Old 05-05-2013, 05:16 PM   #151
Re: Our Farold's Conversion
Originally Posted by travelinwithus
My layout is the same. I thought about putting it in the same location but in the front but thought that would look kind of ugly. I am wondering if a simple fan would circulate the air enough to transfer the cool air to the front.
I was able to use a box fan on the floor, at the bedroom door to "push" air into front of bus, It worked surprisingly well, altho I had a "room" to condition the air before excess air was moved out thru door way
as long as ac doesn't suck in the cold air and freeze up, it will work full time
And some curtains on the sun side will help alot
Old 05-05-2013, 08:53 PM   #152
travelinwithus's Avatar
After a couple hours of work the A/C unit is installed
I also ran a new circuit for the A/C. Everything is working great and I can feel the cool air blow about half way up the bus. It was only in the high 60's or low 70's today so I couldn't really test how well it cools because it was already cool and the compressor didn't run but 1/4 of the time.
I sure am glad I installed it today rather than when it was 80+ because I was sweating my butt off as it was, lol.
I think it is going to work out well where it is. I will be sure to post an update the first chance I get to test it out.
travelinwithus is offline   Reply With Quote
Old 05-05-2013, 10:34 PM   #153
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Great looking install. Now all you need is a strong fan. But, of course, we are all your fans.
Old 05-05-2013, 10:54 PM   #154
Diesel Dan's Avatar
Engine: DT466/AT545
I think that is the perfect place to mount that type of AC. It's a low-cost solution that may not cool quite as well or evenly as a top-mounted and centrally located RV unit, but costs a whole lot less to buy and replace if needed. I think if I were going that route, I would do the exact same thing you did.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 05-06-2013, 04:09 AM   #155
Great install,
Old 05-06-2013, 06:53 AM   #156
Looks good, that's where I have my rear a\c its a 5000 btu, works great for the back part of the bus, up font I have a portable 9000btu with 4 inch hole for exhaust. work fine, the newer ones are a bit smaller then the one I have, but this one is ok and I can run it off my generator when driving to keep the front cool.
Old 05-06-2013, 04:22 PM   #157
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
i want to but an A/C in the back too but i can't fine a wattage chart too see how much it putting. the only thing i run on my 4000 watts genset is a mid icebox when on the road... so if anybody has a watts cart pass on thanks
keith is offline   Reply With Quote
Old 05-06-2013, 06:30 PM   #158
GreyEagle's Avatar
Keith......... Is your generator set a 4000 KW? If so it will pull your AC.
That's what I have on my motorhome and I can run the AC plus a few small items too...
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 05-06-2013, 06:33 PM   #159
Accordion's Avatar
Year: 1973
My 4000 watt Onan generator would run my 13000 BTU roof air that was on my Dodge class C.
Old 05-06-2013, 06:46 PM   #160
I plugged my Killowat (measures watts and amps of appliances) and with battery charger and A/C running it was pulling about 1000 watts, 350 watts when the compressor wasn't running.
Farold's Adventure Number 2 travelinwithus On the Road | Travel, Trips, Camp Sites, Tailgates 11 06-25-2013 10:10 PM
Travelin' With Farold travelinwithus Everything Else | General Skoolie Discussions 7 01-20-2013 02:46 PM
A Perfect Christmas Afternoon With Farold travelinwithus On the Road | Travel, Trips, Camp Sites, Tailgates 3 01-04-2013 09:42 PM
