Didn't get everything I wanted done this weekend. I was able to do the floor and get it ready to fill in the seat holes and then for primer and stop rust. and 1 side of the walls AND was still able to verify my back was still there and not in the shape it use to be in.
Anyway on the windows I was going to re seal them but what about the upper part? the windows have a window rubber foam type seal. Do you guys just replace while you are there or if it is still solid to bus (stuck too) and seams good shape (other than looking dried out) just leave it?
If you do remove it what helps to remove it. GOO GONE and razor blade any good or is there something diff that works better?
thanks
