11-09-2016, 07:37 AM
Our bus
My girlfriend and I are converting a 97 bluebird we won on an auction this January. I have been getting invaluable help from these forums and figured I'd post a few pictures.
Bringing the bus from Seattle to Michigan
Gave these away for free on CL if they took them all
Ripped up the floor
11-09-2016, 07:42 AM
Ripped out the walls
Ripped out the ceiling and cleaned the floors
Primer
11-09-2016, 07:55 AM
Painted floor
Insulated floor
Sub floor
Insulated walls and attached studs
11-09-2016, 08:02 AM
Freshwater
Bed
Grey water tank
Where it is going to be once I run plumbing
Ac
Took a break
Canceled some winders
This was before canceled winders
Pooper
Where the wood stove will go
11-09-2016, 11:13 AM
Engine: 6.5L Turbo
Great looking build! Where did you get your Grey water tank from? I like that style of tank!
11-09-2016, 12:43 PM
Chassis: IH
Looks like a salvaged road tractor fuel tank and brackets.
11-09-2016, 12:45 PM
Rated Cap: Your mom +1
Thats a hell of a start on your build. Keep up the good work.
11-09-2016, 12:50 PM
love the progress!
what is this black underlayment?
11-10-2016, 09:39 AM
The grey tank is a fuel tank from a semi truck. 110 gal I think. The black underlayment is roofing felt.
12-07-2016, 09:38 PM
Wood stove. Half inch concrete board with 1 inch spacers and steel heat shield
12-08-2016, 09:08 AM
Man I wish I had room for a wood fired stove. Not even room left for one of the tiny-toy ones that have to be fed hourly. Too bad the pellet stoves are so danged expensive.
01-02-2017, 03:48 PM
Chassis: TC 2000 bluebird
Engine: 5.9 cummins
Hi Eric, did you make it to MI? How os the build coming?
Bill
Birch Run, MI
01-02-2017, 05:14 PM
On the plus side....
You can survive the winter with 4 candles & a cigarette lighter!
01-02-2017, 10:42 PM
Bill
Birch Run, MI
Yes I drove from Renton WA to Kalamazoo MI in 3 days. Been back since January. I'm in Kzoo if you're ever on the west side of the state. I am currently working as much as possible cuz it's cold out and OT is approved. Just a quick note about my lifestyle. I work for a big corporate cell phone company that im not super fond of. A few years ago I was in a financial hole and was able to make good money at the job so I took it. I was able to make my way out of the hole and with the extra money I'm making now I am trying to have a few years of freedom traveling and living out of a bus. Sept 9th of 2017 I will be vested with my 401k so I'm not taking off til then. I will work more on the bus when it warms up this spring but whatever I don't finish I will be able to crank out when I quit my job
01-03-2017, 02:04 PM
Chassis: Mini Bird (8 window)
Rated Cap: 24 +1
Looks amazing! All the hard work will be worth it once your enjoying the wonders of life on the road
01-04-2017, 11:09 AM
Engine: 5.9 cummins
Sounds like a great plan. If you want to see a TC2000 "mostly" converted stop in to Birch Run (between Flint and Saginaw) and I can show your ours. We hope to use it for the first time this spring.
Bill
01-30-2017, 09:16 AM
Wood stove installed. 3 ft removable extension on top. Double wall black pipe goes up to cathedral box with 18in class a pipe and the dektite rubber flashing as recommended by someone on the forum. Had a nice toasty fire.
01-30-2017, 10:15 AM
Now that looks like a chimney done right. Enjoy the fire!
02-02-2017, 09:31 PM
Engine: 5.9 cummins
I am envious. Its too cold here in MI to work on the bus this weekend. I too was unable to save the space for a woodstove. I did get the roof hatch replacement bolted on last weekend though. It is a Lewmar 70 marine ocean hatch. As soon as it warms up a little I'll install the inside screen and shade.
Bill
02-02-2017, 09:52 PM
Year: 92
Engine: DTA360 5.9L
you are doing great work in a couple months time. agreed with tango, superb stove pipe/chimney setup with the flashing. exactly how it should be done.
