Old 12-02-2003, 02:54 PM   #1
new project too
HI to you all ,
since i saw that site,forum ...im all excited !
I just bought a wayne lifestar flat nosed , dieseled powered , 38 feet , school bus to convert it to an rv for mutiple uses ...
the last 13 feet will be use as a garage for my Jeep (for now)
im looking for a smashed rv to use all the convenience in my bus !
I plan to convert the rear suspension to an air ride conversion to ease the jeep entry, by lowering the rear end at my wish...
im new to this ,but have done so many projects in my life ,that it should be another fun one ....
sorry for my english faults ,,,,im mostly french! ,
Dan 8) & Sylvie :D
1990 wayne lifestar , 38 feet, skoolie ,diesel, allison auto,
As long as it s outdoor : jeepin , riding, rving,
we love it all!,
bigdan is offline   Reply With Quote
Old 12-05-2003, 08:25 PM   #2
Send a message via MSN to Rainforest
I've seen the Jeep hauler done before. The stock suspension will hold the weigh fine. Neatest one I saw used the back end of the bus as a fold down ramp.
Dave (Rainforest)
Olympic Penninsula
1975 IHC/Carpenter
Rainforest is offline   Reply With Quote
Old 12-08-2003, 12:21 PM   #3
Hi Dave,
I wish I could do this but the jeep weights about 3500 pounds ...I dont think the back end cap could take the weight when loading unless I reinforce from the inside with welded on solid ramps ....
dan
Dan 8) & Sylvie :D
we love it all!,
Old 12-08-2003, 02:42 PM   #4
lapeer20m's Avatar
the school bus is no standard rv. You can load your jeep with no problem. The bus is on an extremely heavy duty chassis! I have a jacuzzi inside my bus weighing in at over 4 thousand pounds. Don't underestimate the strength of the skoolie. The Frame is heavy duty, and there's 2 beams that goe up the wall, across the cieling, down the other wall, and across teh floor for every window. There are two more beams that run across the ceiling the entire length of the bus.
As a comparasin, you can look at a typical trailer that you might use to haul a jeep, and you'll see that the skoolie is far superior in the strength.
The only question i have is will the jeep fit inside??
Old 12-08-2003, 02:55 PM   #5
A standard CJ type fits fine as the front wheels will rest on the wheel wells.
Dave (Rainforest)
Olympic Penninsula
1975 IHC/Carpenter
Old 12-08-2003, 03:30 PM   #6
I ll fold the windshield down and modify the roll bar to fold in some way ,because the jeep is 7-3" high on 36" tires .... but width wise no problem at 68" ....and this way if it breaks no trailer to tow...
still leaves about 19 feet to live in ..... and a 13 feet room at the back for rainy days ...
Dan 8) & Sylvie :D
we love it all!,
Old 07-29-2004, 09:46 AM   #7
trx
trx's Avatar
Chassis: Chevy C-60
Engine: 8.2L Turbo Detroit Diesel
Send a message via ICQ to trx
Maybe you can get some ideas for your jeep hauler from my project. Here's a link to the photo gallery: http://trx.punknet.org/gallery/skoolie I did a considerable amount of fabrication, enough that I hope I don't have to do it again (at least any time soon). My bus hauls my 5000 lb IH Scout II without a problem.
Chad
trx is offline   Reply With Quote
Old 08-01-2004, 07:49 AM   #8
Vern1's Avatar
Engine: 345 IH gas
Rated Cap: 66 passenger
Greetings,
After I completed my conversion it weighed 15550 with a full tank of gas and 95 gallons of water onboard.
The listed GVW for the bus is 26000.
That leaves a little over 5 TONS of capacity.
I don't think a jeep would fill that!
I would be careful about weight balance as most of the weight (the heavy stuff like jeep, ramps, etc.) will be behind the axle and may make the front end light and cause weird handling.
Of course, you will add living quarters and that will help.
Just a warning to give you something to think about.
Have fun and post pictures as you progress.
Cheers,
Vern1
http://www.pettypb.com/bus
Cheers,
Vern1
1976 International Wayne - ON THE ROAD!!
Vern1 is offline   Reply With Quote
New Bus with No Name Project Redbear Skoolie Conversion Projects 3 04-24-2010 09:55 PM
First Project salee05 Skoolie Conversion Projects 0 09-02-2009 10:25 PM
My bus Project With a new name.... Kirbystud Skoolie Conversion Projects 12 08-20-2009 10:55 AM
My new project...maybe lapeer20m Everything Else | General Skoolie Discussions 9 04-17-2006 08:03 PM
Trade 1970 VW Karmann Ghia project for skoolie project bus? shortwaverunner Classifieds | Buy, Sell, Swap 3 02-03-2006 09:56 AM
