Old 02-13-2018, 01:59 PM   #141
And I'll second ECCB's recommendation...silicone is not for automotive use. Use an OEM type Seam Sealer. It is urethane and will not only seal better but will last the life of the vehicle and is fully paintable. Can be found at any auto paint supply or online. 3M and others make it.
Old 02-13-2018, 02:40 PM   #142
brokedown's Avatar
Is SS and regular steel "close enough" to negate the issue of differences? I don't mind ordering a bunch of SS rivets, they sure didn't have them locally.
Follow us on Facebook, Instagram, and Twitter
Old 02-13-2018, 03:12 PM   #143
sojourner's Avatar
Engine: DT408
One thing most forget about when considering galvanic corrosion is the need for an electrolyte in the equation. As long as things are dry you most likely won't see much of a corrosion issue. It's in wet environments involving conductive fluids that can become problematic. Salt water is especially problematic and might be an issue if driving on thawed salted roads and splash wetting things down. Fresh water causes hardly any galvanic action, depending on the mineral content, due to it's relatively low conductivity. Remember also, that the more "noble" a metal the less it want's to give off it's electrons. Zinc (galvanizing metal) is lower on the noble scale than is aluminum (albeit only slightly) and aluminum only slightly less than mild steel. The more voltage potential, the more possibility for corrosion. I really don't think you're going to see much of a problem with aluminum rivets in galvanized (zinc) metal especially if it's not structural in any way. That being said, you can never go wrong using stainless steel rivets.
Here's a link to a chart that can help: http://www.designbyinitiative.com/fi...anic_Table.pdf
I'd be more concerned using an alkyd/oil primer on galvanized steel and saponification causing the primer to ultimately not bond well. Better to use an acrylic primer on galvanized metal.
https://www.sherwin-williams.com/homeowners/ask-sherwin-williams/problem-solver/peeling-cracking/peeling-from-galvanized-metal
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 02-17-2018, 04:47 AM   #144
golfersmurf57's Avatar
Originally Posted by brokedown View Post
I got the HF rivet gun and several boxes of rivets. So far we've used about 60 of them doing the one window and the floor. We've already painted the floor and we're using aluminum rivets so the sealer is just to 100% make sure water stays out, i assume my next layer will be rigid foam insulation right on top of it.
With regards to the bamboo flooring, mostly I'm reading bad things about using it if you don't have humidity control. They go as far as saying to lay the planks out for days before installing them so they can pre-swell before you lay them down, that's just not compatible with us driving around the country.
Roll floor pretty much stays the same level of "meh" no matter what.
If I remove the bus windows prior to covering with sheet metal is it going to affect the structural integrity of the walls?
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
Old 02-17-2018, 10:01 AM   #145
Chassis: Saf-T-Liner MVP ER
No.
However, you will want to make sure there is zero twist in the frame before sheeting with new steel. So have the bus firmly planted, straight and level.
Velocipedic drove his 1500 miles home with no windows, to no apparent ill-effect.
Steve Bracken
Build Thread
Old 02-17-2018, 08:17 PM   #146
brokedown's Avatar
Well connected sheet metal should provide way more structural support than the windows ever did... I don't believe the windows provided any meaningful amount of structure.
