Old 09-10-2018, 10:32 AM   #21
Hey Casey,
Where are you located? I am in Dayton.
Old 09-10-2018, 11:23 AM   #22
CaseyBrown's Avatar
Chassis: TC 2000
Engine: C8.3 Cummins
Hey Casey,
About 4 hours west of you on the east side of Chinook pass.
Casey
CaseyBrown is offline   Reply With Quote
Old 09-16-2018, 04:03 PM   #23
Casey
OK
Not as "Eastern" as I expected. We are 60 miles from Idaho.
Old 09-16-2018, 09:20 PM   #24
CaseyBrown's Avatar
Chassis: TC 2000
A little more progress. First I finished the rib tie points by welding the 2 2x5 pieces together with a bottom plate, and thru bolting with a pair of 3/8" grade 8 bolts with nylock locking nuts...
Next I cut "fingers" into the edge of the upper and lower sections...
I took some flat nosed lineman's pliers and bent the fingers and then clamped an aluminum bar to the top and bottom opposing fingers with a piece of steel cut out the section of roof that was removed. This piece straddles the cut between two fingers. I then welded the pair of fingers together with this piece...
The bottom picture shows four fingers chained together with the fifth one ready to weld. When done I'll have 2 parallel rigid lips to rivet the transition piece to.
Onward Ho.
Casey
