Old 05-04-2019, 10:07 PM   #1
NR Tow Pig
Bought this old Thomas a few months ago and havenít had much time to get stuff done due to work and weather. But today i was able to get it cleaned out and the holes in the floor covered up and the floor coated. Going to do another coat in the morning. Then Iíll frame it in, insulate and put down subfloor.
NRdomepiece is offline   Reply With Quote
Old 05-04-2019, 10:11 PM   #2
I did add a hitch to the back bumper a couple weeks ago. Itís welded to the bumper and the plate behind the bumper.
File Type: jpeg B1BC23EC-A087-49F6-A931-D0013CC7978E.jpeg (400.3 KB, 31 views)
File Type: jpeg F81CBC5F-D66F-49A3-9D25-0607B4B30D32.jpeg (212.2 KB, 34 views)
File Type: jpeg 6C402893-EE1C-4E52-A03D-B279C2F84586.jpeg (249.8 KB, 29 views)
Old 05-04-2019, 10:18 PM   #3
Oh and I used the factory Air Ride seat base and modified a 94 Chevy bucket seat for it. So now I have a power seat on Air!
File Type: jpg 5B80A039-0435-43DB-BD59-2370ACF1223C.jpg (258.6 KB, 26 views)
File Type: jpeg F25B3BEC-A59A-49FB-B5C6-4E75458DAAE9.jpeg (261.9 KB, 26 views)
Old 05-04-2019, 10:31 PM   #4
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Nice looking bus! Whatís your powertrain?
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 05-04-2019, 10:32 PM   #5
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
I had my truck's bumper blow out on me, and I built my own. The inspector guy said it had to be "flat, with no extrusions that would damage another vehicle upon impact." That was Hawai'i. Just my 2Ę
And does that mean the bumper is now welded to the frame?
Old 05-04-2019, 11:31 PM   #6
I don't know what bus he has because he hasn't filled out his profile in the UserCP.
If it's anything like mine, which I did the same as him, but behind the bumper is not a plate, but a "U" channel bolted to each side of the frame. I have a plate to weld on top of the "U" channel and the receiver welded to that plate. My pin access will be behind the bumper , keeping the exposed short to avoid knee banging. That access hole will be hinged with the license on it.
Old 05-05-2019, 11:56 PM   #7
Itís got the 8.3 liter Cummins diesel pusher. I believe the trans is the Allison 645. 🤷🏻*♂️ Canít remember.
Old 05-05-2019, 11:58 PM   #8
Iím a long ways from Hawaii. Lol. I donít know what the difference would be between a little bit of hutch sticking out or a receiver and ball sticking out all the time like most pickups do. If it becomes an issue Iíll rebuild the whole bumper and flush mount it.
Old 05-06-2019, 12:01 AM   #9
I filled out my UserCP. Didnít know that was a thing. Mine has a flat vertical 1/2Ē thick plate behind the bumper that bolts onto both rails and the bumper bolts to it.
Old 05-06-2019, 12:05 AM   #10
I got the second coat on the floor this morning. And started putting my subfloor framing together and even got a little bit of insulation down. Probably wonít get anything else done this week. Itís supposed to rain all week. And i have head gaskets to do on a Ford ranger to help fund the Tow Pig.
File Type: jpeg E4043DC1-F732-4CDD-9103-B60759EE7A45.jpeg (188.3 KB, 19 views)
Old 05-06-2019, 09:02 AM   #11
Yukon Cornelius's Avatar
Nice Looking Rig, Can't wait to be back near civilization and scavenge a replacement seat for my rig.
Yukon
Handyman and Shenaniganizer
http://www.skoolie.net/forums/f11/97...ion-22324.html
Yukon Cornelius is offline   Reply With Quote
Old 05-11-2019, 08:00 PM   #12
Me and the ol lady got 5 more sheets worth of framing, insulation, and subfloor down today. We are going to start taking windows out and re-sealing them tomorrow as well as pull the sheetmetal off the walls and the insulation out of them. Hope to get some metal Monday to fill in the outside where we are getting rid of windows.
File Type: jpeg 1B534FF0-FFF1-4602-B4D8-7C3B27EEA1B8.jpeg (219.2 KB, 21 views)
Old 05-12-2019, 04:39 PM   #13
Well we decided to tackle the windows another time. We did get the floor down to between the front wheel wells. Weíll do the last 6 or so feet later.
File Type: jpeg 6BCA57A6-3297-4161-AD6D-05432C701B26.jpeg (233.4 KB, 13 views)
File Type: jpeg 12EDE455-70B4-4D41-9A0C-52E3F3142031.jpeg (210.3 KB, 11 views)
Old 06-17-2019, 11:57 PM   #14
Doesnít seem like we e got much done lately. Been busy working on customer cars and works been kicking my ass. We did pull all the windows we plan on getting rid of Saturday. Unfortunately we had to set them back in because of the chance of rain and no one had 5íx10í sheets in stock.
I did start framing the Queen size bed base in and set the fresh water tank in.
File Type: jpeg 51E59C0E-CE00-4A0F-AACF-A3CE73AE3E86.jpeg (196.2 KB, 23 views)
Old 06-23-2019, 11:32 PM   #15
I got one of the factory engine A/Cs mounted above the back window. Still have to plumb it in and wire it up but it should be out of the way and hopefully provide some cooler traveling when needed. The other A/C unit will go up front above the windshield.
I also figured out where Iím putting one of the engine powered heaters.
Hoping to hit this thing pretty hard this week as i only have a month before the first show I plan on using it for.
File Type: jpeg A10EBD56-AF56-4987-B32C-350F99ADC896.jpeg (245.8 KB, 16 views)
Old 06-24-2019, 11:43 PM   #16
Finally got the metal I ordered. 5x10x18 gauge. Had them shear them right down the middle. So i have 4 pieces of 30Ēx10í. Which is just barely longer then 4 windows.
I did manage to get 5 windows covered up tonight. I still have some more screws to put in but i kept breaking drill bits. So the bottoms are screwed in tight and Iíll get some more bits tomorrow and do the vertical pieces.
File Type: jpeg 89B00DEE-852D-40EB-AAF0-3F885EA06A56.jpeg (213.6 KB, 8 views)
Old 06-25-2019, 12:49 AM   #17
Nice, I wish I could have gotten 5'er's and do what you did. Instead I have a bunch of "scrap" 18" wide.
Old 06-27-2019, 12:12 AM   #18
The 5í sheets were definitely worth the wait.
I got the rest of the screws put in on the passenger side. Iím going to have to break a piece for the tops of each window and acres them into the window frame and then i can screw the sheetmetal into it at the top. Only way i can think of to fasten the top without taking roof rivets out.
I also cut the two pieces for the other side tonight. Hope to get some help tomorrow night and start getting them put in. Maybe get the walls and ceiling spray foamed next week.
File Type: jpeg 40BAB578-AAA3-4047-8091-10BD6BCC60A5.jpeg (248.5 KB, 9 views)
Old 06-27-2019, 12:40 AM   #19
What are you screwing the tops of the skins to? Since the window frames didn't require screwed frames, there really isn't anything to secure it to. I ran the skin up against the bottom of the roof rivets on the inside and will have the welder tack the skins to the backs of the rivets and then sealer on that edge inside and a copious amount up under the roof drip edge.
Old 06-29-2019, 05:52 PM   #20
You are correct. I plan on using some of the left over sheet metal and cutting it to the length of the window. Iíll rip them down to about 3Ē wide and bend them on the brake into a 90. Iíll self tap them to the window frame inside the bus then add screws to the top of the sheets from the outside. There will be plenty of Mastic and silicone to seal it up.
