Old 09-11-2014, 09:21 AM   #31
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Re: Our Skoolie Journey
Looks like I'm not going to be able to save the garage. Maybe on the next bus. Even squeezing it to 5' it just takes up too much valuable space in the front kitchen area.
I'm just going to look for an enclosed trailer that will fit my mustang and a couple big touring bikes. Basically if we are headed out for 6 months then the trailer will come along, if it's a shorter trip then possibly just a toad car and a couple dual sport bikes on a rear rack, prob dome dr350's or some newer drz 400's.
I'm getting closer to a "firmer" floorplan.
Ponyracer is offline   Reply With Quote
Old 09-13-2014, 02:09 AM   #32
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Just picked up a bunch of redwood 5/16 tongue and groove lumber off cl $30. Not enough to do the whole bus but it's a start. I love CL! I've also go my eye on a couple gas powered generators that are electric start.
Thinking of mounting the generator where the front stairs currently are. I will be moving the door farther back so no issue there. I'm thinking of tying the gen exhaust into the bus exhaust. Thoughts?
Old 09-13-2014, 11:55 AM   #33
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Was perusing the short bus section and came across this thread, (great thread by the way!)
viewtopic.php?f=36&t=465837&start=105
I like what he did with his table so I'm going to steal it! Slightly modified of course.
Here's an updated floorplan,
So add something like this into the center that flips up on both sides.
Old 09-13-2014, 09:34 PM   #34
In case you haven't seen'em...there are standard RV, flush in the floor table mounts that will allow you to remove & store the whole thing. Had one in a tiny little Toyota Odyssey camper that was great. Pop it in when needed, pop it out and your back to an open floor.
Old 09-14-2014, 08:49 AM   #35
nice table, I like the way it folds up and out of the way, its not for me, that was one thing when I built my bus I wanted everything in place, no folding or un folding tables or beds etc, I like everything ready to use , but that's just me
keep up the good work and ideals
Old 09-14-2014, 11:06 AM   #36
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Also figure you could use the center section for storage as well. Just not sure about how to make it into a bed yet.
We apparently have 4 extra heaters in the bus, and I'm hoping that at least one is a webasto diesel heater. I'm hoping to be able to turn that into a diesel fired water heater. Don't really have a direct way ahead, just spitballing an idea now.
Old 09-14-2014, 11:10 AM   #37
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
THAT is a GREAT idea!!!!!
M1031 is offline   Reply With Quote
Old 09-14-2014, 02:13 PM   #38
I have been thinking of modifying a bus with a garage at the back and you seem to have the skill set to carry it out. So I thought I would share my vision with you. I started out by looking at rear engine buses. Most build a bed at window height to use the engine cover as part of the bed. I then started thinking that towing my large trailer will be hard due to the height of the rear bumper. 28" is the perfect hitch height for my trailer. The idea to solve all these issues is to cut the floor and frame out 10 or 12 inches behind the rear suspension and drop the frame down to around 24 inches. By building a large square tube frame in a box shape you will increase the strength of the rear frame area. The square tube would come up from the lowered frame, connect to the original frame location, go back under your bed, and connect on to the other end of the lowered frame. This would give you a large garage with a large curbside door (or both sides) and a fully reinforced perfect height hitch. Since you are raising the roof you would also have the option of raising the bed even higher to create the garage. Remember the bus is not just floor space but also vertical space as well!
sweetfarm is offline   Reply With Quote
Old 09-15-2014, 10:52 AM   #39
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
AMAZING IDEA!! I'm def going to have to look into that. Wouldn't work on a rear engine bus obviously but I can see you could easily drop the floor height to the bottom of the skirting or just below. Hell if you door'd both sides u could ride it in and out. The only issue I see is the height of the bed inside and the trailer towing ability. I was actually thinking about something cool, do a double raise, (raise the entire roof then again on the rear section) like the old greyhounds then do a spiral staircase to get into bed. Wouldn't be a full spiral but you could do a 3/4 spiral that could climb 4-5' I'm sure.
Thanks!
Old 09-15-2014, 12:00 PM   #40
I found a picture of a front engine bus that still has the rear window. You said there where buses in the junkyard up there. It would be great if you could buy the back of this bus to graft on to yours. Cut the back and raise it with your roof and lower the door to work at the curb. Reusing is always easier and faster than creating from scratch. Now that I look at a little more, I think you could raise the door with the roof. Then you could extend the bottom of the door down to the bottom. That way you could reuse the hinges on the bottom and have a built in ramp. You would need to separate the bed on the inside from the ramp, but this would solve any loading issues or ramp storage.
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
Zachary Dash Bus Journey ZacharyDash Conversion General Discussions 1 09-26-2014 01:20 PM
Prepping for the Journey - Picking up my Skoolie White99z On the Road | Travel, Trips, Camp Sites, Tailgates 14 03-24-2014 09:56 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
