04-29-2017, 12:32 PM
Rated Cap: 42
Need help identifying these lights...
Took out our instrument cluster awhile back. Went to reinstall it and found these two little lights but can't recall what they are. They're on twist mounts but there is nowhere on the cluster that seems like the right place to install them. I'm apparently overlooking something.
The wires seem to run to a relay but they aren't the turn indicators. Those are integral in the cluster
Our bus is a 98 Carpenter/International
Anyone have a clue for me?
Thanks!
Sent from my MotoG3 using Tapatalk
04-29-2017, 12:56 PM
My guess is they would be idiot lights that slip into a warning hole somewhere on your dash.
Robin
Nobody's Business
04-29-2017, 01:30 PM
they probably plug into the back of a gauge for lighting up the speedo or fuel gauge at night.
04-29-2017, 02:42 PM
Rated Cap: 42
Right, that was my first thought, but all those seem to be covered by lights installed directly in the back of the cluster.
04-29-2017, 02:44 PM
Rated Cap: 42
Thanks turf. My response to Robin would also apply here
04-29-2017, 04:42 PM
You see, stuff like this is why I don't take my gauge cluster out. Something bad always happens when I mess with electrical.
Robin
Nobody's Business
04-29-2017, 06:21 PM
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
They are some sort of instrument or gauge light.
Do they come on when you turn on the headlights? If they don't the first time, change one of the bulbs and try again. Eliminate the most probable thing and work to the less likely.
04-29-2017, 06:26 PM
Chassis: Bluebird
Rated Cap: 72 pax
I don't have much choice, mine is cracked in 3 places and being held together with tape.
I am going to attempt to build my own dash... But that will be one of the "finishing touches"
04-29-2017, 06:47 PM
Rated Cap: 42
Ha! Right? If mine hadn't needed resoldering I totally would have left it alone. Plus, there were a number of burned out bulbs, so I went ahead and replaced all of them
04-29-2017, 06:48 PM
Rated Cap: 42
They don't come on with the headlights and don't look burned out, but wouldn't hurt to try a new bulb. Thanks
04-29-2017, 06:49 PM
Rated Cap: 42
Yeah, and even a used one is ridiculously expensive
04-29-2017, 06:50 PM
famous last words
look again
i recall that one of my gauges has multiple lights
04-29-2017, 06:51 PM
Chassis: Bluebird
Rated Cap: 72 pax
Hmm. I know in my bus when I cycle the key to on, all the idiot lights come on.
Is it possible they are some sort of light to alert you that a switch or circuit is on? Like a master switch... My bus has 2 masters, one for all the accessories and one for the flashers. They light up when they are on.
04-30-2017, 06:56 AM
Rated Cap: 42
famous last words
look again
I hear ya. I will check again
Rated Cap: 42
Thanks, I'll look at that
04-30-2017, 02:04 PM
Rated Cap: 42
So I think they must be for the gear indicator (not 100% certain). They reach that far but no further. Just trying to figure out exactly where to install them. I put the cluster back in and all the instruments are working (yay), but I still have no lights coming on with the headlights. Now I need to track down whether I have a fuse out or a bad connection. I'm still open to ideas. Thanks so far for helping me hone in on the problem.
04-30-2017, 04:07 PM
Rated Cap: 42
Alright Turk, oneof the lights came on when I tried to crank it. It probably is telling me that my rear emergency hatch is open. Now I have figure out what hole it goes in.
