Old 01-28-2014, 12:37 PM   #121
Re: Our Bus, Our Home
Hi guys! The build looks beautiful, I keep referring to your pictures to plan mine. I was wondering if you could share the measurements of your bus from drivers seat back. I'm getting stuck on my floor plans and can't seem to find the basic inside dimensions of a full size bus.
Thanks! Can't wait to see how everything is coming,
Jessie
Gypsydreamg is offline   Reply With Quote
Old 01-28-2014, 05:03 PM   #122
eyedeal.ink's Avatar
Jessie
Thanks Jessie, from the drivers seat to the very back is 29 feet, bus total length is 39. We could have had more room to work with with a flatnose bus but we were set on the dognose from the start.
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 01-28-2014, 08:30 PM   #123
Perfect! Now it looks more realistic. And I agree, I just like the look of the dog nose better. Thanks
Old 02-02-2014, 03:19 PM   #124
Been a while, still making progress. New years day we made the decision to move the bus ten miles up the road to finish her up at Janelle's parents house. At that point it had been a year since we started the bus, batteries went dead November 2012 and we had an air issue at the time (air dryer was popping off about very 15 seconds) so we were focusing on the inside build with the goal of getting new batteries soon. Took us a couple weekends to get the bus ready to hit the road, namely securing tools and building materials, replacing the batteries, installing a center awning support, and a front door lock. Starting the bus was fairly easy, she fired up immediately and then died and wouldn't fire at all. Put in a call to a friend and he said it sounds like it lost it's prime. Quick trip home to reference the service manual and it turns out we have a hand prime pump and a bleed screw just after our fuel pump. Couple pumps until we saw fuel come out, tightened up the screw and she fired right up. We drove 3 miles down the road to a local diesel mechanic to get the air leak fixed and a DOT inspection. after two days I heard back that aside from an "internal leak" in the air dryer which according to him is "ancient" and the idle being set a little low, the bus checks out perfectly, nearly new on the brakes, updated air lines, oil looks new, and of course the coolant is perfect (we flushed and refilled after removing the interior heaters a year ago). He ended up replacing the governor on the compressor while trying to diagnose the air issue which was a fairly cheap part.
So that leaves us with the air dryer..., hopefully that's the culprit. Anybody have to replace their air dryer? How often does your air dryer "pop off" when you're sitting at an idle or driving without using your breaks or door, etc? According to my mechanic, the system builds pressure until the governor kicks it off and sends a signal to the air dryer to exhaust. It should then hold pressure until the air is used down to a certain pressure at which point the governor kicks it on and the process begins again. He said it should hold air pressure for weeks as long as there's no leaks and the air isn't used.
Old 02-03-2014, 08:17 AM   #125
I really like your build, glad your back , keep up the good work
Old 02-04-2014, 03:40 PM   #126
Thank you.
Old 02-04-2014, 03:51 PM   #127
Well he was right, air dryer was the culprit, $488 for a new Bendix AD-9 and she holds air beautifully. After stewing over having to buy a new air dryer, I'm happy we replaced it, the dryer saves the rest of your air system in the long run. Drove her ten short miles north and now we're really anxious to get her finished up, she's a pleasure to drive and we've got a "first major road trip" goal for the week of the fourth of July.
Old 02-13-2014, 03:48 PM   #128
Great build!!! inspiring to get my butt out to finish mine...
Project Niles Skoolie
http://www.skoolie.net/forum/viewtopic.php?f=9&t=55161
FOLLOW US ON FACEBOOK TOO!!!
https://www.facebook.com/NilesSkoolie
NilesSkoolie is offline   Reply With Quote
Old 02-25-2014, 10:12 PM   #129
Finished the cupboard doors (they'll need a few more coats of polyurethane) and added handles, tested the propane and stove and cut the tile, we'll glue and grout next weekend.
We made the removable stove cover out of 3/4 plywood with wood rails and wood trim. With a hinged counter support we'll be able to "extend" our counter-top when cooking or take our counter outside to an outside table.
Old 02-26-2014, 09:46 AM   #130
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
Very nice indeed!
I noticed that your kitchen outlet is a regular 15 amp outlet. If that hole in the counter is for a sink, you should replace that outlet with a GFCI outlet.
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: http://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Got it home, time to make it home. ThePimentals Skoolie Conversion Projects 11 07-29-2013 09:17 PM
HOME bansil Skoolie Conversion Projects 2 05-29-2013 11:53 PM
Just for fun... do this at home frank-id Conversion General Discussions 0 07-26-2009 11:14 PM
new bus home westport_wayne Everything Else | General Skoolie Discussions 7 09-14-2006 07:50 AM
Well, I'm home with my new bus! Griff Coach Conversion Projects 11 07-07-2006 12:00 PM
