01-27-2015, 09:29 AM
#81
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
Im dying to hear if you can really feel a difference in road handling with all those new shocks!
please keep us posted when you finally get her on the road!
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
01-27-2015, 02:46 PM
#82
Engine: 190hp 5.9 Cummins
I love builds like this.
01-27-2015, 04:20 PM
#83
How Did You get Insurance??? I live in Alabama I Can;t get Bus Insur Can Help???
01-27-2015, 05:27 PM
#84
Coachwork: Crown / Pusher
Nat,,, your back
01-29-2015, 07:53 PM
#85
Coachwork: AM-TRAN
Chassis: International 1853
Engine: DT466 210hp, MT643 trans
Rated Cap: 44
Got some more work done and had more parts come in.
74oz of ceramic balance beads and 60' of butyl rubber tape.
Got the new valve stems for the 22.5" rims. Mounted up the 4 rear tires today but I do not have any pictures yet.
Bought a bunch of grease to lube the ole girl up.
Got the plastic piston pieces in so I could finish the rebuild of the wiper motors. I have one completely rebuilt now.
01-30-2015, 12:10 AM
#86
Coachwork: AM-TRAN
Rated Cap: 44
I have have private bus insurance through State Farm.
02-08-2015, 09:43 PM
#87
Coachwork: AM-TRAN
Rated Cap: 44
02-09-2015, 06:45 AM
#88
Chassis: I.H.
Wow! I love those windows! I wish I could put a couple of those in place of what I have!
02-09-2015, 08:01 AM
#89
Coachwork: AM-TRAN
Rated Cap: 44
Depending on where in Florida you are, you might see it soon. If I can get it all finished in time.
02-09-2015, 08:23 AM
#90
I'm near Orlando
02-09-2015, 11:22 AM
#91
Coachwork: AM-TRAN
Rated Cap: 44
You will be pretty close. I plan on being just up at the end of 4 from you if I get this thing finished.
02-09-2015, 12:55 PM
#92
Chassis: I.H.
Which end? I am at the turnpike and Osceola Parkway, about 10 minutes from 4.
02-09-2015, 01:04 PM
#93
Coachwork: AM-TRAN
Rated Cap: 44
North end.
02-09-2015, 10:41 PM
#94
Coachwork: AM-TRAN
Rated Cap: 44
Went out and worked on the bus some today. Got the 5 front roof marker lights off and installed the new reflectors. Ordered another large round of parts.
02-10-2015, 07:46 PM
#95
Coachwork: AM-TRAN
Rated Cap: 44
Worked on the bus some more today. Got the spots for the front lights prepped and painted.
Cut up the new hitch to start the process of making it fit.
Decided to remove the ramp to make it closer to the frame as it had plenty of space. I want to move it up about 2.5". This will give me more options mounting the hitch.
After removing all that I decided to pressure wash the underside of the bus and the ramp. They were filthy and could have used a cleaning. It was dark by the time I finished so I did not take any pictures. I will get some tomorrow.
02-11-2015, 08:48 AM
#96
I look forward to your hitch install.
I hope you disregard all that non sense in that other thread telling people to not drill or mount hitches on the bottom of the frame rails. Almost every vehicle with a hitch mounts it off the bottom of the frame rail.
That other thread about hitch mounting needs to be deleted. No use full info, it might scare some one that don't know better.
02-11-2015, 07:03 PM
#97
Coachwork: AM-TRAN
Rated Cap: 44
I was not aware of said thread nor have I seen it. I can only think on one hand the number of reasons one would not want to mount a hitch on the flange of a frame. My frame is the same 3/8" thickness as my hitch is. Plus, there is a cross brace in front of and behind where the hitch will be mounted. I would have no worries hooking up 20k to this and towing it when I am all said and done.
I did not get as much done today as I wanted. Life has a habit of doing that to me. I got the hitch put in a large band saw and cut down to the correct width I need.
Here is a picture of the rear after I got it all pressure washed.
Had a few boxes start showing up today.
I mostly started cleaning out the back of it. I had a ton (literately) of steel in the back I took out. Also removed the Dana 44s for my ARO project. I still have a huge amount of auto parts in the back I need to take out so I can continue working on her.
02-14-2015, 11:38 PM
#98
Coachwork: AM-TRAN
Rated Cap: 44
02-15-2015, 01:39 PM
#99
Nice and simple, I like it.
Keep the updates coming.
02-15-2015, 05:09 PM
#100
Coachwork: AM-TRAN
Rated Cap: 44
It is cold today and we are supposed to get some snow soon. So I stayed inside and built the new wiring harness for the rear lights. It is a 50' 16 wire harness of varying gauges. This will power all the rear lights, the trailer plug, and the rear camera.
It is all in 3/4" split loom and then wrapped with 3M super 33+ electrical tape.
