Originally Posted by CaptSquid
Leave the rubber down. It's good insulation.
We thought about leaving it down. But had seen where a lot of them had rust under them so we decided to pull it up and see and glad we did. it was wet under some of it and it did have rust under the rubber. Not bad but glad we found it so we can seal it and start fresh. we are going to lay insulation board down then plywood then what ever we decide to put down on top of that not 100% sure what that will be.
It is a lot of work pulling it up and getting the floor ready but I think it will be worth it in the end.
