Old 07-15-2013, 05:53 PM   #1
Year: 92
Chassis: Saf-T-Liner
Engine: Cummins 8.3L 6CTA-210
Our project bus begins
After a couple of years considering a skoolie project we finally took the leap and purchased a 1992 Thomas Saf-T-Liner. I will post progress photos as we go...
raceminer is offline   Reply With Quote
Old 07-15-2013, 06:03 PM   #2
Re: Our project bus begins
Congrats on the bus...now you just need to score some wheels and tires!!
Malkieri is offline   Reply With Quote
Old 07-15-2013, 06:51 PM   #3
Year: 92
I didnt realize the picture posted. This is the driver side steer axle, holy rust!!!
It appears this bus was under about 4' of water. Major wire wheeling going on. New canisters, auto slack adjuster, gabriel shocks. Removing rust from everything and then primer sealer and paint.
Old 07-16-2013, 09:26 AM   #4
JakeC's Avatar
Well done!!
Brutus
Old 07-16-2013, 02:57 PM   #5
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
It sure looks like you know what you are doing.
There are many warnings about taking those air brake canisters apart. Apparently the spring pressure inside them is very powerful. I have been told that if you take them apart, you can be seriously hurt.
Old 07-16-2013, 03:16 PM   #6
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
that what the rod for in the air canter ,don't take apart with out that rod in it,,,it pull the cam back and hold it in place so u cand take it apart ,the only thing in side is what they call a rubber pancake and spring,u can rebuild it by replaceing the pancake...there are two size and the pancake is mark to the size..all new canters have the rod if not some one has taken it out,,they are shipped from the factory with one,,,and when u get it back together leave the rod in it and run the nut down to the housing.
keith is offline   Reply With Quote
Old 07-16-2013, 03:26 PM   #7
I am planning to get info off my front axle and brake parts so I can look for manuals online...this weekend.
I hope to start on tear down in 3 weeks after next camping trip
Old 07-22-2013, 06:55 PM   #8
Year: 92
I am not a mechanic nor do I offer the following as anything other than an observation. Always follow manufactures recommendations and/or consult a professional when working on braking or any other systems.
The air brake canisters on the front (steer axle) do not have spring pressure other than the internal spring used to return the pushrod when air pressure is released. The rear brakes, or maxi's, have a double canister configuration, just like the front brakes but with an additional, STRONG spring in the second can that allows the brakes to be automatically applied when air pressure is reduced (emergency situation) or the parking brake is applied. You are right, do not try to pull these apart, it could cost you dearly. These brakes need to be fully caged with a proper tool in order to adjust the slack adjusters.
Old 12-28-2014, 12:38 PM   #9
Year: 92
Been working on the project for a while, thought it about time to update with some photos
http://www.skoolie.net/forums/album.php?albumid=576
the above link should take you to the album
Old 12-29-2014, 05:19 AM   #10
Beautiful bus. You're absolutely doing it all right. But you know that!
LOVE it!
I'm going a similar route with my 92 Senator. RV windows look nice.
Old 12-29-2014, 09:17 AM   #11
browncrown's Avatar
Rated Cap: 79 at Birth
Very nice work!!! Loved the pictures of the bus!
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 01-03-2015, 02:53 AM   #12
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
Actually, there's no need to cage the rear brake chambers before adjusting the slack. Just chock the wheels and release the parking brakes. This will 'cage' the brakes and allow proper adjustment of the slack.
But yes, those springs are strong enough to stop a bus and can kil!
Safe bussing is no accident
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
Old 01-03-2015, 11:26 AM   #13
Nice build!
Nice work on the build. Looks like you have the perfect shop to work on the bus in with all the tools needed. Great work!
dgorila1 is offline   Reply With Quote
Project Road Buss begins! RoadBoss Skoolie Conversion Projects 11 05-27-2014 09:12 PM
And it begins..... opus Conversion General Discussions 2 05-31-2010 02:17 PM
and so it begins. gromit Everything Else | General Skoolie Discussions 13 11-16-2008 12:27 PM
The saga begins retrogeek42 Skoolie Conversion Projects 8 09-29-2008 08:35 AM
It begins! w1bmw Skoolie Conversion Projects 36 08-29-2008 12:18 PM
