Old 01-06-2008, 04:39 AM   #21
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
Re: Pics of 87 Ford B700 Blue Bus 6.6 Diesel
Originally Posted by Chuck Webb
We bought some Ford Blue, mixed in some white, and John Deere Green too my wifes liking, and wa-laa. We rolled it on. The roller we used left behind fibers. Get a foam roller. Good luck. We only used one gallon plus the White and Green mixed in with it.
http://picasaweb.google.com/stonemanrip/B700FordBus
I remember reading about your paint job, and how you came about that color (I also liked the green ).
For a roll-on it looks good. In the pictures, you can't really tell that it was roll painted, all except for the young lady rolling on the paint.
Now, is this a 50 foot (looks good at 50 feet), or a 5 foot paint job?
Roasting8 is offline   Reply With Quote
Old 01-06-2008, 03:42 PM   #22
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
That's good at 50 ft, 5ft you can see where the roller shedded along the way. When we spray paint we always end up with the paint running or dripping. We know how to avoid this by having a steady movement and being 12in or 2ft away. Anyway, the roller was our best option.
Don't worry, I'm also terrible at spraying. I think it's because I'm impatient and I want to see the finished result while I'm spraying.
The only way I can get good results is by brushing or rolling.
Anyway, your paint job looks great.
Robert
Old 01-21-2008, 07:46 AM   #23
reprobate's Avatar
Your bus has come a long way, Chuck. I enjoyed looking at all the pics. I like the native theme, esp. the totem pole end table. Hey, did you buy your bus with the awning on it or did you put it on. I'm wanting to mount an awning that goes over the door like that. No troubles with it like that....driving or otherwise? Looking very nice.
reprobate is offline   Reply With Quote
Old 02-04-2008, 07:02 PM   #24
when my dad built the "azalea" bus he used heavy gauge extension cords for wiring, but cut the ends off and used regular household outlets. that's what i'm gonna do as well. i can't blame you for being paranoid either if you have 3 tanks in there. as always, better safe than sorry.
chase
Connoisseur of "skoolies" and "skoolie life" since "way-back," still waiting for the right chance to build one worthy of my roots.
bbkid is offline   Reply With Quote
Old 02-07-2008, 08:57 PM   #25
the_experience03's Avatar
All of my wiring is done out of 12 and 14 gauge extension cords with ends hacked off. It was cheaper to go that route than to buy bulk SO wire and I gained the benefit of having color coded circuits.
Old 06-12-2008, 11:52 AM   #26
CVanDamme's Avatar
Hey Chuck, this was the first time I had a real indepth look at your bus, its looking good, and it looks like your having fun doing it. I had a question for you, looks like you have a tankless hot water tank over your tub. I bought one used, found the manaul on the internet, and it said not for use in RV's..... I'm guessing because it gets HOT?? Can you fill me in on how yours works? any problems? Hows the stack work? Does your pilot ever blow out? Thanks I would appreciate it?
Chris Van Damme
92 Blue Bird TC2000FE
The Slab Cab'n
Follow my build up here https://www.skoolie.net/gallery/v/Skoolies/Slab_Cabn
Or join the facebook group Friends of the Slab Cab'n https://www.facebook.com/group.php?gi...2145574&ref=ts
CVanDamme is offline   Reply With Quote
Old 06-21-2008, 07:41 AM   #27
CVanDamme's Avatar
No Rush. We aren't installing ours for a month or so. Not sure if we have the interior room inside the bus or not. We may have it swing out from under the bus, we'll see when we get there.
Chris Van Damme
The Slab Cab'n
Old 06-23-2008, 02:58 PM   #28
tankless waterheater
I don,t know why thy don't want you yo use it in your rv, except for liability reasons, if you only use it to shower and keep the pilot and gas turned off it shouldent be a problem. I've had a bosch tankless in the house for about 5 years and on 2 occasions the pilot has gone out but other than that I'm sold, as long as you have water to trigger the flowmeter that turns on the main burner and gas you have an endless supply of hot water. i suggest that you plumb the outlet with 3/8 tubing to minimize the amount of water used waiting for hot, the other tip wouldbe to adjust the temp so that you use only hot and no cold mixed in for a comfortable temp to keep the burner lit at low flow rates associated withwater conservation.
good luck
Old 06-24-2008, 07:27 AM   #29
reprobate's Avatar
The Currrent River. Now there's a nice place, esp. in the summertime. Have fun.
Old 06-29-2008, 05:12 PM   #30
Congratulations at not being asphyxiated, that's always a plus! I still have to find a water heater for mine.
Abbott is offline   Reply With Quote
Run Away Diesel! - '88 Ford B700 Won't shut off. jasonvandyke Conversion General Discussions 4 02-22-2023 10:34 PM
'87 Detroit Diesel 8.2L Ford B700 conversion -- help! caster Alternative Fuels | Electric, Propane, Wood & Biofuels 0 07-18-2014 10:37 AM
89 Ford B700 being scrapped for diesel driveline for wrecker Gateway-broker Mechanical and Drivetrains 1 10-02-2010 08:20 PM
89 Ford B700 diesel automatic 30 passenger for sale Gateway-broker Classifieds | Buy, Sell, Swap 0 09-19-2010 05:41 PM
86 Ford B700 Turbo Diesel TravelingMan Conversion General Discussions 0 03-12-2005 02:01 PM
