Old 01-07-2014, 11:13 PM   #11
Re: Off-grid traveling family dreams
Nate, I suggest you don't know anything about what Tango and I and several others can do, have done and what training we have. You are welcome to your opinion but it seems to me that for the most part that is just what it is. You go on and on about "doing it the right way"--as long as it is your way. If several of us are warning a new member about possible pitfalls I'd think you would be right there along with us trying to protect them rather than encouraging them to pay their money and take their chances.
ol trunt is online now   Reply With Quote
Old 01-08-2014, 09:09 AM   #12
Skip's Avatar
Engine: 366 6.0L V8
You guys are gonna scare 'em off just with your bickering
Originally Posted by wmkbailey
Welcome to the maddness.
Skip is offline   Reply With Quote
Old 01-08-2014, 09:28 AM   #13
JakeC's Avatar
LMAO Nat... I see you still don't understand the concept of tact. Do you seriously have to be so condescending and belittling when people have an opinion different from yours? It reminds me of someone else, just from a different angle. They gave her a caution, which was wise. Most people don't have the fab skills or engineering knowledge to pull off a slide-out. If they do have the ability to pull it off, they are well aware they have the ability and will be able to say "thanks for the caution, but we are capable of doing this." Quit thinking your word is the end word. You aren't the smartest one here, and are turning this lady's thread into a pissing match.
Brutus
Old 01-08-2014, 09:39 AM   #14
Hey Guys --- I'm in no way discouraging anyone from building anything they need or want into/onto their chosen platform. All I am saying is think it through before you go cutting up any engineered structure. I will stick with what I stated earlier in that any such mods, whether a slide-out or a roof raise... "requires some serious engineering thought". As noted, I consulted with a BlueBird factory engineer prior to raising the roof on my All American by 19" and got excellent guidance including his advice on maintaining the integrity of the endcaps as well as staggering the cuts on the roof bows to avoid a "weak line" and also some very good suggestions on how to attach the raise without dramatically altering the loading of the structure. It turned out very well and was not only "solid" but properly flexed and transferred the loading as it should. With a little research and proper direction, just about any mod can be accomplished without negatively impacting safety or structural integrity.
BTW...I used to fly aerobatics in small, high powered craft designed to function at the extreme edge of their engineering limits. In working with qualified A & P mechanics on them I came to especially appreciate how a "small" modification in one area can upset everything else. Example there...adding a small amount of steel to try and stiffen & beef up the engine mounts on a highly modified Pitts S1B seemed to me a minor and sensible adjustment. The A & P knew otherwise in that it would transmit excessive torque & vibration to the airframe that could push it beyond its' limits unless other measures were taken elsewhere.
I know these old buses don't get pushed that hard, but they do share a common characteristic with the aircraft in that they were originally designed & engineered to handle a specific set of loads a certain way. Any alterations made need to take that design criteria into account if anything remotely close to the original load specs are to be maintained. And while I am NOT a structural engineer, cutting away large sections of the primary structure on both sides certainly seems to qualify as an "alteration" to that original design.
Can it be done safely and satisfactorily? Absolutely! But it does need to be done thoughtfully...not casually. That's all I'm sayin'.
My dos centavos.
Old 01-08-2014, 09:46 AM   #15
JakeC's Avatar
Very well-worded and wise advice, indeed. For what it's worth, the thread that Nat posted has some EXCELLENT info in it. A very good example of one way to build a slide out and probably the best one I have seen as well. Not to mention the fact that his fab skills are pretty much eye candy.
Brutus
Old 01-08-2014, 09:54 AM   #16
wmkbailey's Avatar
Engine: 3126
Man, now you have me wondering if I should do a slide out.
I could not find the link I had for the slide out. Most of my Bus links no longer work.
They bascially took a section where the windows are and did what they called a pull out. Just the width and height of the bed.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 01-08-2014, 10:35 AM   #17
That's what Sir Trunt did made room for his footsies
Old 01-08-2014, 10:59 AM   #18
JakeC's Avatar
Originally Posted by lgonzalez
in regards to the slide out comments...what if we plan on doing above floor slide outs and not flush ones? Are your worries based off of uneven weight distribution? We plan on adding levelers for added support.
The concern has probably been explained enough, lol... Hopefully the bickering didn't scare you off. I would think that doing an above floor slide out would simplify things substantially. For one, it would make it easier to seal, in my mind, and more importantly, you would be able to keep the chair rail. That would make the engineering simpler, as the chair rail adds a fair amount of structure and leaving it would mean you were modifying the original design that much less. It would also be fairly simple to tie reinforcement into the chair rail.
Brutus
Old 01-08-2014, 11:42 AM   #19
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Boy I have to step away for a few hours & look what happens
Old 01-08-2014, 07:22 PM   #20
and welcome to skoolie.net see how much fun it is
Solar vs. Grid usage inkblots84 Conversion General Discussions 0 02-24-2013 04:31 AM
Feedback on a newbie's dreams Diesel Dan New Member Intros - Say Hello! 2 08-09-2011 04:25 PM
going off grid > electrical writejill Conversion Tutorials and How-to's 0 05-04-2011 09:48 AM
Off Grid Water lornaschinske Conversion General Discussions 32 05-30-2010 07:21 PM
bookmobiles and dreams PRyberg Classifieds | Buy, Sell, Swap 6 03-27-2004 08:12 PM
