Questions:
How much overlap do you have on the top and bottom edges of the new panels to attach them to the bus?
What is your plan for pre drilling rib holes from inside? Will you be using those to save effort when hanging the sheet (clecos?)?
What's your thought on the transition from high to low roof? I did a pendantic slope from one edge to the other on a cut just like yours, but maybe would have done something different now - ran it to the front edge of the bus roof so it was like a lifted eagle roof.
Nice job getting your roof up there.
Originally Posted by Roadrunner
My window openings were 24 1/4" high. To get 1/4" under the upper lip I went up 23 1/2" so basically a 2' raise. That was the best way to use 4x8 sheets.
