Old 09-13-2015, 12:51 PM   #81
Engine: 190hp 5.9 Cummins
I have a ton of those left over from commercial furnace installs.
Old 09-14-2015, 07:57 PM   #82
LRflip's Avatar
Year: 1994
Chassis: B700
Engine: 5.9L 12V Cummins
Rated Cap: 71 Passenger
Originally Posted by The Nebuchadnezzar View Post
Spent the day adding an underbelly box for the batteries for 600w of solar panels. Turns out a motorcycle lift is ideal for lifting stuff like this.
[IMG]URL=http://s1383.photobucket.com/user/tom_walker4/media/battery%20box%205_zpspqp8uwei.jpg.html]
[/URL][/IMG][/URL][/IMG]
[/URL][/IMG]
thats rad. good work.
I don't negotiate with terrorists...or Canadians.
LRflip is offline   Reply With Quote
Old 09-15-2015, 11:37 AM   #83
Chassis: Amtran
Rated Cap: 71
As promised here are some pictures for detail on how I chose to install this box.
the hanger
[/URL][/IMG]
Nuts jammed together to prevent loosening
[/URL][/IMG]
The box tightened against the floor supports as well as the openings (one on each side) for the air return grates that will be used to provide air flow through the box.
[/URL][/IMG]
[IMG][IMG]
Here is the frame work
[/IMG]
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
The Nebuchadnezzar is offline   Reply With Quote
Old 09-15-2015, 05:54 PM   #84
If you reallllllly don't want those bolts moving you can always use locktite, super glue, or some clear nail polish.
CaptainInsaneo is offline   Reply With Quote
Old 09-15-2015, 11:52 PM   #85
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Engine: DT 466e/MT 643!
Rated Cap: 16
Thanks for sharing! really appreciate the info.
johnbloem1974 is offline   Reply With Quote
Old 10-08-2015, 09:20 PM   #86
Chassis: Amtran
Rated Cap: 71
Solar system progress
Making some progress with the solar charging system. Batteries are in and wired, one big 12v battery now. Cables have been built and run to the electronic cabinet. Solar charge controller and monitor are wired. Have to do some wiring for the inverter, shore power and load center. Getting there.
[/URL][/IMG]
[/URL][/IMG]
~Morpheus
Old 10-11-2015, 06:02 PM   #87
browncrown's Avatar
Rated Cap: 79 at Birth
Nice work on the electrical
BC
Old 10-18-2015, 03:27 PM   #88
Chassis: Amtran
Rated Cap: 71
Finished the solar system
Finally finished the solar charging system, last warm weather project before the cold
~Morpheus
Old 11-01-2015, 12:41 PM   #89
Chassis: Amtran
Rated Cap: 71
Heater help please
"So I replaced my heater hoses (cabin) a while back and relocated the heaters, the heaters sit on there sides now. I finally have good circulation of coolant through the system and no leaks thankfully. One thing that has me confused is that the heater blowers will not turn on. I have the two heater switches on as well as the booster pump switch? I'm confused, is the coolant just not hot enough or do the heaters somehow sense the temp in the bus?
~Morpheus
Old 11-01-2015, 02:17 PM   #90
First, I would grab a test light or voltage meter and make sure you have power to the heaters.
I have never seen a blower motor have any sort of thermostat on it.
