07-25-2013, 10:02 PM
#81
Engine: DT466/AT545
Re: Our Bus, Our Home
Thanks for posting your progress on the plumbing. Looks great! I'm coming up on that task as my next project and you have inspired me. I just recently returned all the PVC I had bought earlier at Home Depot and plan on using PEX instead for as much as I can of the system. I've seen several really nice looking PEX installations on this forum, so I'm looking forward to getting into it, especially now that I've seen another reminder of how easy it is to use. I'm also jazzed about the insulation on the hot water lines, I might even put some aluminum tape around mine for good measure, especially for any lines I am running outside. Onwards!
07-25-2013, 11:47 PM
#82
Just thinking about it, maybe you can get something custom made for you to fit the exact curve and pitch of your roof. Here is a link of custom plastic company I pulled off web. I, in no way endorse or know anything about them, just kind of a place I thought looked like a good starting point.
http://www.laneplastics.com/custom-t...e-forming.html
I, uhh, also have a carpenter.... it's a '90 but I am sure that if it matches your roof it would match mine so please keep me looped on this one!!
07-29-2013, 01:34 AM
#83
Originally Posted by eyedeal.ink
just before falling asleep last night I realized I could have gained 1 1/2 inches in headroom in my shower if I'd have cut the plywood and insulation out before installing the pan duh. of course that would have made for a very cold shower floor, I could have insulated that particular spot from underneath. This led me to lay awake for the next three hours trying to figure out how I could still pull it off. Nope, too much glue. Not unless I want to start from scratch on the shower walls. That ain't happening. gotta laugh. It'll be a stool in the shower like I said before. Add this one to the list of "what I would have done different".
Nope, not gonna go down like that, 1 1/2 inches of head room, a little bubble in the plywood top layer right where the shower controls are going (not to mention the plywood only being 1/4 inch) and the fact that 2 part epoxy doesn't stick to silicone (it's a mold release) leads us to redo the shower woulda is going to end up being coulda and eventually shoulda I'm afraid... gonna go with tongue and groove cedar boards instead I think. Demo is already done pics to follow after construction tomorrow.
"That's,. like,.. your opinion, man...." - the Dude.
08-05-2013, 02:58 PM
#84
Engine: Ford B600 6.6 TurboDiesel
Rated Cap: 32
Very nice job! Want to come to PA and help me? hahah
Curious, why did you take out the rubber flooring and the ply wood? You ended up replacing it anyway. Im just curious cause im starting my project soon and im considering doing it too.
08-05-2013, 04:00 PM
#85
Engine: 3126
Hey Mr. bbeenn88 in PA, I'm your neighbor in Maryland.
Most people take up the floor to 1) remove that school bus smell. It seems to be from the rubber. 2) to check for rust. All those wet boots and shoes and leaky windows.
08-06-2013, 12:21 AM
#86
Thanks a bunch! Mainly to check/paint and seal the metal and seat holes, and to install 3/4" of insulation.
08-06-2013, 01:54 PM
#87
Rated Cap: 32
wmkbailey hi neighbor!
eyedeal : thank you for the info.
did you glue the new plywood to the metal underneath?
08-06-2013, 02:33 PM
#88
Rated Cap: 89
Our rubber floor doesn't smell. And it is bare and sitting in an oven. I did mop it with a solution of laundry detergent and bleach... threw the mop away afterwards because it was black. I was just trying to clean it and kill any mildew. David slept on the floor in temps of 100°F and up for over a week. He said it didn't smell then. Downside of living on the rubber is it makes the bottom of our bare feet black. I guess that makes David a Blackfoot also!
It washes off in the shower. Maybe what you guys are smelling resdual mildew. I would suggest anyone who keeps the rubber floor, mop it more than once to kill any bacteria or fungi before you cover it up.
08-06-2013, 02:41 PM
#89
Engine: 3126
With all those nice clean children ridding in the bus for the last 12 years, what bacteria or fungi?
08-06-2013, 07:55 PM
#90
Rated Cap: 89
Our bus had soggy, river-soaked, white water rafters riding it before we got it.
08-07-2013, 10:20 PM
#91
So here's a pic of the demo (notice the light, it was a full day of work). We got that inch and a half after all The hardest part was carefully removing/cleaning the shower pan and pretty much anything that was coated in the caulking we chose.
08-07-2013, 10:23 PM
#92
This is the stuff, used a few tubes of it the first time around and it turned out to be a major chore to remove, tough stuff, I highly recommend it.
08-07-2013, 10:34 PM
#93
Here's a few pics of the shower as it sits. Again, it needs a few trim boards. We decided to invest in some clear penetrating epoxy sealer and then we'll coat it with a few coats of marine grade spar varnish. Overall we're happier with this result (not to mention I can stand all the way up ) We'll wait to add the trim boards, plumbing and fixtures until after we seal all the end grains; the ones that don't show have already been sealed...I used a dozen tubes of that Dap 3.0 stuff in the construction, a bead at each end grain and in behind the tongue of each board (tongue pointed upwards). This time I was very careful no to get any of the silicone on any surface I plan to coat with the epoxy.
08-07-2013, 10:54 PM
#94
We also worked a bit on the toilet/sink side of the bathroom. Janelle had the idea of making a sink out of a bowl, I think it turned out really cool. still a ways to go on this side too, we plan to add a built in medicine cabinet and another cabinet above the toilet.
08-08-2013, 03:29 AM
#95
Shower turned out good
08-08-2013, 08:16 AM
#96
Engine: 3126
Nice way to fit everything in a small space.
08-08-2013, 09:27 AM
#97
Shower looks amazing. I LOVE cedar. I am planning on fake tile in mine, but I may do the ceiling in cedar, after looking at yours. Or I may completely copy it
Brutus
08-08-2013, 12:49 PM
#98
Bathrooms looking really good!
08-20-2013, 07:55 PM
#99
Got our CPES in yesterday and took advantage of some beautiful Western Washington weather (we've been pretty fortunate the last couple months with the weather) to lay down a decent coat of the stuff on any wood we want clear and water proof. http://www.smithandcompany.org/CPES/ the idea is that the solvents in the CPES carry the 2 part epoxy deep in to the wood fibers. The epoxy takes longer to cure (4-8 days) but you're supposed to "hotcoat" it with spar varnish in 18-24 hours (with the weather we're having) and this glues the varnish down as the epoxy is still curing underneath. We'll be doing two coats of CPES with 8-10 coats of McCloskey 's spar varnish on the shower. That should keep it looking good for a few years (knock on wood). As for PPE goes, we didn't take any chances, paint and pesticide respirators, gloves and goggles with the nasty mix of solvents. Also got the shutoff valves installed for the toilet and bathroom sink, pex makes plumbing easy. Will post pics soon.
08-20-2013, 11:30 PM
#100
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
Really nice work. The shower looks great and it's the only one I've ever seen built with cedar. I can't wait to see it with the finish coating all done.
