04-27-2016, 02:53 PM
#121
Chassis: international
Rated Cap: 71
And ya air bags... Way cool. I have clearance in the wells already (cant fit head though.... Too big) and then the bags kick in give that much more and then I can fit
04-27-2016, 03:22 PM
#122
Mmmmm... air bags.... jealous!
Yeah, I haven't even started a build thread. Actually I haven't done much to this bus either. It has been impressed on my mind that I really really need insulation. This many windows really sucks the heat up during the cold spells and I'm not sure the OEM insulation is effective at all. I'll test that theory when I get all the panels and insulation out, right before I insulate the begeebees out this thing.
04-27-2016, 05:07 PM
#123
Jeez Louise that sounds scary! Tell us that you're not really trusting your air bags to not crush your head or chop it off. Get a jack; you'll find uses for it.
04-27-2016, 08:25 PM
#124
Rated Cap: 71
I have been told I have a hard head so I should be good...... I only checked under there when I bought the bus. Never stuck my head in to far just enough I could see the wells good. Any work I need to do in there it will be raised then blocked. I try to be as safe as I can.
04-27-2016, 08:34 PM
#125
Rated Cap: 71
I used the 1" tin foil foam. That made a big difference from what was in there. Shrunk down the # of windows and Blocked out 8 and will insulate those as well.
04-27-2016, 11:59 PM
#126
Yeah, there is just something wrong with this much glass during the coldest part of the winter.
04-28-2016, 06:03 AM
#127
these busses have Lots of heaters.. at least mine does. . 6 heaters i think...
im not sure why people dont just leave their Bus heaters intact and then make a small boiler to heat the loops when the bus isnt being driven... even can make a small wood fired boiler so theres no big ole smoky wood stove inside... ..
what are air bags on a bus?
04-28-2016, 06:29 AM
#128
04-28-2016, 06:56 AM
#129
oh I got it! thanks.. I was thinking it was something different.. LoL..
I have that on mine
04-28-2016, 07:04 AM
#130
After hearing from some full timers in a school bus, I almost think its a necessity.
04-28-2016, 08:03 AM
#131
Rated Cap: 71
I have that on mine
They have the airbags for this style too lol
04-28-2016, 08:04 AM
#132
Rated Cap: 71
Not what I'm using mine for though.
04-28-2016, 08:06 AM
#133
Rated Cap: 71
I tell you what bringing the bus home was a completely different ride then what I remember a bus as. Very smooth. I'm glade I have them. Didn't realize they even put them on busses. So bonus for me.
04-28-2016, 01:19 PM
#134
Chassis: Thomas
Engine: Cat 3126 7.2 / Allison AT545
Rated Cap: 77 Passenger
I have the same lock on the outside of the front entry doors. I just have to push in on the door from the outside and the key will turn. I think the doors just don't line up perfectly so you've got to push on the door kind of hard then try to turn the key.
That's interesting about your model of bus. My door is air, as are the brakes. This is a pretty small bus to have air brakes. I've had a number of buses with hydraulic brakes.
I'm curious to know your tire size. There are several models of this bus that look the same, but some have wheel wells on the interior floor and some don't. It seems the buses with 19.5" tires are flat floors while the same bus with 22.5" tires has four wheel wells to deal with during the build.
I am kind of a minimalist, but I've also been caught needing a bathroom when there is none. I'm coming around slowly.
Do ALL buses have this external lock situation? this is something I have been wondering because if my bus has one I CAN NOT find it!!??
04-28-2016, 01:37 PM
#135
my little bus is Air brakes too... I looked at busses with 4 more rows than mine that had hydraulic brakes.. maybe its a handicap bus thing?
04-28-2016, 02:23 PM
#136
That's a good question. I'm going to assume the actual locking front door is from the chassis producer because the ignition key also fits the door. No, this is my first bus with a locking front door. Before I was using two large eye bolts that I could lock with a chain from outside to keep the two doors locked.
I'm thinking your experiencing 20/20 hindsight right about now, not unlike the rest of us. There is always something better that would be an advantage. In my case locking doors are pretty cool. With deadbolts on the two rear doors, allowing key entry, I'll feel pretty secure until someone comes through my top hatch.
Zo, vee hav disgust einsfhart and ausfhart of zee busss.
04-28-2016, 09:09 PM
#137
Rated Cap: 71
Air bags? I didn't get any air bags and I probably need them more than most. While I don't like dealing with wheel wells I sure could use the extra clearance. Eventually my driveway scare will get big enough that it doesn't scrape anymore.
right now the bus is basically empty no weight really to speak of. That said went out today fired the beast up just to blow out any bugs. Airbags kicked in. Fully aired up it gives me about 8" from tire to fender. Didn't measure inside the well but probably have about an acre or 2. It has shocks as well and what's cool is if the bags blow out the shocks will help but I still have tire clearance until I can get to a safe spot to stop if needed.
04-28-2016, 09:15 PM
#138
Rated Cap: 71
Bags Fully deployed
04-28-2016, 09:19 PM
#139
Rated Cap: 71
Got last of the windows cleaned and re installed
04-28-2016, 09:22 PM
#140
Rated Cap: 71
Finally getting the walls pur together. Slow but getting there.
