Old 08-14-2013, 08:23 AM   #41
wmkbailey's Avatar
Engine: 3126
Re: Our New Home
Originally Posted by JakeC
X2!
Also, I don't know what kind of welder you have, but if it is a wirefeed, try using fluxcore wire. You don't need gas and it works MUCH better in wind.
When getting my welder I was told the same thing, unless you weld inside out of the wind get fluxcore. It works well for me. I was also told to stay away from welding galvanized. The steel under my windows was galvanized, I wasn't able to re-use it
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 08-14-2013, 08:35 AM   #42
JakeC's Avatar
Re: Our New Home
Yup, same And it really is no joke. Yes, I have ignored it in the past...and gotten sick to the point of almost throwing up. Lesson learned!!
Brutus
Old 08-14-2013, 09:41 AM   #43
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Our New Home
Originally Posted by D&ACaple
the back windows blockedout, now what to cover it, wood don't work so well, mabe illhave someone weld it, or fiberglass...
I think it was Lorna that glued thin sheet metal onto the plywood and then attached and caulked it in to the window space. It may be too late for you to do that, or not, but I thought I'd throw that idea out there. You would likely have to remove the plywood, glue on the sheet metal, then re-install. You could try to do it in place, but it would be much better to have the window frame overlap the sheet metal.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 09-17-2013, 11:30 PM   #44
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: Our New Home
Why weld? Your bus is held together with ribbets, I mean rivets. Use the same to skin your windows.
I'm hungry!
You Gotta Let Me Fly
Old 10-28-2013, 11:59 AM   #45
D&ACaple's Avatar
Chassis: Ford B-700
Engine: Cummins 5.9l Turbo Diesel
Rated Cap: 28
Re: Our New Home
well long time no post no net in the toolies yet the bus is coming along it will never be done the toilet and dinks are in and gunctional no hot watercheater so at leady we can drop a load novholding tank so its hard lined to the septic it made the trip to north carolina just fine 7.5 average loaded with our crap and towing our minivan about 1500 miles not a drop of oil used which ivwad shocked by that considering how black our white van got. but weve been living in it now since the end of august i dont mind it at all some finishing touches will make it our homr. till then its a roof a place to sleep eat n poo so the basics are covered nc is expensive to live so our $450 dollar lot rent with trash water electric n cable included we can start stashing for a plot of land.
Yes..... it IS a bus, and no you can't have it!
D&ACaple is offline   Reply With Quote
Got it home, time to make it home. ThePimentals Skoolie Conversion Projects 11 07-29-2013 08:17 PM
HOME bansil Skoolie Conversion Projects 2 05-29-2013 10:53 PM
Just for fun... do this at home frank-id Conversion General Discussions 0 07-26-2009 10:14 PM
new bus home westport_wayne Everything Else | General Skoolie Discussions 7 09-14-2006 06:50 AM
Well, I'm home with my new bus! Griff Coach Conversion Projects 11 07-07-2006 11:00 AM
