Old 09-24-2016, 10:30 AM   #11
Chassis: International S3800
got it... temporary should be no issue.. all I did was make sure they are in parallel .. my rearmost heaster has a built-in reducer on it as its effectivelly a loop-through so that created resistance.. I have some heaters far apart and some close together... and all my cores get hot... I do have a boost pump that came with the bus which im sure helps for good flow.
Old 09-27-2016, 02:21 PM   #12
Chassis: Dana
Engine: 5.9 l Cummins turbo
Rated Cap: 30ft
Pics
Ok, getting around to uploading pics now. Me and the fam are building a home in this here machine. We're really doin it! Thanks to the creators and contributers of this forum, I hope to add whatever knowledge I possess, and/or entertainment at least.
RatBaptist is offline   Reply With Quote
Old 09-27-2016, 04:06 PM   #13
Chassis: Dana
Rated Cap: 30ft
More pics
Yeah, I'm gonna leave that for a bit.
One by one, they all come out.
Bonus!
After some demolition.
Compressors on top, cool.
The only significant rust I could find on the motor components. (Brake pump & power steering pump?)
We're about to start removing wall panels and ceiling, patching and treating the rust with Ospho and rustoleum. Hoping to have this thing insulated before it gets too cold!
Cheers!
Eric, Katy and Zion
Old 09-27-2016, 05:11 PM   #14
Justin McCormick's Avatar
Chassis: Saf-T-Liner MVP ER
Engine: Cummins 5.9L Diesel Engine
Rated Cap: 83
Great seeing photos. Its a nice looking bus. The floor looks like its in good shape. Two compressors. Does that mean you have two skirt condensers as well?
Follow our bus blog here -
http://www.wildernesswandering.com/
Justin McCormick is offline   Reply With Quote
Old 09-27-2016, 05:22 PM   #15
Coachwork: Ward/AmTran
SWEET lil bus!
YOu really should change your user name accordingly, Rat Baptist.
Roll Your Own Build Thread
Old 09-27-2016, 06:53 PM   #16
Chassis: Dana
Rated Cap: 30ft
SWEET lil bus!
Haha, of course! I'll wear it proud
Old 09-27-2016, 08:02 PM   #17
Chassis: Dana
Rated Cap: 30ft
Yep, there were two of those big #%^*'s back there. I decided to remove the one for the back, and keep the front one for OTR cooling.
