Old 02-26-2014, 09:55 AM   #131
eyedeal.ink's Avatar
Re: Our Bus, Our Home
Originally Posted by nat_ster
Top notch man!
Thanks man!
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 02-26-2014, 10:37 AM   #132
LandLubber's Avatar
Chassis: All American RE
very nice work. I am new to the community, so I am seeing all of your build for the first time, we love it.
Roll Tide
LandLubber is offline   Reply With Quote
Old 02-26-2014, 12:40 PM   #133
Originally Posted by Locutus
Very nice indeed!
I noticed that your kitchen outlet is a regular 15 amp outlet. If that hole in the counter is for a sink, you should replace that outlet with a GFCI outlet.
Thanks, yeah that outlet and one next to it are protected by a GFCI breaker, outlets are just too fat to cram into the low profile space. I figure it won't be that bad if it trips, our load center is only across the "hallway", literally one step away. I decided to go this route after cramming one into the bathroom.
Thanks guys, slow and steady, like eating an elephant, one bite at a time.
Old 02-26-2014, 12:51 PM   #134
Coachwork: blue bird
Chassis: International, 3000, Blue Bird
Engine: Dt360
Rated Cap: 25000
I've enjoyed the work you have done so far, really is an inspiration, I will be putting tile on our counter tops checked out solid granite countertops they wanted $800. for 8 feet total. I am just made of money or that's what everyone around me thinks, lol, I wish it was so. Thanks for the great photos.
Looking for that happy place, I've got a home on wheels and I'm going to find it.
Better Tomorrows is offline   Reply With Quote
Old 02-26-2014, 01:05 PM   #135
Thanks, yeah, granite would be cool but the cost and the look wasn't right for us, we wanted something we could set hot stuff on, maybe a pot of soup or something off the woodstove or something. We've had tile in the past just didn't like the lighter grouts, seemed like even if you seal em and kept it clean, the grout always found a way of staining especially near the sink and stove. We also had a problem with cracking wherever someone might be liable to sit. So this time, being that it's a school bus, we'll be using a dark "pewter" grout for the majority and we purchased a couple tubes of matching sanded caulking that we'll be using for the rest, nothing worse than cracked caulk.
Old 02-26-2014, 01:51 PM   #136
Engine: Dt360
Rated Cap: 25000
I agree the dark grout will work best, I will have to keep that in mind or I should start to write this stuff down as I forget when I am in the store and buy the wrong items and have to return it later, you know another trip to town, and more money spent on the bus.
Old 02-26-2014, 11:31 PM   #137
schoolmarm's Avatar
Year: 1985
Coachwork: Wayne Chaperone
Chassis: chevy
Engine: 350
Nat, I enjoyed the video on you tube, certainly a neat and nice looking install.
schoolmarm is offline   Reply With Quote
Old 02-27-2014, 12:27 AM   #138
schoolmarm's Avatar
Year: 1985
Chassis: chevy
Engine: 350
I don't have a counter top in my bus, If I did this is what I would use.
Old 02-27-2014, 02:29 PM   #139
We built our countertop out of 1/4" ply glued & nailed to 3/4" ply = 1" plywood. That stuff looks awesome, probably woulda used it if I'd known about it or where to get it, weight and vibration/bumps are always a consideration in these things.
Old 03-03-2014, 08:27 PM   #140
LandLubber's Avatar
Very nice looking build. Really looking close at your bus. I know it's been awhile since you did the roof's paint job, but I want to mix up the hytech additives as well (to save on the shipping handling). What type of primer did you use on your roof? and what type of paint is good to add the hytech stuff to? I plan to roll it on.
BTW your wood stove is DOPE. Thanks in advance.
Roll Tide
Got it home, time to make it home. ThePimentals Skoolie Conversion Projects 11 07-29-2013 08:17 PM
HOME bansil Skoolie Conversion Projects 2 05-29-2013 10:53 PM
Just for fun... do this at home frank-id Conversion General Discussions 0 07-26-2009 10:14 PM
new bus home westport_wayne Everything Else | General Skoolie Discussions 7 09-14-2006 06:50 AM
Well, I'm home with my new bus! Griff Coach Conversion Projects 11 07-07-2006 11:00 AM
