Old 04-27-2008, 05:00 PM   #41
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Re: new member 1965 chevy
Old 04-27-2008, 05:03 PM   #42
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Old 04-27-2008, 05:05 PM   #43
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
[img][http://i249.photobucket.com/albums/g..._0172.jpg/img]
Old 04-27-2008, 05:08 PM   #44
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Old 04-27-2008, 05:11 PM   #45
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Old 04-27-2008, 05:13 PM   #46
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Old 04-27-2008, 05:15 PM   #47
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Old 04-27-2008, 05:29 PM   #48
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
well i didnt get them all on but i think grinding on the bus is easier than posting pics the bus ass pics shows the job done after the door was deleted the hinges and handles were pulled and filled the door was welded shut and the cracks filled the mlower and upper windows were filled with metal panels and bondoed into a conglomeration which made the bus ass! in still not sure what to do here as there4 is some rust to contend to im seeing checker plate a 3by8foot sheet would do nicely how much do you think that is? some shots of the inside with the new floor the control panel beside the seat is a old road sign i put a circular design on it with the wire wheel and clearcoated it same with the piece on the dash thats the front grill stripped and primed it too had 34896 coats of paint on it you can have that seat shortbus i think you will recognise it the compartment is for the propane it was plywood and rotten i used old roofing panels and the grill that was over the heater next to the seat to vent the tanks recycle! getting close to finishing the final stripping but alas it rains again today this weather is quite odd this spring holding up progress......carry on converting! timbuk
Old 05-04-2008, 10:27 PM   #49
swinada's Avatar
Finaly I got some time to look at your pictures at home. I cant see pictures at work that are on photobucket due to network restrictions, and at home dont have to much time for surfing, need to work on the bus.
How many layers of paint was on that bus? Looks like somebody was very busy with a angle grinder
I'm planing on painting ours in the next couple of weeks.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 05-13-2008, 07:11 PM   #50
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Old 05-13-2008, 07:14 PM   #51
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Old 05-13-2008, 07:16 PM   #52
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Old 05-13-2008, 07:25 PM   #53
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
ok there she is almost totally stripped and bare metal primed the roof has been coated with a roll on rubber membrane called "inland coating" cut apart a emergency exit door from a school reno and rivetted the piece on the bus ass with 3/16 rivets cheaper than checker plate and has the tank look a bit of rust there but not bad she has a few battle scars but some cheese and some primer coats and she will get the paint i think i will go over the brakes and the susp now repack all the bearings and just go over the whole thing ill take shots of the job for the old skoolers ill put in new brake lines and cylindersetc for piece of mind thanks smitty and good luck with your paint swinada timbuk
Old 05-28-2008, 10:25 PM   #54
Inland Coating. What made you chose it for the roof of your bus and how do you like it now that it is on the roof? Did the application go well? Any problems or details worth mentioning that you noticed while rolling the material on your roof? Prep work? I still need to do the roof on my bus and I have been planning on a bright white ceramic paint...but I may reconsider depending on what you found with your application of Inland Coating.
Abbott is offline   Reply With Quote
Old 05-29-2008, 11:40 PM   #55
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
hi abbott i just powerwashed the roof and wire wheeled t ehere it was rough it already had a coating on it of some kind and it was not coming off maybe it was snowroof? i just rolled it on with a roller it leaves a textured finish the stuff i has was grey and it is fumey but liked it dried quick enough comes from a roofing supply place good luck with your roof timbuk
Old 05-31-2008, 09:22 PM   #56
Thanks Tim. Vancouver Island BC, what a nice place to live!
Old 07-23-2008, 07:27 PM   #57
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
there you go 1965 brakes!
Old 07-23-2008, 07:36 PM   #58
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
theres the front tire with the brake drum and the hub very difficult to remove and seperate i hurt myself and was sore for a week had to use heat and pound the studs out then i had to order studs from ontario...... had to order in the wheel cylinders in also 150 bucks for 2 got the drums turned the shoes look good sanded them a bit having a hard time posting shots lately but am still working it ! getting some of the bodywork done front clip had been worked on before i ground out the glass job and welded in metal got a new door installed and put some new led lights on ripped out the old stove for a top burner style with no oven there is always progress at timbuk acres
Old 07-25-2008, 12:42 AM   #59
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
[img][http://i249.photobucket.com/albums/g...208.jpg/img]ok there is the power plant pretty much untouched exept for carb and fuel pump it runs great this is before pic
Old 07-25-2008, 12:44 AM   #60
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
a new door sat in buddys body shop for 8 years fit in in 10 minutes
1965 bluebird parts needed grevers911 Conversion General Discussions 6 07-18-2017 12:57 AM
New Member - Okla area - 1986 Chevy G30 Shortie GoldenGate Short-Bus Conversion Projects 7 12-15-2009 11:43 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-24-2007 11:58 PM
1965 ford busette d_codebreaker Skoolie Conversion Projects 19 10-30-2006 02:18 PM
1965 BlueBird FS EldoMike Classifieds | Buy, Sell, Swap 3 01-18-2004 12:46 PM
