][/IMG]
~Morpheus
09-13-2015, 12:19 AM
#78
Excellent! Nice job.
09-13-2015, 12:33 AM
#79
Coachwork: Crown by Carpenter
Rated Cap: 16
Curious as to how you secured the box to the bus....I really like that idea and would like too add that to my list...
09-13-2015, 05:39 AM
#80
Chassis: Amtran
Rated Cap: 71
I used these style clamps with 1/2-13 threaded rod and a spacer inserted into the open channel supports then uni-strut under the box. I used the proper uni-strut hardware and lock washers and nuts, this allowed me to tighten the nuts until the box was locked directly to the floor supports above. I still need to add a couple of cross beams of the uni and move the box a little closer to the outer skin, I measured the opening to over lap the box in the front which will allow me to screw the skin to the box around the perimeter of the door. I'll try to get pictures of the support structure later today.
~Morpheus
