Old 06-12-2007, 03:35 PM   #1
BassnTruck's Avatar
Coachwork: AM-TRAN
Chassis: International 1853
Engine: DT466 210hp, MT643 trans
Rated Cap: 44
New here. Here is my Bus. Dialup warning.
Some of you might have seen this bus. It is a 35' 88 International 1853 with a 210hp DT466 and an Allison MT643. And it only has 24,000 miles on it and about 500 hours. I plan on making it an RV. This bus was used on base as transport. It has almost no rust but paint is faded. The paint will polish out nicely. Only came with half the bus seating and it appears that is how it was built. Has a large rear double door and came with two ramps. One is under it and a larger one came inside. It has a 3cyl diesel motor in the rear that powers the standalone AC system. Now on with the pics.
Sorry some are blurry.
Exterior:
Stock Interior:
Moving and modifying the seats inside:
Edit: Fix broken links.
Edit2: Forum seems to be cutting the pictures off on the side.
BassnTruck is offline   Reply With Quote
Old 06-12-2007, 05:25 PM   #2
Steve's Avatar
Re: New here. Here is my Bus. Dialup warning.
Are those seats in your bus made to recline?
Old 06-12-2007, 06:14 PM   #3
oldog12's Avatar
... Now THAT is a nice bus !!!
oldog12 is offline   Reply With Quote
Old 06-12-2007, 07:22 PM   #4
the_experience03's Avatar
Jealous....
Cute Jeep too...and what's with the crane? If that's yours too I'm uber jealous.
Old 06-12-2007, 10:15 PM   #5
GoneCamping's Avatar
With that big double door in the back, maybe you should consider a false wall about 1 foot or so in, use the back as a 'garage' area...doesn't need to be deep, one or two feet is more more than enough. I've seen trailers with something like that on the back... makes for a great place to store stuff like the grill etc....
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 06-12-2007, 11:16 PM   #6
BassnTruck's Avatar
Coachwork: AM-TRAN
Rated Cap: 44
Yes the seats recline and the head room is 6'5".
The rear doors will be taken out and filled in. I have trailers to tow the toys with. I could use the interior space more.
Edit: Removing dead links.
Old 06-12-2007, 11:51 PM   #7
You even have a pit! When can I move in?
Cool picture of the rainbow.
Old 06-13-2007, 08:50 PM   #8
I am not used to seeing a bus with a dog house, but that one seems larger than usual. Is this bus still used as an ambulance?
U-Haul is offline   Reply With Quote
Old 06-14-2007, 04:32 PM   #9
BassnTruck's Avatar
Coachwork: AM-TRAN
Rated Cap: 44
Yes the dog house is large but the whole motor is under it although it does not sit much higher then the floor level. Not currently nor in the future as far as I can tell it is not. Unless you count it hauling around crazies like myself. Then yeah, maybe.
Old 06-14-2007, 10:18 PM   #10
beekay's Avatar
Engine: 5.9
I am envious of a 6-5 interior height. Even room for a little bit-o-insulation unless you have 6-3+ people. I am 6-2+ with a 6-2 ceiling. What type of engine is the aux motor? The windows are an upgrade also. The engine...the trans. Wow, looks great. Good luck.
beekay is offline   Reply With Quote
Air filter warning bus-bro Conversion General Discussions 4 01-08-2012 03:22 PM
OVERHEAD WARNING LIGHTS SCARECROW Conversion General Discussions 10 12-12-2011 06:23 PM
Re-Installing Warning lights.... TygerCub Conversion General Discussions 1 09-19-2009 01:25 PM
My electrical AC/DC panel install <dialup beware> talk2cfs Conversion General Discussions 1 05-01-2008 10:11 AM
Brake Question Warning Light quizbus Conversion General Discussions 0 03-24-2008 08:49 AM
