06-14-2015, 06:21 PM
#21
Originally Posted by 64crew4x4
One BIG reason for the Coolant lines inside Vehicle....Inside lines stay warmer in winter weather....If it is below freezing outside and the lines of fluid Are travelling 35-50 ft up to the front, they are cool by the time they get to front heat...;) In Bus, that won't happen... just one silly mechanical point of view....lol
Hmmm, I hadn't thought of that, not really planning on running it in freezing cold weather, but a good consideration all the same. I just don't like the idea of having something that could make that big a mess in the living space.
06-16-2015, 03:39 PM
#22
Chassis: MPV Pusher
Engine: 8.3 Cummins Mechanical
If running Rubber hoses up thru cab space, convert to Solids.....;) Easy to plumb into and t off of anyplace you need to run a Heat source Tap....;) I have not looked at mine yet to see if it is already steel or rubber
06-16-2015, 03:46 PM
#23
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
I ran mine underneath because I didn't plan my interior space to have the hoses run inside. If I were to do it again I'd run them inside. Takes less hose, would be easier and puts the heat where you want it.
Unless, of course, you're using your heater loop as radiators #2 and 3 on a summer road trip like I'm doing in a few days. Then run them underneath.
06-16-2015, 04:07 PM
#24
Engine: 3208 turbo Cat
Hey porkchopsandwiches, that is a good Idea, removing the rear heater and installing it underneath the bus for auxiliary radiator.
J
06-16-2015, 06:15 PM
#25
Chassis: Amtran
Rated Cap: 71
Just replaced mine with new hoses, old ones had a bunch of repairs and I too didn't want them leaking once finished. Front to back (RE).
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
06-16-2015, 09:14 PM
#26
Engine: 190hp 5.9 Cummins
J
I have done that on a few of our rides here on the farm.
The best one is the tree spade truck. It always over heated due to the fan not pushing enough air through the smallish rad while sitting stationary digging a tree, revved up.
So in a pinch I used two of the rear heater units out of my first bus plumbed into the heater lines. Never heated up again.
The hottest place to draw hot coolant from on a 5.9 Cummins is off the back of #6 piston. This is part of what helps the 5.9 cummins engine in buses last as well as they do, compared to the same engine in a dodge truck. Dodge trucks never pulled coolant from #6 piston.
There are also ports for more lines behind the thermostat, coming directly off the engine block on the front of the engine.
Manny rear engine buses have a 12 volt coolant pump plumbed into the heater lines. This ensures that the flow is sufficient to carry the heat needed with all the added restriction of heater cores, long lines, 90% elbows, ect.
The 12 volt pumps can be set to trigger, and start pumping by the same system that starts and stops a electric fan on a automotive radiator.
That same system is what also triggers the fans on the bus heaters.
07-26-2015, 12:34 PM
#27
I was hoping to get the floor treated with Ospho and painted in the next few days, so I could let it dry during August as I am away, but I'm having a surprising amount of trouble finding Ospho at any local stores. I can find it on Amazon, but it's through a third party seller and wouldn't get here for over a week. There are a bunch of other options for rust treatment available at local stores, but from what I've read on the forum Ospho seems to be the one most people think is the best. I want to make sure and do this right, anyone have any alternatives they liked that Home Depot or Lowes would carry?
Also, planning on treating the frame and parts of the engine that are rusting with Ospho, any pros/cons to this?
07-26-2015, 12:40 PM
#28
They don't have anything like ospho at my local HD or Lowes. But all the Ace Hardwares and True Value stores have it. Lots of auto supply shops may have it too.
Just look up your local auto paint supply store.
07-26-2015, 12:49 PM
#29
I tried True Value and Do It Best, Ace is closed today, I'll try them tomorrow. The guy at the Sherwin Williams store knew what it was and said he could order it in, but it would take a week to get here.
07-26-2015, 12:52 PM
#30
Chassis: MVP
Engine: CAT 3116
I got mine from the local Benjamin Moore paint store, and the local ACE hardware store also has it.
Home Depot sells Corroseal ( Corroseal Rust Converter | Metal Primer | Rust Paint) that works very well, but it is $$$.
07-26-2015, 01:03 PM
#31
Originally Posted by Piersg
Corroseal is sold online only at HomeDepot I was also under the impression it wasn't as good as Ospho based on a previous thread I was reading - can't remember the reason though. Is it actually just as good?
07-26-2015, 01:24 PM
#32
Chassis: MVP
Engine: CAT 3116
Interesting, my Home Depot here in Miami has it on the shelves. I have no idea if it is as good as Ospho or not. It looks like it is a converter and latex primer all in one as opposed to Ospho which is just a converter.
I used Ospho and it worked well.
07-26-2015, 02:14 PM
#33
Chassis: Amtran
Rated Cap: 71
Amazon routinely quotes longer times than actual for shipping, makes me wonder if its to get more people to sign up for Prime anyway when I ordered Ospho back in November it arrived the next day. Good Luck.
~Morpheus
07-26-2015, 09:38 PM
#34
Nice bus! I am looking foreword to watching your progress.
07-26-2015, 10:15 PM
#35
HD offers "pick up at nearest store" option. You buy it on line & have it shipped to your choice of stores. Check & see if that saves time.
07-27-2015, 05:04 AM
#36
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
It usually does. Last summer, I ordered a lot of stuff that way (to usually stop annoying the UPS guy since I lived in a 3d floor walk up).
07-27-2015, 02:15 PM
#37
Engine: 8.2 Detroit Diesel
Great job keep up the good work, these things take time.
07-27-2015, 02:18 PM
#38
3 stories around here is a high rise!
We've got 1 elevator in our town, and it's in the courthouse!
07-27-2015, 04:48 PM
#39
Engine: T444E/AT545
Rated Cap: 75
I live in Atlantic County, most of our high rises are down by the ocean...and several of them are bankrupt, and empty, eyesores.
He wasn't thrilled when the 5 gallon pail of Bus-Kote and two gallons of primer were delivered. And, frankly, I don't blame him.
07-27-2015, 07:39 PM
#40
Ended up ordering the Ospho from Amazon. Hopefully it gets here in the next few days, it says it shipped today, and it's coming from RI to Upstate NY (where I am right now), so not far distance wise at least.
Spent some time prepping the floor for the Ospho, and my wife is working on getting the last of the stickers off the outside. A torch gets them off fast, but leaves a massive amount of residue. Goof Off on the residue sort of just smears it around, we're getting as much off as we can, hopefully it doesn't effect the paint job too much.
Took the Stop Sign assembly off. Had to drill out the metal insert that attached it to the side of the bus.
Oh, and it was wicked hot out today.
