Old 08-02-2015, 08:26 PM   #41
Chassis: Amtran
Rated Cap: 71
Mounted the tanks
Doing warm weather projects on the Neb, mounted the two 100 gal tanks this week. I got a deal on a bunch of uni-strut so I used that. I added fittings to the grey water tank. will be painting the exterior in the next couple of weeks, all that is yellow will be silver.
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
The Nebuchadnezzar is offline   Reply With Quote
Old 08-02-2015, 08:40 PM   #42
crazycal's Avatar
Very nice work.
I'm hungry!
You Gotta Let Me Fly
Old 08-02-2015, 09:06 PM   #43
yes, very nice work.
Old 08-02-2015, 09:38 PM   #44
Rated Cap: 40 Prisoners
Are the fittings compression type fittings for the polypropylene
tanks? When I added fittings to my tanks I got the spin-weld
fittings from Inca Plastics and one of their tools to fit my disc
grinder for less than $20 and welded on new fittings that
matched what was on the tank. Nice layout on the tank
support platform.
Old 08-02-2015, 09:44 PM   #45
Chassis: Amtran
Rated Cap: 71
They are bulk head fittings. Great deal from Inca, would have gone that route to had I known.
~Morpheus
Old 08-02-2015, 09:48 PM   #46
Chassis: Amtran
Rated Cap: 71
Grey water tank
I was going to vent my grey water tank through the roof, but now I'm thinking since I have a composting toilet maybe I can just put a length of pvc with a screen over it underneath, nothing nasty in there, thoughts?
~Morpheus
Old 08-02-2015, 10:47 PM   #47
Chassis: I.H.
That is my plan as well. My tanks are 40 gal each.
You might want to cut some of the excess threaded rod below the tanks. Hate to catch them on a speed bump, curb, etc.
Old 08-03-2015, 09:30 AM   #48
Chassis: Amtran
Rated Cap: 71
The excess rod will be cut, after making final adjustments, thanks
~Morpheus
Old 08-03-2015, 12:16 PM   #49
We're going with a Natures Head composting toilet
and it has a vent attachment that goes to the outside
to carry away foul odors. Our plans are to pipe it into
the vent for our grey water tank which goes thru the
roof already. They claim that it produces zero odor when
someone is doing number 2. Also I understand that grey
water can sometimes produce stronger odors than a
black water tank and since odors usually rise you might
not want to be venting under the bus.
Old 08-03-2015, 12:34 PM   #50
Chassis: Amtran
Rated Cap: 71
Thanks Dragonpop, I have Nature's Head as well, and I think using the same vent is a great idea. I did install a fitting on the tank
for the vent.
~Morpheus
